14 settembre 11, 22:14 | #21 (permalink) Top | |
User Data registr.: 25-05-2007 Residenza: Ancona
__________________ Fly Low! | |
15 settembre 11, 00:05 | #22 (permalink) Top |
User Data registr.: 05-09-2005 Residenza: Lago d'Iseo
| Riporto la procedura di Binding, presa dal manuale: 7.2.2 Binding a Dual 2.4 Dual FHSS micro series receiver to the transmitter module You can bind as many receivers as are required to each transmitter module/transmitter as each transmitter module transmits an individual code, of which there are millions, to the receiver which must store the code before it will become live. This makes it impossible for more than one weatronic receiver to react to a weatronic transmitter module at the same time. Before a weatronic transmitter module and a weatronic Dual 2.4 Dual FHSS series receiver can communicate with each other they must be bonded together (Quick Binding). During this binding process the receiver will receive and store the code transmitted by the transmitter module and the transmitter module will receive and store the receivers serial number. Once this process is complete, the receiver will only react to signals transmitted by that transmitter module. The process for binding a receiver to a transmitter module is very simple and should be carried out as follows: During this process, you must ensure that the transmitter module and the receiver are a minimum of half a metre (50 cms) apart. Two buttons are fitted to the transmitter module, labelled Button 1 and Button 2. These buttons become active a few seconds after switching on the transmitter and this will be signalled by all 3 LEDs flashing. Once the transmitter is switched on and the module has conducted its self-test the red LED will flash as the module is not receiving a return signal and the green LED will omit a short double flash indicating that it is not bonded. The transmitter module is now ready for bonding. Begin the bonding process by pressing Button 2 for at least 5 seconds, at which point the green LED will begin to flash rhythmically. The Dual 2.4 Dual FHSS micro receiver should now be switched on or power connected. Once the receiver is switched on the red jumper should be fitted to the pins on the side of the receiver opposite the servo sockets. The jumper can be fitted either to the upper and middle or to the lower and middle pins and binding will begin after approximately 5 seconds. Once the transmitter module and the receiver are bonded together the green STATUS LED will illuminate solidly on both components. The red jumper may now be removed from the receiver. ************************************************** ******************* Non credo sia possibile una tale procedura durante il volo!!! |
15 settembre 11, 00:21 | #23 (permalink) Top | |
15 settembre 11, 00:48 | #24 (permalink) Top |
UserPlus Data registr.: 03-09-2008 Residenza: Jesolo - VE
| forse si è dimenticato di toglierlo.........
__________________ Massimo Bison https://imgur.com/a/rZMlsqz El sapiente sa poco, l'ignorante el sa massa, ma el mona sa tuto |
16 settembre 11, 12:49 | #25 (permalink) Top |
User Data registr.: 09-12-2004 Residenza: Castelfranco Vto.
Probabilmente ha tentato un quick-binding Riguardo al Binding le istruzioni riportano che il ponticello và messo indifferentemente sopra o sotto non ricordo esettamente se sopra o sotto, ma tutte le mie rx hanno funzionato su una sola posizione nell'altra non era possibile fare il binding Daniele
__________________ Daniele Polo il mio sito http://danielepolo.jimdo.com e dove volo www.rossanomodel.com |
16 settembre 11, 23:33 | #27 (permalink) Top | |
Ergo, puoi tentare di fare quel che ti pare, ma i tasti mentre stai volando non funzionano. Sarebbe invece interessante sapere cosa riporta esattamente il file di log, ma dubito sia stato consultato, anzi molti non mettono neanche la micro SD sul modulo, tanto a che serve?
18 settembre 11, 11:56 | #28 (permalink) Top |
Qualcuno sa come funziona il modulo GPS di Weatronic? Vorrei sapere se invia dati alla SD Card inserita nella TX e a che intervalli. Esiste un manuale consultabile/scaricabile on-line? Grazie a tutti. |
18 settembre 11, 21:19 | #29 (permalink) Top |
Non ho il modulo gps nè riceventi con gps integrato, ma credo che i dati vengano comunque inviati sulla SD della TX, in quanto il software gigacontrol che rerve per leggere la SD ha anche una sezione riservata al GPS con grafici sia in 2D che in 3D. I dati vengono inviati ogni seecondo ed i grafici possono essere interfacciati con google earth, in modo di avere il tarcciato di volo proiettato sul terreno.
19 settembre 11, 11:03 | #30 (permalink) Top |
User Data registr.: 12-08-2006
" The weatronic® GPS module on board is continuously sending all measured data concerning route, speed, position as well as altitude to the weatronic® 2.4 Dual FHSS transmitter module. There you can freely define via GigaControl how often and which data should be emitted in your headphones. The device, for example, is able to emit speed and/or altitude over ground or the current position in spoken language. Moreover the data is logged on the integrated micro SD-memory card, comparable to the mode of operation of a flight data recorder in aviation. With the aid of the weatronic® software GigaControl, the connected GPS-sensor can be set up. " weatronic GmbH - RC components - The weatronic® GPS module bel giocattolino questo sistema
__________________ -- michele |
Moduli Weatronic | gianmario | Radiocomandi | 6 | 08 novembre 10 12:59 |
sistema weatronic | sergior90 | Radiocomandi | 6 | 24 ottobre 10 18:02 |
Differenza tra Sanwa Exzes Plus fhss-3 e fhss-2 | 020285leo | Radiocomandi | 0 | 21 maggio 10 15:32 |
weatronic | GiorgioTNT | Radiocomandi | 2 | 25 febbraio 10 22:33 |
Graupner Weatronic | 3mendo | Radiocomandi | 1 | 08 ottobre 09 11:51 |
