![]() | #1281 (permalink) Top | |
User Data registr.: 28-01-2002 Residenza: Val Curone (AL)
Ciao, le riceventi DSM2 con le quali stai avendo questi problemi sono originali Spektrum o compatibili? Ciao, Paolo. ![]()
__________________ Keep it light fly it right! ![]() | |
![]() | #1283 (permalink) Top |
User Data registr.: 05-01-2008 Residenza: Bologna
AGGIORNAMENTO 1.08 AirWare: New Features & Improvements The pre-flight checklist shows the name of the model on power-up. This allows you to verify the right model is being started without having to go through the complete list first. New trainer mode FPV added to allow head tracker inputs to be mapped to any channel, with adjustable scaling and reversing. This mode enables easy mapping of head tracker channels to receiver ports, while not affecting flight controls. Add support for Flight Pack Capacity (mAh) and Receiver Pack Capacity (mAh) sensors Add support for ESC sensor X-Plus channels are now able to be configured to generate warnings in 18- channel systems, in addition to the normal channels previously available On the Model Copy utility, you are now able to select the Source model for copying. It is no longer necessary to use Model Select first. When setting up a timer in a speaking radio, a 20-second alert is now available. You can now use the wiggle function to select analog inputs when entering a switch option. Just move the appropriate switch or stick or slider and it will select it automatically. Corrections .AS3X Gains telemetry screen does not show when configured to not show. Sailplane AIL>RUD mix field Sub Switch is now exported properly. Heli gyro trim values are aligned properly for all flight modes Heli trim setup screen operates properly in tray radios Digital Switch Setup does not allow selection of Flight Mode switch if the Flight Mode system is not configured. Trainer inputs are not allowed to exceed Absolute Travel settings. Corrected delay between tx voltage status announcements Telemetry screens now refer to Turbine rather than JetCat. Telemetry screens with trim displays now properly indicate centered status the same as the main screen. Sequencers and Gyros will now properly release a channel when being turned off. Note that you must completely disable the gyro for the old channel name and function to be fully restored. That is, you must set the Gain input (first screen) to INH, click NEXT, then set the mix to INH > INH, then the switch to INH. Only then will the channel be completely and properly freed up. For sequencers you only need to set the output channel to INH.
__________________ ....diffidate sempre dagli aeromodellisti da tastiera http://www.aeromodellisti-aecibologna.it/ |
![]() | #1285 (permalink) Top |
User Data registr.: 24-04-2008 Residenza: Cesena
Hai dimenticato la meglio!!!! ![]() ![]()
__________________ SPEKTRUM DX10T | Raptor 60 | SAITO FA-56 , O.S. 56FS-Alpha , O.s. FS-30s , West Eurotec .52 v1 | Great Planes SuperSportster 40 | TRAXXAS REVO 3.3|GP Combat CORSAIR| O.S. GF40 |
![]() | #1287 (permalink) Top |
allora ti manca la meglio! ![]() ![]() fine OT
Modulo Spektrum, rx spektrum AR6300, case spektrum | Bart76 | Merc. Motori ed Elettronica | 12 | 19 marzo 13 19:22 |
