Vecchio 30 ottobre 08, 16:00   #1 (permalink)  Top
Usur
L'avatar di pipercubgiallo
Data registr.: 01-02-2007
Multiplex 2,4 ghz
MULTIPLEX on the subject of: 2.4 GHz
For quite a while now the subject of “2.4 Gigahertz” has been much discussed amongst all modellers and in
all the modelling media. Every day we are asked about our position, and we now wish to issue the following
statement:
New technology!?
Yes and no.
Yes, because previously this frequency band had no part to play in modelling, and the technology has only
started to make inroads in RC model sport relatively recently.
No, because this frequency band (ISM band = Industrial Scientific Medical) was designed for digital data
transmission, and is already in very widespread use (e.g. by WLAN, Bluetooth, cordless telephones, garage
door openers, etc.).
What advantages does 2.4 GHz offer us as modellers?
The advantages are very interesting, e.g.
- automatic channel selection
(i.e. no conventional manual channel selection required, frequency control unnecessary)
- short transmitter / receiver aerials
- telemetry applications (data transfer from model to transmitter)
- higher data transfer rates (many high-resolution control functions, high transmission speed)
- good rejection of typical interference sources encountered in modelling applications
(e.g. electric power systems, electrical “noise”, ignition interference)
What about the “legal” aspect?
On 14 May 2008 a meeting was held at the EUROPEAN COMMISSION TCAM, the participants being
representatives of the modelling industry and organisations from across Europe, the R-LAN industry and the
European monitoring authorities. The starting point was a drive on the part of the European R-LAN industry
aimed at banning model radio control systems from the 2.4 GHz band, together with certain other
applications. The outcome of the meeting was that there would be no general prohibition for applications on
the 2.4 GHz band. This means that the band can continue to be used regardless of application or
technology, i.e. in principle the band’s use for model radio control systems is approved for the whole of
Europe.
However, the meeting did emphasise the importance of observing the appropriate technical regulations and
limits, as this was the only means of ensuring that different types of apparatus operating on 2.4 GHz could
co-exist without interference. On 01.07.2008 a new version of the corresponding directive for Europe (EN
300 328 V1.7.1) came into force, which contains a new requirement for a Medium Access Protocol. This
represents a fresh challenge to equipment manufacturers to ensure that their products can continue to be
sold.
What is MULTIPLEX doing?
Now that the legal aspect in Europe has been clarified, we are working very hard at making the technology
accessible to our customers. In particular we are concentrating on the recently initiated prototype test phase,
examining the equipment’s performance in all types of application under the widest possible range of
practical conditions. This is essential to ensure that our products will set new standards in terms of
functionality and quality.
Our aim is to introduce the first products in 2009. The initial range will include the following:
- a modular solution for retro-fitting to the ROYALpro series*
- a modular solution for retro-fitting to the PROFI mc 3000 / 4000 series
- a range of 2.4 GHz receivers
*) or the ROYALevo, if the firmware has been updated to V2.xx or if the device has been upgraded to ROYALpro standard by an
authorised MULTIPLEX Service Centre.
MULTIPLEX Modellsport GmbH & Co. KG
Product Management October 2008
Anche la vecchia cara MPX si converte.....
....nel frattempo mi tengo cara la cockpit sx!!
pipercubgiallo non è collegato   Rispondi citando
Vecchio 30 ottobre 08, 16:05   #2 (permalink)  Top
L'avatar di Valerio Ceccherini
Data registr.: 09-01-2008
Residenza: Poggio MIrteto
in italiano
MULTIPLEX sul tema: 2.4GHz
“2,4 Gigahertz” è un tema che da qualche tempo è sulla bocca di tutti e su tutti i media che si occupano di
modellismo RC.
Ogni giorno riceviamo innumerevoli richieste e per questo motivo vogliamo prendere posizione:
Una nuova tecnologia!?
Si e no.
Si, perché questa tecnologia è stata adottata nel modellismo da poco tempo e non ha quindi ancora avuto
un ruolo importante.
