Vecchio 10 dicembre 11, 09:22   #2601 (permalink)  Top
L'avatar di baracca1
Data registr.: 01-08-2008
Residenza: TORINO
Talking Lo sapete ?
Beastx+ Rx 7 ch !
In pratica la rx viene a costare circa 35 euro !
Horizon Spektrum AR7200BX 7-channel DSM RX
Spektrum (SPMAR7200BX) AR7200BX 7-channel DSM™ receiver with integrated flybarless control system
Overview
Going flybarless is a great way to unleash the animal in any 3D helicopter. By eliminating the mechanical complexity and weight of a flybar, you get faster MEMS flybarless stabilisation system is the most powerful flybarless technology available today. Its unrivaled responsiveness and precision completely transforms any 3D flying experience.
Now BeastX technology can be added to most any 250- to .90-size helicopter, while saving space and reducing flying weight at the same time, with the Spektrum™ AR7200BX. This groundbreaking innovation combines a 7-channel DSMX™ receiver with the BeastX system into a single, compact unit that weighs a minimalist 18 grams. It also has an incredibly small footprint, so it’s easy to find mounting space on even the most crowded heli frames.
Perhaps best of all is how simple the AR7200BX is to set up. Because BeastX flybarless technology doesn’t require a special interface to make adjustments ,It can easily be tuned to a heli’s response at the field using just the AR7200BX unit and a DSM2/DSMX computer transmitter with heli programming.
Specification:
• Application: 250- to 800-size helis
• Channels: 7
• Receivers: 1 with support for additional remote receiver
• Modulation: DSM2/DSMX
• Band: 2.4GHz
• Dimensions: 36.0 x 29.0 x 13.0mm (1.30 x 1.10 x 0.51 in) (LxWxH)
• Weight: 0.63 oz (18.0g)
• Input Voltage: 3.5-8.5V
• Resolution: 2048
• Frame Rate: 11ms
• Dual Antenna Length: 110mm/40mm
• Range: Full
Features
• Data/Telemetry Compatible:Works with Spektrum Telemetry Transmitter systems and flight log information.
• Integrated 3-Axis MEMS GYRO Control System: 3-axis gyro and stabilization provides maximum precision, stability, and control for advanced
• 3D manoeuvres. Combined with Spektrum DSMX and DSM2 Technology.
• 2S Li-Po Capable: Variety of power sources available
• 7CH Receiver: Integrated Spektrum 7CH Receiver, capable of both park flyer and full range applications
• Built-in swashplate mixer: Mechanical, 90, 120, 140 degree
• Compact Footprint : Easy installation in 250 - 700 size electric and Nitro Helicopters
• Large Voltage Range Input: Operating voltage: 3.5 - 8.5V
• PC Programmable : Allows for updating firmware, and advanced settings via USB.
• Selectable Servo Centre Pulse Width: Tail Servo: 1.52ms, 0.96ms, 0.76ms
• Selectable Servo Pulse Rate: Tail: 65Hz, 270Hz, 330Hz Swashplate 65Hz, 120Hz, 200Hz
• User Friendly Setup and Programming: No PC required, allows for field adjustability.
baracca1 - MCX2 - PROTOS 700 MAX V2 - Logo550 VBar Carbon - DEVIL 380 - ESACOTTERO CRIUS AIO V2 - EACHINE E010 + H8 - SPEKTRUM DX8 - Ferrovia MARKLIN H0
baracca1 non è collegato   Rispondi citando
Vecchio 10 dicembre 11, 17:55   #2602 (permalink)  Top
L'avatar di BBC25185
Data registr.: 19-01-2007
Residenza: Dintorni di mestre (DINTORNI)
Bella...
Sono andato a vedere quanto costava perchè ci avevo fatto un pensierino...
Intanto esce a gennaio del prossimo anno (cioè fra 2 mesi)
Costo: 230 Dollari...
Inviato dal mio Transformer TF101 usando Tapatalk
BBC25185 non è collegato   Rispondi citando
Vecchio 10 dicembre 11, 20:57   #2603 (permalink)  Top
L'avatar di LDEly
Data registr.: 27-11-2011
Il prezzo non è male contando i prezzi singoli delle rx ar8000 e 7100, poi è anche comodo avere la rx e la centralina del flybarless uniche
LDEly non è collegato   Rispondi citando
Vecchio 10 dicembre 11, 23:19   #2604 (permalink)  Top
Alexvan
Guest
Messaggi: n/a
Si, e può montare anche un satellite supplementare. Pare un buon prodotto.
