Nuova Turnigy 9XR - Pagina 107 - BaroneRosso.it - Forum Modellismo
Vecchio 16 aprile 12, 22:06   #1 (permalink)  Top
L'avatar di Robby Naish
Data registr.: 16-10-2002
Nuova Turnigy 9XR
Ciao a tutti,
ormai dovrebbe mancare molto poco all'arrivo di quets anuova Radio.
Qui ricopio alcune info abbastanza attendibili
The 9XR is designed and built completely in-house (my back pocket reminds me of this every day).
It will use the atmega chip and can be flashed with your existing customised software. In fact, it comes standard with a similar rom to one you have mentioned.
We wont be sending out eval units because we have done alot of testing in house already and its unfair to make customers wait for further evaluations.
All our CE certs are genuine from Genuine testing companies.
Unfortunately competitors like to contest those certs by retesting and making comments to undermine their legitimacy.
Just to keep the critics quiet we will be using TUV to test.
The 9XR has a pin-out in the battery compartment for easier flashing without needing to unscrew the case.
Backlight is standard
Has inbuilt and module based antenna system
Button config makes sense
Spare parts avail from the start
Switch and pot quality far better than previous version.
The 9XR will be $50.00 and targeted at the standard user that likes flying, not fiddling with his radio or looking for a shady spot to see his LCD.
I like that radio and we're working on something similar (android based) but it wont have the takeup that the 9XR does.
[Q]Would be good if you could make them already flashed with the frsky 2.4 telementry already installed
[A]We're working with them on a module for the 9XR
No sliders, darn!
I guess we've got an addition for v2 already.
By Hobbyking Admin
module based with inbuilt 2.4 antenna plus options for FASST, DSMX & long range 433mhz plus it looks & feels much nicer.
By HK Twitter
In breve ho copiato tutto quello che hanno detto gli "interni" di HK, quindi non semplici rumors (almeno spero )
Ale
Robby Naish non è collegato   Rispondi citando
Modalità elencata Modalità elencata
Collegare Turnigy 2650mAh a Turnigy 9X FabioPE Batterie e Caricabatterie 16 25 gennaio 13 16:22
Adattatore per caricare Turnigy 2650mAh Tx Pack con Turnigy Accucel-6 FabioPE Batterie e Caricabatterie 19 04 febbraio 12 11:56
turnigy posee93 Compro 0 04 dicembre 11 16:16
Tutti gli orari sono GMT +2. Adesso sono le 21:31.
