Vecchio 30 luglio 11, 10:06   #2131 (permalink)  Top
L'avatar di rillo75
Data registr.: 05-01-2008
Residenza: Bologna
...c'erto che ce nè di gente che la notte dorme poco
In ogni caso, eccovi le modifiche introdotte:
DX8 Spektrum™ AirWare™
Change Log
Version 2.03
Software Features
• Changed Monitor screen to improve perceptibility of changes in stick and trim resolution.
• Added new wing type Elevon B. This mode is used if control horn or servo positions don’t allow correct throw directions. Eliminates need to swap elevator and aileron servo leads. Also required with some trainer systems like the DX6i.
• When editing the timer configuration, any changes will cause the timer to be reset.
• After reversing the throttle channel, the screen changes to show a reminder to rebind at low throttle for safety.
• To improve the ease of adjusting travel limits for complex servo functions (swash, V-tail, etc), the Servo Setup screens now are tracking servo outputs directly.
• To avoid confusion when binding, we changed the Bind screen to show actual 11ms/22ms bind info instead of what the receiver is capable of doing.
• Enabled adjustment of the telemetry receiver voltage display bar. Adjusting the low and high setpoints (high is NOT an alarm) you are adjusting the scaling of the bar graph for Rx Voltage.
• When importing a model, a confirmation screen now appears to warn about possibility over-writing the wrong model.
• Changed telemetry menu and capabilities to enable access to future sensors.
• Users are now able to calibrate the knob and both stick in both axes. This is done by selecting NEXT several times from the System Setup menu. Move the sticks in a “+” format, NOT in an X or O. It is important not to push the sticks to the corners.
Software Corrections
• Flap/Elevator Smoothness – Elevator compensation travel was not smooth when there was significant trim on the elevator channel.
• Flap Overdrive – Initial flap movement could sometimes cause flaps to jump to one extreme of travel before moving to correct setting.
• Telemetry - Changed scaling for telemetry alarms Altitude & Airspeed. Fixed ‘hidden status’ screens when using models created in older versions.
• Translations – Improve/Correct translation of some terms for German, Spanish and Italian modes, particularly on the Timer and Telemetry screens.
....diffidate sempre dagli aeromodellisti da tastiera
http://www.aeromodellisti-aecibologna.it/
Ultima modifica di rillo75 : 30 luglio 11 alle ore 10:15
rillo75 non è collegato   Rispondi citando
Vecchio 30 luglio 11, 11:09   #2132 (permalink)  Top
L'avatar di luigismith
Data registr.: 19-02-2010
Residenza: Taranto
Originalmente inviato da Horizon Hobby Visualizza messaggio
non essendo in sede da domani per circa 10 giorni invito chiunque abbia necessità di chiarimenti o assistenza a scrivermi in privato.
Beato lei che va in ferie. io, per colpa della dx8 non potrò andarci
luigismith non è collegato   Rispondi citando
Vecchio 30 luglio 11, 12:31   #2133 (permalink)  Top
Alexvan
Guest
Messaggi: n/a
Originalmente inviato da rillo75 Visualizza messaggio
Change Log
Version 2.03
Sembrano interessanti. Ma accettando di diventare beta tester non hai dovuto accettare un NDA per cui le informazioni inerenti le beta erano da ritenersi confidenziali?
  Rispondi citando
Vecchio 30 luglio 11, 12:34   #2134 (permalink)  Top
Moderatore
L'avatar di klamath
Data registr.: 20-09-2005
Residenza: ɐuƃoloq
Invia un messaggio via ICQ a klamath
Bene dopo lo provo, cmq io non m ricordo di essere beta tester, pero nel mio spazio su spektrum comunity posso scaricare le beta...
klamath non è collegato   Rispondi citando
Vecchio 30 luglio 11, 12:35   #2135 (permalink)  Top
L'avatar di rillo75
Residenza: Bologna
Originalmente inviato da Alexvan Visualizza messaggio
io non ho neppure la DX8
ma dato che come prodotto mi interessa sto seguendo varie discussioni e quindi ho riportato anche a voi quanto appreso altrove
Per il momento, non avendo la DX8 funzioni specifiche per alianti, non posso prenderla in considerazione anche se per tutto il resto (richiami a parte) non mi dispiacerebbe
Vecchio 30 luglio 11, 13:03   #2136 (permalink)  Top
Moderatore
L'avatar di klamath
Residenza: ɐuƃoloq
Curiosita su telemetria
Ciao a tutti,
ho una domanda sulla telemetria, ma l antenna ricevente sulla dx8 dove è?
Altro quesito sulla telemetria cè anche la voce velocita e altitudine ma per averli serve qualche sensore particolare o ce da attivare qualcosa sul tm100? In caso dei sensor sono gia in commercio?
Ultima modifica di klamath : 30 luglio 11 alle ore 13:07
Vecchio 30 luglio 11, 15:04   #2137 (permalink)  Top
Residenza: Taranto
Originalmente inviato da klamath Visualizza messaggio
cos'è il tm100?
Vecchio 30 luglio 11, 15:14   #2138 (permalink)  Top
L'avatar di rillo75
Residenza: Bologna
Originalmente inviato da luigismith Visualizza messaggio
cos'è il tm100?
mi sembra ovvio che intendesse dire TM1000??? non credi?
Vecchio 30 luglio 11, 19:14   #2139 (permalink)  Top
Residenza: Taranto
non mi sembra ovvio niente!
Vecchio 30 luglio 11, 21:36   #2140 (permalink)  Top
Moderatore
L'avatar di klamath
Residenza: ɐuƃoloq
si mi sono perso uno 0 per strada.
tm1000 o SPM9548 o Full Range Aircraft Telemetry Module
va bene cosi?
ultima nata spektrum: Dx8 greg89 Radiocomandi 1 08 febbraio 10 23:48
Tutti gli orari sono GMT +2. Adesso sono le 12:06.
