![]() | #3101 (permalink) Top |
User Data registr.: 19-03-2007 Residenza: lecco
Ma io ho provato col tuttala ed e andato tutto bene led fisso sia su rcv che sat. Chi la detto mi spiegava che cosi il binding e immediato e piu sicuro provare ho provato e andava bene pero io qui in montagna ho solo rcv orange con l originale provero a casa...gianni
![]() | #3102 (permalink) Top |
User |
È disponibile AirWare 2.05 😊 Version 2.05 10 August 2012 Software Features • Added support for GPS and High Current telemetry sensors. • Enabled up to 32-pole motors for the brushless RPM sensor. • Enabled SD telemetry log file • Enabled ability to configure inactivity timer • Enabled backlight configurability (Auto/On/Off) • Enabled dimming control of the orange Spektrum LED for night flying • Adjusted vibe motor RPM to be less aggressive Software Corrections • Fixed bug that could reset the radio when scrolling through Mix options. • Corrected L/R trimmer ‘forgetting’ assignment after power cycle. • Improved translations in French and Italian screens. • Corrected export of flap configuration. • Corrected over-travel of flaps that could result in reversed operation at extreme deployments. • Corrected switch change on Acro throttle cut screen when going from the initial switch selection to the edit page. • Corrected timer to work properly in Throttle Out mode when using reversed throttle channel. • Corrected end-point adjustability when Trainer is used as an input to a channel. • Corrected trainer normal Master mode so that it doesn’t modify controls from the slave. In previous versions it could reverse channels vs. what was expected. NOTE: This change affects sub-trim and travel of existing models and ones you will import. You may need to adjust sub-trims and travel on all control surfaces in both airplanes and helicopters. Ciao Egidio
__________________ "Quanto più ci innalziamo, tanto più piccoli sembriamo a quelli che non possono volare" (F. N.) |
![]() | #3103 (permalink) Top | |
UserPlus | Citazione:
![]() | #3104 (permalink) Top |
User |
Da me non compare nessun aggiornamento. ![]() Non digerendo bene l'inglese, se qualcuno volesse tradurre ne saremmo contenti. Come ultima domanda, ho capito bene che dopo questo aggiornamento si deve risettare tutti i modelli? Buone ferie a tutti, anche se io ancora sto lavorando. ![]() |
![]() | #3105 (permalink) Top |
User Data registr.: 19-01-2007 Residenza: Dintorni di mestre (DINTORNI)
anche da me non compare l'aggiornamento!!!! Comunque finalmente hanno inserito il sensore di corrente e il log della telemetria su SD... Per chi non sà l'inglese: AGGIUNTE: Aggiunto supporto per il GPS e per il sensore di corrente Aggiunta la possibilità di usare motori fino a 32 poli con il sensore di giri per motori brushless Aggiunto il salvataggio del Log della telemetria su SD Aggiunta possibilità di modificare il tempo di inattività Aggiunta possibilità di accendere e spegnere la luce dello schermo (Auto, ON, OFF) Aggiunto il controllo di luminosità del simbolo arancione spektrum per il volo notturno Possibilità di modificare la vibrazione CORREZZIONI: Sistemato il bug del reset della radio mentre si scorre nel menù MIX Corretti i trimmer L/R che perdono l'assegnamento dopo lo spegnimento Migliorato la traduzione in Francese e Italiano Corretto l'esportazione della configurazione dei FLAP Corretto l'over-corsa dei flap che potevano portare all'operazione inversa in caso di estrema corsa Corretto il cambio di switch del Cut Off del gas quando si è nel menu iniziale della selezione degli switch Corretto il timer che lavora con il GAS quando lo si usa con il gas invertito Corretto la variazione della corsa massima quando la porta trainer viene usato come input per un canale Corretto la modalità Trainer Master in modo che non modifica più i controlli dallo Slave NOTA: Queste modifiche alterano i Sub-Trim e le corse dei modelli esistenti e di quelli importati tramite SD... è necessario sistemare i Sub-Trim e le corse di ogni comando sia sugli elicotteri che sugli aerei!!! |
![]() | #3107 (permalink) Top |
User Data registr.: 19-01-2005 Residenza: 33170 e dintorni
mha! egi sei sicuro? per me ce' l'aggiornamento e x la DX10 e la DX18 non la DX8.
__________________ Trattiamo bene la terra su cui viviamo: essa non ci è stata donata dai nostri padri, ma ci è stata prestata dai nostri figli |
![]() | #3108 (permalink) Top | |
User Data registr.: 27-05-2009 Residenza: Piacenza
Ho provato a cercare in giro e in effetti di AirWare 2.05 non ne parla ancora quasi nessuno. Sarà stato appena sfornato! Inviato con Tapatalk | |
![]() | #3109 (permalink) Top |
User |
Tranquilli 😉 Se già non lo avete su Spektrum Community, è questione di molto poco. P.S: non chiedetemi di più 😷
__________________ "Quanto più ci innalziamo, tanto più piccoli sembriamo a quelli che non possono volare" (F. N.) Ultima modifica di egicar : 11 agosto 12 alle ore 14:33 |
ultima nata spektrum: Dx8 | greg89 | Radiocomandi | 1 | 08 febbraio 10 22:48 |
