![]() | #9522 (permalink) Top |
Moderatore |
basta cliccare su release notes ecco cosa dicono: Version 2.1.8 / 2016-04-14 Notice: EDGE Logical Switch operation has changed. Users should check their setups, if they use EDGE with AND switch. This bug was introduced in version 2.1.2 and has been fixed in 2.1.8. (#2939) [Taranis] - Improvements of Statistics screen (#3206) - Flight Modes screen layout fix (#3307) - Fixed: left slider was affecting the value of the right slider on X9E (#2639) - USB Joystick now supports 24 buttons (CH9-32) (#3268) - Main view adjustments for 3-char switch names (#3278) [ARM (Taranis, Sky9x, 9XR-PRO, AR9X)] - Channel jitter reduced (#3233) - Fixed: EDGE Logical switch internal state was being reset by the AND switch, that affected its function (it looked like AND was applied before the EDGE processing, not after like it is done for other logical switch types) (#2939) [Lua] - Some Lua fields were not available to scripts (#3223) - Fixed: only first 32 input lines (out of 64) were accessible in Lua (#3285) - playDuration() second parameter is now really optional (#3329) - Fixed Lua io.open() problem for non-existing files (#3342) [Mega2560] - Fixed: First PPM pulse in the frame was longer (#2981) [All] - Various texts and translations corrections (se, it, pl, de) - Text to speech fixes (hu, sp) - Various small bug-fixes - PowerBox telemetry sensor names changed - Removed a few legacy timer limitations, fix non-working limit (#3301) - Removed the "RF signal low" alert before "Telemetry lost" when powering off the receiver (#2616)
__________________ ----------------------------------------------------------------------- Il nuovo forum riservato ai Multirotori è ONLINE... >>> https://www.dronerc.it/forum/ <<< Pack suoni completo con varie voci e per tutte le versioni di opentx. Ultima modifica di klamath : 14 aprile 16 alle ore 10:37 |
![]() | #9523 (permalink) Top | |
User Data registr.: 25-03-2003 Residenza: Varese
le modifiche dovrebbero essere queste RADIO COMPANION
__________________ ----------------------------------------------------- "Il buon aeromodellista atterra dove può" M.B. www.gavonline.it | |
![]() | #9524 (permalink) Top |
già uscita ![]() nessun cambiamento epocale, ma vale la pena aggiornare interessante la questione del jitter
![]() | #9525 (permalink) Top | |
User Data registr.: 05-04-2007
Il jitter era stato notato sulle taranis X9D plus e normale dalla versione 2.1 in poi, soprattutto da chi usa la radio per droni o elicotteri (secondo me non era un vero problema per la maggior parte dei modelli). Ora la 2.1.8 integra un filtro sulla lettura dei pots e pare che crei un problema sul ritorno al centro (se pensiamo a come funziona un filtro kalman e' facile intuire il perche'...). Sembra che questo sia consistente e secondo me poco accettabile, soprattutto per chi usa modelli piu' seri: facciamo di tutto per prendere servi precisi al massimo e poi la radio non ritorna al centro (l'errore e' intorno al punto percentuale, che non e' poco)... secondo me questo e' un problema ben piu' grave del jitter sull'uscita servo. c'e' una grassa discussion in corso, qui una prova. la mia opinione, personale e discutibilissima, e' che 2.1.X, sebbene piu' evoluto e con dei vantaggi, deve mantenere la compatibilita' anche con la X9E, che usa un HW molto diverso sugli stick, questo insieme al fatto che probabilmente usa una gestione diversa del microcontrollore, crea un rumore sugli ADC che probabilmente non influenza la X9E (che usa sensori di hall) ma non ha mai funzionato perfettamente con la X9D (che usa potenziometri). Sospetto che ci sia una gestione diversa del micro che (forse) crea dei profili di consumo tali da creare del rumore sui potenziometri perche' fu notato che il jitter aumenta di molto quando la retroilluminazione del display e' accesa. Credo che Romolo potra' darci considerazioni molto piu' autorevoli. Il problema del ritorno al centro introdotto adesso e' a parer mio molto piu' grave del jitter, ho letto discussioni e richieste di utenti di introdurre una "spunta" nell'upgrade del FW (tipo "noHeli" o "include LUA") per selezionare se si voglia il filtro o meno. Nessuna offesa agli sviluppatori, ho donato piu' volte e continuero' a farlo perche il lavoro e' davvero lodevole, ma forse il dover mantenere la compatibilita' su HW diversi crea problemi difficili da risolvere, ed e' piu' che comprensibile. Ho aspettato molto ad aggiornare a 2.1, perche' non riuscivo a rendere compatibili I miei scripts LUA, ora ho risolto questa parte ma ancora mi trovo nel dubbio se fare il passo o no, le ultime 2.0 sono davvero molto stabili, la latenza e' ottima e non c'e' alcun problema di jitter o ritorno al centro. Secondo me queste sono le cose piu' importanti. buoni voli, marco | |
![]() | #9526 (permalink) Top |
qui un altro video interessante: https://www.youtube.com/watch?v=h1DXSmCfEA0 e questo https://www.youtube.com/watch?v=ymvEtfYWABY Ultima modifica di marcodef : 14 aprile 16 alle ore 21:00 |
![]() | #9527 (permalink) Top |
Non avevo ancora provato, da quanto vedo il problema del centro non è trascurabile ci stanno lavorando ma al momento tutto tace..... in effetti vale la pena aspettare prima di aggiornare
![]() | #9528 (permalink) Top |
User Data registr.: 03-12-2006 Residenza: Piancastagnaio
![]() | downgrade X8R
salve, scusate il basso livello della mia domanda, ma come si fà a fare un downgrade di questa ricevente in vendita su Jonathan, io ho una Taranis di qualche anno fà, aggiornata a 2.1.7,ci vuole qualche cavetto particolare? grazie per ogni aiuto
__________________ ..non sono gli avvenimenti esterni che ci turbano, ma l'opinione che ci facciamo di essi.. (Marco Aurelio) ![]() |
![]() | #9529 (permalink) Top | |
User Data registr.: 02-01-2004 Residenza: Vicino a Saronno
http://www.baronerosso.it/forum/radi...-v1-8-1-a.html | |
![]() | #9530 (permalink) Top |
User Data registr.: 17-07-2014 Residenza: Varese
| Scusa, ma perchè fare un downgrade? non ti conviene aggiornare i modulo della radio e le riceventi al firmware LBT?
__________________ Hubsan X4 H107C - H107L; mio quad: Radio: FrSky Taranis PLUS, Frame: F450 clone , ESC: Afro 30A, motori: SunnySky X2212 980KV, FC: Naza M Lite con upgrade a V2 Stampante 3D: Prusa i3 Rework |
SONDAGGIO, Frsky Taranis | klamath | Radiocomandi | 343 | 27 gennaio 16 18:40 |
