30 novembre 14, 08:33 | #631 (permalink) Top |
UserPlus | Io l'ho preso qui: http://www.ebay.it/itm/321304609799?redirect=mobile |
30 novembre 14, 23:07 | #634 (permalink) Top | |
User Data registr.: 26-05-2014 Residenza: Anguillara Sabazia (RM)
Grazie ancora
__________________ T-Rex 470LM - Oxy 3 - 230S - 200SRX - Oxy 2 - 180 CFX - mcpx bl - msrx - nano cpx Alessandro | |
03 dicembre 14, 07:52 | #639 (permalink) Top |
User |
Da RCGroups: Nothing visible. It just adds a check for an internal factory setting that wasn't included in the older versions. It's really just a "factory compatibility" update. Because there were no feature changes there will be no changes to the release notes. It's not even a "mandatory" type update. You're all just fine with what you have. Andy Ciao Egidio
__________________ "Quanto più ci innalziamo, tanto più piccoli sembriamo a quelli che non possono volare" (F. N.) |
03 dicembre 14, 08:05 | #640 (permalink) Top |
User Data registr.: 21-07-2006 Residenza: Ferrara - Molinella
Version 1.06 Changes since 2014-April-18 New Features & Improvements Added AS3X Gain monitor functions for use with AR636, AR6335, and similar AS3X receivers. When you enable telemetry option AS3X, you are able to see gain status in real time, and adjust it with a trimmer. Note that this function performs the following re-configurations in your radio: o The F-Mode switch has its outputs set to the proper values for AS3X operation. If you are using it for other purposes, you will need to reconfigure those features to allow AS3X to use them. o Mix 16 (DX10t and higher) is used to control AS3X gain. o The selected channel is reconfigured for proper control. If you change the channel, you will need to manually re-assign the old channel to its desired purpose. o Enables a screen AS3X Gains on the Function List to configure parameters. o Enables the AS3X telemetry gain monitor on the telemetry screens. o If you are using a DX6, you can tweak the gains using the roller while on the AS3X Gains configuration screen. If you are using a higher radio, you can adjust at any time using the desired trimmer. Corrections In Heli mode, Governor Trim function now works properly. Fixed Servo Travel problem for second Elevator in a 4-Servo swash heli. Improved translations in multiple languages When using a trimmer in 2- or 3-position mode, trimmers were acting as Flight Mode trims. They are now operating in Common Mode Trim decrement tone was being controlled by the Switch Sounds setting Governor Trim on Heli Trim Setup screen is now properly adjustable If a radio is configured as a Wireless Trainer Master, if it were used as a wired slave it would not function. This has been corrected. Audio System Changes No changes |
JR 9303 - dx9 non compratele e se ce l'avete leggete | Ingo | Radiocomandi | 0 | 29 marzo 12 20:40 |
retroilluminare la dx9 jr | Baltimora44 | Radiocomandi | 2 | 27 marzo 12 21:35 |
opinioni su JR propo dx9 2.4ghz | cosmic | Radiocomandi | 2 | 11 agosto 10 22:09 |
