| | #1 (permalink) Top |
| User Data registr.: 16-10-2002 Residenza: Roma
| Nuova Turnigy 9XR
Ciao a tutti, ormai dovrebbe mancare molto poco all'arrivo di quets anuova Radio. Qui ricopio alcune info abbastanza attendibili The 9XR is designed and built completely in-house (my back pocket reminds me of this every day). It will use the atmega chip and can be flashed with your existing customised software. In fact, it comes standard with a similar rom to one you have mentioned. We wont be sending out eval units because we have done alot of testing in house already and its unfair to make customers wait for further evaluations. ----------------------------------------------------------------------------------------- All our CE certs are genuine from Genuine testing companies. Unfortunately competitors like to contest those certs by retesting and making comments to undermine their legitimacy. Just to keep the critics quiet we will be using TUV to test. ------------------------------------------------------------------------------------------ The 9XR has a pin-out in the battery compartment for easier flashing without needing to unscrew the case. ------------------------------------------------------------------------------------------ Backlight is standard Has inbuilt and module based antenna system Button config makes sense Spare parts avail from the start Switch and pot quality far better than previous version. ------------------------------------------------------------------------------------------ The 9XR will be $50.00 and targeted at the standard user that likes flying, not fiddling with his radio or looking for a shady spot to see his LCD. I like that radio and we're working on something similar (android based) but it wont have the takeup that the 9XR does. ------------------------------------------------------------------------------------------ [Q]Would be good if you could make them already flashed with the frsky 2.4 telementry already installed [A]We're working with them on a module for the 9XR. ------------------------------------------------------------------------------------------ No sliders, darn! I guess we've got an addition for v2 already. ------------------------------------------------------------------------------------------ By Hobbyking Admin module based with inbuilt 2.4 antenna plus options for FASST, DSMX & long range 433mhz plus it looks & feels much nicer. By HK Twitter In breve ho copiato tutto quello che hanno detto gli "interni" di HK, quindi non semplici rumors (almeno spero )Ciao Ale |
| | #2 (permalink) Top |
| User |
grazie Robby anche perchè "è un lavoro sporco ma qualcuno doveva pur farlo!" ( intendo quello di aprire un thread per la nuova radio )e soprattutto stavo pensando... ma gli sviluppatori come Romoloman, Erazz, Bertrand, Mike e gli altri... che penseranno di tutto ciò? nel senso: 1) "fantastico finalmente hanno capito che i cinesi non sanno fare FW ma lo facciamo noi, si occupassero di darci una piattaforma seria e già pronta!" 2) "anvedi sti fi** de na ******a manco hanno detto grazie che gl'avemo fatto fà i soldi! ![]() "Per la data di uscita girovagando si "parlava" (chiacchere poco fondate") di date da giugno a fine anno... ![]() ovviamente se avete altre info inerenti postate e citate la fonte! buona attesa! |
| | #3 (permalink) Top | |
| User Data registr.: 06-09-2008
![]() Credo che alla fine HK stia realizzando un clone plus della FlySky e che perciò risulterà arrivata tardi se davvero accadrà quello che immagino stiano facendo in casa Frsky ![]() Vedete di non morire prima così, magari, vedremo assieme come va a finire ...
__________________ "If flying were the language of man, soaring would be its poetry." | |
| | #4 (permalink) Top |
| User |
Alè è arivato l'gufo! ![]() ![]() No a parte gli scherzi effettivamente come dice LONGFLYER i sequel non vengono sempre bene, soprattutto con una "concorrenza" come Frsky che oltre ad essere economica e anche fortemente competente! Ma restiamo a vedere... (tanto già ho deciso di montare sulla t9x la mainboard Ersky9x, quindi dubito che la nuova uscente possa competere con quella... forse per gli stick... ma stiamo provvedendo...) |
| | #6 (permalink) Top |
| UserPlus Data registr.: 27-05-2004
di certo se costerà 50$, non sarà di sicuro un flop, anzi... ricordiamoci che la 9x è stata un successo commerciale anche prima delle fw modificate, con il suo fw originale tremendo. Se sono furbi, e sapranno dire "grazie" (ci sono 1000 modi per farlo) alla comunità di sviluppatori, non potrà che essere un super successo |
| | #7 (permalink) Top | |
Flop inteso nel senso che potrebbe non venderne quante se ne è prospettata di fare e, riguardo le comunità software, non ci metterei la mano sul fuoco che queste poi non si spostino esclusivamente su chi gli darà maggior man forte ed in questo FrSky ne ha davvero per tutti ... Poi, come dire: chi vivrà vedrà!
| | #8 (permalink) Top |
| Moderatore |
dite quello che volete ma queste radio valgono niente di più di quello che costano! Certo la potenzialità di un software opensources su una radio è impagabile, ma per tutto il resto vale quello che costa.
__________________ ----------------------------------------------------------------------- Il nuovo forum riservato ai Multirotori è ONLINE... >>> https://www.dronerc.it/forum/ <<< Pack suoni completo con varie voci e per tutte le versioni di opentx. |
| | #9 (permalink) Top | |
Riguardo Frsky quel che so sono solo rumors ma 2+2 sappiamo tutti quanto fa ed oggi, se vuoi campare, è bene che costruisci una Tua radio giacchè tutte le nuove non hanno più modulo intercambiabile e non si può vivere solo di rx clone. Aggiungi poi una sapiente capacità di produzione e voglia di fare, nonchè apertura vera verso le comunità open-source ed il SE lascia il posto solo al QUANDO ...
| | #10 (permalink) Top |
| User |
Beh il capo è australiano.. Ed è anche parecchio partecipe nell'azienda, mah... Inviato dal mio X10mini usando Tapatalk
__________________ A boy walks in to a hobby store... He says to the the shopkeeper, "When I grow up I want to be a R/C pilot." Shopkeeper says, "Nope, you can't do both." |
| Bookmarks |
| Strumenti discussione | |
| Visualizzazione | |
| Collegare Turnigy 2650mAh a Turnigy 9X | FabioPE | Batterie e Caricabatterie | 16 | 25 gennaio 13 17:22 |
| Adattatore per caricare Turnigy 2650mAh Tx Pack con Turnigy Accucel-6 | FabioPE | Batterie e Caricabatterie | 19 | 04 febbraio 12 12:56 |
| turnigy | posee93 | Compro | 0 | 04 dicembre 11 17:16 |
