Vecchio 26 marzo 12, 14:14   #611 (permalink)  Top
L'avatar di icarus64
Data registr.: 30-03-2011
Residenza: perugia
Appena sfornati:
Find my codes here: RC International (valid until April 09, 2012)
Turnigy 6 in 1 Multi Tool - Flat/Phillip/Hex (1.5/2.0/2.5/3.0mm) Save US$: 1.76
Tail Wheel System. w/ Steering and Spring 40-90 Size Save US$: 0.14
JR Y Servo Lead 30CM Length (5pcs/bag) Save US$: 0.97
Master Airscrew propeller 12x6 Save US$: 1.41
---Find my codes here: RC International (valid until April 09, 2012)
Receiver Switch (3 plug) Save US$: 1.19
Turnigy 9X 2.4GHz 8Ch Receiver (V2) Save US$: 0.70
"Quando il saggio indica la luna, lo stolto guarda il dito." (anonimo) - "Due cose sono infinite: l'universo e la stupidità umana, ma riguardo l'universo ho ancora dei dubbi." (A. Einstein)
icarus64 non è collegato   Rispondi citando
Vecchio 29 marzo 12, 00:40   #614 (permalink)  Top
Scj
L'avatar di Scj
Data registr.: 27-04-2005
Residenza: Prov. UD - Prov. TV
appena generati...
HobbyKing R/C Hobby Store : Turnigy 5.5mm Hex Socket Screwdriver
HobbyKing R/C Hobby Store : EC5 Battery Harness 12AWG for 2 Packs in Series
HobbyKing R/C Hobby Store : Turnigy Heat Shrink Tube 50mm BLACK (1mtr)
HobbyKing R/C Hobby Store : Turnigy Heat Shrink Tube 40mm Black (1mtr)
HobbyKing R/C Hobby Store : 160W Dremel Style Rotary hand-tool w/ 33pc set 230V
HobbyKing R/C Hobby Store : TurboThumbs Super Big Futaba Rocker (1pair) Blue
HobbyKing R/C Hobby Store : Folding Propeller 7.5x4inch
HobbyKing R/C Hobby Store : JM 13x6 / 330x152.5mm propeller
HobbyKing R/C Hobby Store : HobbyKing Glow Plug No.6 (COLD)
HobbyKing R/C Hobby Store : Turnigy Heli-Tach 3600 Optical Tachometer 1000~3600RPM
HobbyKing R/C Hobby Store : 4MM Banana Plug / Charge Plug (solder type) (2 pair/bag)
HobbyKing R/C Hobby Store : Hobbyking DC-4S Balance Charger & Cell Checker 30w 2s~4s
HobbyKing R/C Hobby Store : Peel-n-stick foam tape. 10x5inch 4mm thick
HobbyKing R/C Hobby Store : AC Hinge L25*W20*H0.3 (10pcs)
HobbyKing R/C Hobby Store : Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories
HobbyKing R/C Hobby Store : Turnigy S3317S Servo 17g / 2.3kg / .14sec
HobbyKing R/C Hobby Store : Turnigy balancer & Charger 2S-3S
HobbyKing R/C Hobby Store : Turnigy High Density R/C LED Flexible Strip-White (1mtr)
HobbyKing R/C Hobby Store : Turnigy High Density R/C LED Flexible Strip-Green (1mtr)
HobbyKing R/C Hobby Store : 40CM Servo Lead (JR) 32AWG Ultra Light (10pcs/bag)
Si stava meglio quando si stava peggio.......
