Radio Devention 8/8S - firmware OpenSource - Pagina 12 - BaroneRosso.it - Forum Modellismo
Vecchio 18 settembre 12, 14:24   #1 (permalink)  Top
L'avatar di eriskio
Data registr.: 18-03-2010
Residenza: Genova
Immagini: 4
Volevo informare che da pochi giorni è stata rilasciata la prima release del firmware OpenSource e Freeware per la radio Devention DEVO 8 e 8S (Walkera).
In breve:
"Deviation is a replacement firmware designed primarily for the Walkera Devo® series RC Transmitters. While Deviation is heavily influenced both by the Walkera DEVO8 firmware as well as by the Flysky/Turnighy based ER9X firmware, it has been written completely from scratch to be easily portable and extensible.
Major features include:
  • Support for multiple protocols without any modifications to the transmitter:
    • Walkera Devo 6/7/8/10/12
    • Walkera WK2401/WK2601/WK2801
    • Nine Eagles J6 Pro (requires telemetry module)
    • DSM2
    • DSMx (in progress)
  • Support for other protocols with very easy transmitter modifications
    • Flysky/Turnigy 9X
  • Support for up to 255 different models
  • Transmitter can act like a USB drive. Managing models, configuration, icons, and themes is as easy as copying a file...No more need to use the Walkera DfuSe tool.
  • Fully configurable themes including bitmaps, fonts, and colors
  • Flexible transmitter configuration. Support up-to 12 channels on a Devo8; remap any switches or buttons to any purpose
  • All text is localized. Available translations for Hungarian, German, French, and Russian. Adding a new translation is as easy as editing a text file, and copying it to the transmitter.
Per chi fosse interessato a provarlo/contribuire allo sviluppo il sito del progetto è questo: Home.
Hanno anche prodotto un emulatore dell'interfaccia per PC, in modo da poterne valutare le caratteristiche di programmabilità.
Ciao.
AGEM Genovamodel.it
eriskio non è collegato   Rispondi citando
problema con radio devention 7 walkera filpesp Radiocomandi 16 08 marzo 12 15:25
E' possibile caricare un firmware per AUTO su una radio con più di 4 canali? henry7612 Radiocomandi 0 10 agosto 09 18:15
Tutti gli orari sono GMT +2. Adesso sono le 08:28.