No, perché questa banda di frequenza (Banda-ISM = Industrial Scientific Medical) è prevista per la
trasmissione dati in formato digitale e viene già utilizzata per innumerevoli applicazioni (p.es. WLAN,
Bluetooth, telefonia mobile, apriporta per garage).
Quali sono i vantaggi del 2.4GHz per il modellismo RC?
I vantaggi sono molteplici e molto interessanti – p.es.
- impostazione automatica del canale
(non è quindi più necessario impostare/controllare la frequenza che si vuole usare)
- antenne corte per radio e ricevente
- applicazioni di telemetria (trasmissione dati dal modello alla radio)
- alta velocità di trasmissione
(molte funzioni di comando con un maggiore risoluzione e alte velocità)
- immune dalle fonti d’interferenza tipiche del modellismo
(p.es. motorizzazioni elettriche, accensioni elettroniche o interferenze dovute al contatto fra metalli)
E dal punto di vista „giuridico“?
Il 14 maggio 2008 si è tenuto un incontro fra i rappresentanti dell’industria europea di modellismo e relative
organizzazioni, dell’industria R-LAN, nonché degli enti di controllo europei presso la EUROPEAN
COMMISSION TCAM, per discutere sulla proposta avanzata dall’industria R-LAN per vietare l’utilizzo della
banda di frequenza 2.4GHz a livello europeo per il comando a distanza di modelli e per altre applicazioni.
Alla fine dell’incontro è stato stabilito che non ci saranno divieti generali per l’utilizzo della banda 2.4GHz. La
banda potrà quindi, anche in futuro, essere usata per tutte le applicazioni, anche per il comando a distanza
di modelli RC.
Tuttavia è stato sottolineato che dovranno essere rispettate le normative tecniche ed i valori massimi
consentiti. Solo in questo modo è possibile una coesistenza priva di interferenze fra i diversi apparecchi che
lavorano sui 2.4GHz. Il 1 luglio 2008 è inoltre entrata in vigore una nuova versione della rispettiva normativa
europea (EN 300 328 V1.7.1), che prevede l’introduzione di un Medium Access Protocol - …una nuova sfida
per i produttori.
Cosa fa la MULTIPLEX?
Dopo che in Europa è stato chiarito l’aspetto giuridico, lavoriamo con impegno per rendere accessibile
questa nuova tecnologia ai nostri clienti. La fase sperimentale, iniziata da poco con i primi prototipi, mira a
valutare l’affidabilità nelle diverse situazioni e campi d’impiego, in modo da garantire la funzionalità e l’alto
livello qualitativo.
Il nostro obiettivo è di mettere sul mercato i primi prodotti nel 2009. I primi ad essere realizzati saranno:
- un modulo d’espansione per la linea ROYALpro*
- un modulo d’espansione per la linea PROFImc3000/4000
- una linea di riceventi 2.4GHz
*) o ROYALevo dopo che l’apparecchio è stato aggiornato da un centro assistenza autorizzato MULTIPLEX alla versione V.2.xx o
allo standard ROYALpro.
Valerio
Valerio Ceccherini non è collegato   Rispondi citando
Vecchio 30 ottobre 08, 17:43   #3 (permalink)  Top
L'avatar di twentynine
Data registr.: 14-04-2005
Residenza: Verona
Corro a impachettare la REvo e a spedirla per l'upgrade a 2.0.
RC PLANES ARE NOT DRONES
Vecchio 31 ottobre 08, 12:46   #4 (permalink)  Top
L'avatar di pierrecruset
Data registr.: 18-10-2005
Residenza: Saluzzo (CN)
Grazie per la segnalazione.
Io ho una MC3030 e aspetterò gli sviluppi...non mi dispiacerebbe un upgrade al 2.4...
pierrecruset non è collegato   Rispondi citando
T10C 2.4 Ghz vs JR9303 2.4 Ghz enry74 Radiocomandi 147 14 maggio 10 15:32
2.4 GHz bi555 Elimodellismo Principianti 17 26 febbraio 08 09:29
Tutti gli orari sono GMT +2. Adesso sono le 11:51.
