![]() | #842 (permalink) Top | ||
User Data registr.: 02-08-2010 Residenza: verona
| duty free Extra Codes, You can save 41.02% for all of this products with:RC Buddy! Codes from RC-Buddy.com Citazione:
![]() | #843 (permalink) Top |
User Data registr.: 18-01-2011
| Hobbyking Bixler EPO 1400mm (KIT) Control Horns 13.5x16mm (10pcs) Nylon Clevis 1.8x27mm (10pcs/set) Control Horns 16x20mm (10pcs) Nylon Clevis 2x29mm (10pcs) Linkage Stopper D1.8mm (10pcs) Evotite CA460 Foam Safe Super Glue (Medium) Servo Terminals (Futaba) Gold Plated (10pairs/set) http://www.hobbyking.com/buddy.asp?c...8-9B342A203CD1 20CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set) Ultima modifica di mick3485 : 22 ottobre 12 alle ore 13:03 |
![]() | #844 (permalink) Top |
User Data registr.: 20-01-2005
Ecco i miei Turnigy Accucel-8 150W 7A Balancer/Charger ![]() NTM Prop Drive 2836 Series Replacement Shaft Charge Cable w/ Male XT60 <-> 4mm Banana plug Battery Monitor 2-6S Hobbyking SS Series 50-60A ESC FrSky V8FR-II 2.4Ghz 8CH Receiver (HV)
__________________ Tonino |
![]() | #845 (permalink) Top |
User Data registr.: 12-05-2009 Residenza: Lucca - Heidelberg
Validi fino al 5 novembre... HD Wing Camera 1280x720p 30fps 5MP CMOS ![]() 2.4Ghz A-FHSS Compatible 8CH Receiver (Hitec Minima compatible) ![]() AX 1806N 2100kv Brushless Micro Motor (19g) ![]() TURNIGY Plush 12amp (2A BEC) BESC ![]() Turnigy nano-tech 1000mah 3S 25~50C Lipo Pack ![]() Turnigy nano-tech 2650mah 3S 35~70C Lipo Pack ![]() HXT500 5g / .8kg / .10sec Micro Servo ![]() Ciao ![]()
__________________ Marco MANCIONE in Germany... Giovanni Garofoli, MANCIONE back to Italy... Pasquale Ametrano. ![]() |
![]() | #847 (permalink) Top |
User Data registr.: 02-01-2006 Residenza: napoli
robbbba fresca.............................. Parallel charging Board for 6 packs 2~6S (T Connector) Rubber Band Powered Freeflight Dr-1 Model 437mm Span w/Electric Winder Turnigy nano-tech 260mAh 1S 35-70C Lipo Pack (QR Ladybird/Genius CP/Mini CP) Turnigy A-6-10 200W Balance charger & discharger Turnigy 4mm Heat Shrink Tube Yellow (1mtr) Turnigy AAA LSD 900mah Low Self Discharge (ready to use) Male XT60 connectors (5pcs/bag) GENUINE APC Style Propeller 5x5 (2 pc) ![]() ![]() ![]()
__________________ M GLI ELICOTTERI W I PYLON |
![]() | #848 (permalink) Top |
User Data registr.: 20-11-2005 Residenza: Carbonia
![]() | 2 Pin 6 x Pico Plug Charging Set Eflite compatible. Ultra Thin Foam Glue 40ml 450 Size Heli Blade Balancer Adapter (3mm) Turnigy 4mm Heat Shrink Tube - <b>RED</b> (1mtr) Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
__________________ Passato: Calmato 40, Raptor 30 V2, T7CHP Presente: UM T-28, B450 3D, T7CHP, DX7S modo 1 In costruzione: GP T-Craft 20 |
![]() | #850 (permalink) Top |
User Data registr.: 29-10-2010 Residenza: Napoli
| Un servo più economico non si trova! :)
Find my codes here: RC International (valid until November 09, 2012) HK15178 Analog Servo 10g / 1.4kg / 0.09s Save US$: 0.08 ![]() Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app ![]() |
BuddyPrice su HobbyKing | Mayer | Modellismo | 2 | 23 maggio 11 12:03 |
X Garbo e i tuoi 20/23 | micheletn | Aeromodellismo Volo a Scoppio | 69 | 21 febbraio 08 20:53 |
