27 marzo 09, 18:24 | #11 (permalink) Top | |
User Data registr.: 20-09-2004 Residenza: Torino
A parte questo anche a me capita a volte che la RX non faccia il binding... di solito spengo tutto poi accendo la RX con l'interruttore del cavo binding (batteria RX carica mi raccomando!) mi sposto un pò dalla RX e accendo la TX con il tasto premuto... Lo spostarmi durante il binding allontanandomi un pò dalla RX mi ha aiutato anche quando era recalcitrante... Bye Andrea
__________________ Iscritto al gruppo "Volare su Tetti" di Rivoli (TO) | |
27 marzo 09, 18:40 | #12 (permalink) Top | |
User Data registr.: 16-01-2006 Residenza: San Giovanni del Dosso (MN)
27 marzo 09, 18:42 | #13 (permalink) Top |
User Data registr.: 05-01-2008 Residenza: Bologna
dai una letta quà: Binding Connection Explained e leggi questo: i've got a major problem with my brand new dx7.. when i first got it i did the binding procedure and everything worked perfectly for 2 days. i flew my trex around without any problems, everything worked perfectly.. then on the third day i took it out to the field and turned on the radio, but it wouldnt do anything - i gave stick inputs but no reaction from servos. the LED on the main receiver is solid, but the LED on the small rx just keeps flashing. i tried rebinding a million times, no luck. when i rebind, the main receiver's LED goes solid but again, the small rx's LED just keeps flashing. when i did this the first time it worked fine without any problems. i have tried everything loads of times, but no luck.. any ideas?? UPDATE: ive been playing around with it more and wanted to see what would happen if i unplug the secondary rx altogether. so i unplugged it and then did the binding with only the main receiver. LED goes solid as expected. now it gets wierd again. i turn on the radio, then turn on power to the rx (again, this is without the small rx). about 2 out of ten times it connects and the servos react to stick inputs. other 8 times they do nothing and do not respond. i guess i could just sit there plugging it in and out until it works. but can i even fly without the 2nd rx?? im only flying a trex heli so i dont need too much range..
__________________ ....diffidate sempre dagli aeromodellisti da tastiera http://www.aeromodellisti-aecibologna.it/ |
27 marzo 09, 22:06 | #14 (permalink) Top | |
User Data registr.: 27-03-2007
Comunque questa sera ho provato con le sue batterie RX caricate durante il pomeriggio e l'rx funziona ma adesso la satellite ha luce fissa e la principale lampeggia ma in modo più lento di quando fa il binding... | |
28 marzo 09, 02:39 | #15 (permalink) Top |
si ma hai letto il mio post e i miei link?
28 marzo 09, 10:56 | #17 (permalink) Top |
User | a me il mondo sorride co il sistema 2,4 ghz dei poveri...la corona DSSS, và che è una bomba, ieri traini al limite del visibile, che con un aliante da 4 metri e un trainatore da oltre 2 e un motore a benzina da 52 cc.....è oltre i 500 metri...mai un problema...ergo...ci si può divertire anche spendendo poco....
__________________ garbo@libero.it sù Skipe giuseppegarbo, volo da cane sciolto in montagna, a Chialamberto, dove ora abito, sù un prato di mia proprietà.. ....ASSAN........ |
28 marzo 09, 12:01 | #18 (permalink) Top | |
Giorgio vola anche per noi. Data registr.: 26-10-2006 Residenza: SARZANA
28 marzo 09, 12:32 | #19 (permalink) Top | |
User | Citazione:
__________________ Associazione Sportiva GRUPPO AEROMODELLISTICO VST - Volare su Tetti http://www.vst-aero.it - Per i poco intelligenti non indica 'i tetti', ma il Comune in cui ha sede il campo volo (Tetti Neirotti) che dista piu' di 750 mt. dalla pista. | |
28 marzo 09, 12:34 | #20 (permalink) Top |
User | non taccango...ma parsimonioso, d'altronde la mia modesta condizione di pensionato, la crisi che morde duro, mi impone di cercare soluzioni economiche...come quella di costruirmi da disegno, un modello da 220 cm di aa spendendo circa 90 di materiale rivestimento compreso...
Dx6i e Blade 400 binding | darkfener | Elimodellismo Motore Elettrico | 4 | 13 marzo 09 18:23 |
Ar7000 Binding A Polarita' Invertita - Dilemma | ciccioriccio82 | Radiocomandi | 2 | 22 gennaio 09 12:25 |
Binding - Governor | baracca1 | Radiocomandi | 0 | 30 novembre 08 09:02 |
Swash -governor - Binding -trex | baracca1 | Elimodellismo Principianti | 1 | 29 novembre 08 10:16 |
BINDING Spektrum DX6i | baracca1 | Radiocomandi | 5 | 22 novembre 08 15:52 |
