![]() | #941 (permalink) Top |
User Data registr.: 14-01-2012 Residenza: Roma
scusate tutti, ho una cosa da chiedervi... so come funzionano i buddy codes ma .. solo per metà!! volevo sapere: maaa se una persona usa un tuo buddy code, come faccio io a saperlo? per caso HobbyKing me lo dice? curiosità!
__________________ Hi Sky FBL 100 - T-Rex 450 Sport V2 - Arrow plus Flybarless - Easystar II - Graupner Mini Taxi - Ansmann Mad Rat - TT MTA4 Aurora 9 - Funcub - STINGER 64 EDF 4S |
![]() | #943 (permalink) Top |
Guest
Messaggi: n/a
| Viteria e minuteria di ricambio heli/car - HK International ![]() 2.5x10mm Sockethead Screw (10pcs/pack) ![]() 2.5x12mm Sockethead Screw (10pcs/pack) ![]() 2.5x8mm Sockethead Screw (10pcs/pack) ![]() Hex locknuts M2.5 10pc ![]() Blue Anodised Aluminum M3 Nylock Nuts(8pcs) ![]() Blue Anodised Aluminum M2 Nylock Nuts (8pcs) ![]() Red Anodised Aluminum M2 Nylock Nuts (8pcs) ![]() TURNIGY 4pcs hex socket driver set |
![]() | #944 (permalink) Top |
User Data registr.: 02-01-2006 Residenza: napoli
qualche codicillo........................ Turnigy Aerodrive SK3 3536/3542/3548/4240/4250/DT30XL Series Replacement Ball Bearing Set (3pcs/bag) Thermal Heat Transfer Compound with Applicator (2pc) Turnigy AerodriveXp 28-22 Shaft LED Corn Light 12V 2.6W (13 LED) - Green (2pcs) LED Corn Light 12V 2.6W (13 LED) - White (2pcs)
__________________ M GLI ELICOTTERI W I PYLON |
![]() | #945 (permalink) Top |
User Data registr.: 02-12-2012 Residenza: Nogara
| M3x10mm Hex Screw (12pcs/bag) - Turnigy Trailblazer XB and XT 1/5 http://www.hobbyking.com/buddy.asp?c...5-3BAFC31CC18C Parallel charging Board for 6 packs 2~6S (T Connector) 1/8 Buggy 3.4 (offset) Wheel/Tire 17mm Hex (2pcs/bag) http://www.hobbyking.com/buddy.asp?c...9-F31C731B9055 TrackStar Silicone Diff Oil 5000cSt (60ml) |
![]() | #947 (permalink) Top |
User Data registr.: 16-05-2006 Residenza: Ragusa
Salve a tutti Spero che cosi funzioni, ecco i miei codici: Bumblebee Carbon Fiber Quadcopter Frame 550mm LED Strip with JST Connector 200mm (Red) LED Strip with JST Connector 200mm (Green) 9 Mode Multi Colour/Multi Function LED strip with Control Unit Hobbyking Multi-Rotor Power Distribution Board (DIY 8 x output PCB ) Multiwii and Megapirate AIO Flight Controller w/FTDI (ATmega 2560) LED Strip with JST Connector 200mm (White) |
![]() | #948 (permalink) Top |
User Data registr.: 30-10-2011 Residenza: roma
| buddy code warehouse olanda Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories (NL Warehouse) Hobbyking 60w Power Supply (NL Warehouse) Turnigy nano-tech 460mah 2S 25~40C Lipo Pack (NL Warehouse) 18-11 2000kv Micro Brushless Outrunner (10g) (NL Warehouse) TURNIGY Plush 6A /.8bec/6g Speed Controller (NL Warehouse)
__________________ blade mcpx brushless mini quadricottero con multiwii hk 250 gt flybarless |
![]() | #949 (permalink) Top |
User Data registr.: 22-10-2012 Residenza: macerata
qualche accessorio All my buddy-codes on RCSearch.info Hobbyking 60w Power Supply (NL Warehouse) ![]() $12.61* XT90 to Banana Plug Charge Lead Adapter (NL Warehouse) ![]() $2.72* (buddy price -36%, -$1.52) HXT 4MM to Banana Plug Charge Lead Adapter (NL Warehouse) ![]() $2.39*
__________________ LOSI micro DT; micro SCT;serpents240; Strike; Raminator; turnigy 1\16 buggy; "la Giallina";desert buggy; TT TS4 E; AXIAL Exo; Dingo;Vaterra TH;hpi savage xs; hobao Hyper ST Pro; amewi Pitbull-x; quanumQRF400; anderson M5 |
![]() | #950 (permalink) Top |
User Data registr.: 18-12-2012 Residenza: MOLFETTA
Salve Ha Tutti Ho Preso Da Poco Una Revo Monster 3.3 Ma Sto Avendo Problemi A Metterla In Moto Dopo Pochi Tentativi Non Gira Piu Il Motore Io Penso Problemi Di Batteria Dello Start Che Dite Aiutatemi
BuddyPrice su HobbyKing | Mayer | Modellismo | 2 | 23 maggio 11 12:03 |
X Garbo e i tuoi 20/23 | micheletn | Aeromodellismo Volo a Scoppio | 69 | 21 febbraio 08 20:53 |
