26 ottobre 10, 20:01 | #383 (permalink) Top | |
UserPlus | Citazione:
Per i prezzi non saprei, ma comunque la prenderei in Italia. Io l'ho presa da Alex, che come prezzo mi sembra allineato ad altri. P.S. E' da diverse ore che non riesco ad entrare nella pagina di supporto personalizzata. Che sia in arrivo il firmware 1.04? | |
28 ottobre 10, 18:47 | #385 (permalink) Top | |
Finalmente il display bello luccicante | |
29 ottobre 10, 23:45 | #386 (permalink) Top |
UserPlus | Firmware 1.04
E' stato rilasciato. Questo il changelog: Version 1.04 Software Upgrades Trim Center Pause When adjusting the trims through center, the pause was lengthened to allow the center position to be more easily accessed. Knob Center Tone When adjusting the knob, it generates a center trim tone as it rotates through center. LiPo Battery Verification Attempting to change the battery type in the Extra Settings screen from NiMH to LiPo will not be allowed until a LiPo battery is installed. This prevents the user from mistakenly selecting the LiPo battery voltage cutoff with a NiMh battery installed. Frame Rate Defaults to 22ms- The Frame Rate now defaults to 22ms rather than 11ms. This prevents analog servo compatibility issues in the default mode. AirWare Auto-Update To guard against inadvertently downgrading the radios AirWare, after installing version 1.04 or higher the system will rename the update file to prevent it from auto-loading in the future. Startup Screen The startup is changed so that no inaccurate No RF Link warning is displayed. Software Corrections Heli Mode Trainer Button if the Trainer button was assigned to a channel in the Switch Select screen, the channel was inactive. Flap Trim When a Flaperon wing type was selected and the right or left trimmer was assigned to flap trim, the trim was mixed as ailerons instead of flaps. It was also not possible to deactivate flap trim once selected. Acro Throttle Curve Pressing the CLEAR button could allow the displayed throttle curve to not match the values entered numerically. German Timer The prompts for the German-mode throttle-based timer controls were renamed so as to be more intuitive. Throttle = Gasstellung Throttle 1-time = Motorstart Throttle Out = Motorlaufzeit |
30 ottobre 10, 00:19 | #388 (permalink) Top |
UserPlus | Programming/Setups
Hanno cominciato a rilasciare i setup standard per alcuni modelli di elicottero ed alcuni aerei. Gli elicotteri sono i T-rex 450PRO, 550e FBL, 700e, 700e FBL e Avant Aurora-E. Gli aerei sono i Park Zone Corsair e Habu. Si possono scaricare dalla community alla tab citata nel titolo del post. |
30 ottobre 10, 17:26 | #389 (permalink) Top |
User Data registr.: 20-01-2008 Residenza: MI | PV | AC LODI: 220 feet - N45.13.1 E009.28.1
Immagini: 45 |
mi sembra ottimo il sistema di update! se poi la comunity rilascia il set per qualche modello ben venga per provarlo Il sistema mi sembra ottimo e "real time" complimenti.... feedback +++++ ps: e con questa siamo alla III release
__________________ mini heli vari |TREX 450: AGUSTA109| 450 PRO|TREX 500: MD500 + AS350 + 2 DFC SPEED |T-REX 600E AGUSTA 109|T-REX 600 DFC!MINITITAN MD500| VARIO JET RANGER DJI WKH |GOBLIN 700 KSE BD3SX| E-FLITE VTOL!DJI F550-NAZA|SKY STRIDER| T14SG | |
30 ottobre 10, 17:43 | #390 (permalink) Top |
User Data registr.: 11-07-2006 Residenza: Verona
si e' una bella cosa la possibilita' di scambiare i modelli! la modifica ai 22ms ci voleva, era troppo pericoloso. mancherebbe ancora un programma specifico per alianti e gli allarmi con diverse tonalita'. aspettiamo, anche se con questo aggiornamento hanno fatto molte modifiche. |
ultima nata spektrum: Dx8 | greg89 | Radiocomandi | 1 | 08 febbraio 10 22:48 |
