![]() | #1 (permalink) Top |
User Data registr.: 04-02-2013 Residenza: Bergamo
| Turnigy 9X fw originale come abilitare switch 3 posiz.
Ciao, come da titolo ecco cosa impostare, credo sia utile per abilitare lo switch 3 posizioni. Si attiva sul canale 7! This is what works for me. I use this on my MWC. Someone here claimed it didn't work for them, but it's worked every time for me. 1. Go to the AUX-CH menu and set CH6 to "PIT TRIM' The Pitch Trim dial will be the "basis" for the mix, leave it at FULL, turned all the way clock wise. 2. Go to PROG-MIX menu and enter MIX 1, then enter the following settings STATE ACT MASTER FLP SLAVE AUX (The first one) OFFSET -100 UPRATE -100 DNRATE -100 SW NOR 3. Go in to MIX 2 and enter the following settings STATE ACT MASTER FLP SLAVE AUX OFFSET 000 UPRATE 100 DNRATE 100 SW ID2 That's it! Go to the DISPLAY menu and you can see that channel 7 is now being activated by the 3-position switch with low, mid, high output for the 3 positions. You can now connect channel 7 of your Rx to the Mode input of the MWC and it will activate the three settings. Took me a while of trial and error to figure out. (Note, you can turn the Pitch Trim dial all the way down and it will reverse the operation of the switch. Up will be High, mid-mid, and down will be Low if you prefer that configuration for whatever reason) Preso da RCgroups, io ho provato e funziona! ![]() Prima o poi passerò a openTX ![]()
__________________ La mia pagina Facebook --> http://www.facebook.com/ivan.riva.587 La mia pagina Youtube --> http://www.youtube.com/user/Jvani83 |
Switch error con turnigy 9x | bobrock | Radiocomandi | 2 | 30 marzo 13 22:53 |
Butterfly su Turnigy 9x originale | angioletto72 | Radiocomandi | 2 | 27 luglio 12 20:26 |
turnigy 9x switch 3 posizioni | giacomo801 | Radiocomandi | 8 | 20 luglio 12 19:55 |
Turnigy 9x ORIGINALE - pregi e difetti? | CarloRoma63 | Radiocomandi | 21 | 03 febbraio 12 21:48 |