  Rispondi citando
Vecchio 15 dicembre 11, 08:49   #2605 (permalink)  Top
L'avatar di lino.
Data registr.: 11-02-2010
Residenza: roma
2.04 La radio si spegne sui mix
Buongiorno
Ieri sera ho aggiornato la mia DX8 con la nuova versione 2.04, purtroppo non va....
ho lo stesso problema dell'amico ballariballu cioè:
entrando nel menu "Mixing" pio nel Mix 1 ed evidenziando la scritta "MIX1" in modo da poter selezionare il mix da modificare, ruotando il roller avanti e indietro qundo passo dal mix ALE-DIR al MIX1 la radio si spegne e subito si riaccende.
Adesso manderò una e-mail alaa spektrum e vediamo un po'.
Buona giornata
Lino
lino. non è collegato   Rispondi citando
Vecchio 16 dicembre 11, 09:04   #2606 (permalink)  Top
L'avatar di lino.
Residenza: roma
hde-service hde-service@horizonhobby.com
22:22 (9 ore fa)
a me
Ecco l'e-mail di risposta della SPEKTRUM.
Yes, it’s one of the items noted as fixed in the DX7s version 1.01 code. It will be in the next DX8 release.
Horizon Hobby GmbH
Stefan Wilhelmi
Leiter Technischer Service / service manager
Fon: +49(0)4121-2655 300
Fax: +49(0)4121-2655 111
Mail: s.wilhelmi@horizonhobby.de
Web: Horizon Hobby Modellsport - Ferngesteuerte Flugzeuge, Hubschrauber, Autos und Boote
Vecchio 16 dicembre 11, 11:18   #2607 (permalink)  Top
L'avatar di moscaleras
Data registr.: 18-10-2008
Residenza: palermo
Originalmente inviato da lino. Visualizza messaggio
22:22 (9 ore fa)
a me
Horizon Hobby GmbH
Stefan Wilhelmi
Traduci perfavore, che non ho il traduttore nel nokia. a me avevano risposto che nessuno aveva questo problema,e quindi il difetto me lo dovevo tenere.
moscaleras non è collegato   Rispondi citando
Vecchio 16 dicembre 11, 11:32   #2608 (permalink)  Top
L'avatar di LONGFLYER
Data registr.: 06-09-2008
Originalmente inviato da moscaleras Visualizza messaggio
Pare invece che finalmente lo abbiano riconosciuto: scrivono di averlo già messo a posto nella sorella più piccola DX7s e che faranno la stessa cosa nella prossima release software per DX8.
"If flying were the language of man,
soaring would be its poetry."
Ultima modifica di LONGFLYER : 16 dicembre 11 alle ore 11:36
LONGFLYER non è collegato   Rispondi citando
Vecchio 16 dicembre 11, 17:27   #2609 (permalink)  Top
L'avatar di dex1
Data registr.: 19-01-2005
Residenza: 33170 e dintorni
abbiamo il traduttore personale.
evvai!
ps.chi e' iscritto alla community di spektrum,queste info arrivano
direttamente,a me e' arrivata il 14.
non la ho riportata perche' pensavo che la maggior parte di chi frequenta
questa discussione lo sia,iscritto intendo.
community.spektrumrc
Originalmente inviato da LONGFLYER Visualizza messaggio
dex1 non è collegato   Rispondi citando
Vecchio 16 dicembre 11, 18:47   #2610 (permalink)  Top
Originalmente inviato da dex1 Visualizza messaggio
evvai!
Evvai! Ti potevi svegliare anche prima: qui è da molto tempo che si parla del problema, c'è anche chi ha fatto un video e poi postato al forum ...
Evidentemente, non tutti sono iscritti e/o non leggono bene l'inglese.
Ultima modifica di LONGFLYER : 16 dicembre 11 alle ore 18:56
ultima nata spektrum: Dx8 greg89 Radiocomandi 1 08 febbraio 10 23:48
Tutti gli orari sono GMT +2. Adesso sono le 15:46.