SIMONE ._.-._. simcard @ rocketmail.com
http://pradeigai.altervista.org
Scj non è collegato   Rispondi citando
Vecchio 29 marzo 12, 10:02   #615 (permalink)  Top
L'avatar di McDaniels
Data registr.: 28-09-2011
Residenza: Catania
Find my codes here: RC International (valid until April 12, 2012)
XH Adapter Coversion Board W/ Polyquest Charger plug Save US$: 0.19
Hard Steel Tweezer Set Save US$: 0.29
Balance Plug Savers (JST-XH 3s) (5pc Per Bag) Save US$: 0.46
Align T-Rex 500 E PRO DFC X-Bar
Blade mCPX v2 stock - Blade mCPX v2 Brushless HP05 - Radio: Spektrum Dx7
Walkera Lama 400 - Walkera CB100 - Walkera 4#6
McDaniels non è collegato   Rispondi citando
Vecchio 29 marzo 12, 13:27   #616 (permalink)  Top
L'avatar di hit22
Data registr.: 22-07-2011
Residenza: Perugia
fibra da 18 grammi
HobbyKing R/C Hobby Store : Glass Fiber Cloth 450x1000mm 18g/m2 (Super Thin)
Ciao ;-)
Max
hit22 non è collegato   Rispondi citando
Vecchio 30 marzo 12, 10:13   #617 (permalink)  Top
L'avatar di Nicus
Data registr.: 17-01-2005
Residenza: Arce, Frosinone, Lazio, Italia
Invia un messaggio via MSN a Nicus
Freschi Freschi
Extra Codes, You can save 68.83% for all of this products with:BuddyPrice Codes! Codes from RC-Buddy.com
HobbyKing 6mm Silicon Rubber Bungee Hi-Start Cord
Savings: 11.52 % / $0.38
Price after: $2.92
Weight: 185 g
X8 2.4Ghz System Refit Antenna Cable
Savings: 32.72 % / $1.42
Price after: $2.92
Weight: 25 g
Light Foam Wheel (Diam: 110, Width: 30mm)
Savings: 39 % / $0.78
Price after: $1.22
Weight: 47 g
Car Cigarette Lighter Adapter for Battery Chargers
Savings: 32.66 % / $0.65
Price after: $1.34
Weight: 59 g
Turnigy nano-tech 3300mah 4S 65~130C Lipo Pack
Savings: 97.35 % / $49.21
Price after: $1.34
Weight: 527 g
JST-XH to JST LED Power Distribution Lead
Savings: 66.04 % / $1.05
Price after: $0.54
Weight: 25 g
Turnigy Receiver Controlled Switch
Savings: 12.89 % / $0.92
Price after: $6.22
Weight: 21 g
NTM Prop Drive 42 Series Accessory Pack
Savings: -212.56 % / $-4.23
Price after: $6.22
Weight: 55 g
NicusWebPlanSearch cerca Piani costruttivi
Il Mio Sito
- Il Mio Blog - I Miei Buddy Price
Nicus non è collegato   Rispondi citando
Vecchio 30 marzo 12, 16:51   #618 (permalink)  Top
Data registr.: 23-11-2011
Residenza: trento
Rhino 460mAh 2S 7.4v 20C Lipoly Pack
HobbyKing R/C Hobby Store : Rhino 460mAh 2S 7.4v 20C Lipoly Pack
TURNIGY Plush 40amp Speed Controller
HobbyKing R/C Hobby Store : TURNIGY Plush 40amp Speed Controller
Male XT60 connectors (5pcs/bag) GENUINE
HobbyKing R/C Hobby Store : Male XT60 connectors (5pcs/bag) GENUINE
a voi!!
dammuozz non è collegato   Rispondi citando
Vecchio 30 marzo 12, 20:31   #619 (permalink)  Top
L'avatar di magnetron1
Data registr.: 26-12-2009
Ecco i miei ultimi...
HobbyKing R/C Hobby Store : Turnigy nano-tech 3300mah 3S 25~50C Lipo Pack
HobbyKing R/C Hobby Store : Front Wheel Steering Arm & Mount Set 40mm (5sets)
HobbyKing R/C Hobby Store : Button spirit level. (2pc)
AERODRONE M4X - AERODRONE M6S (revamping) - AERODRONE M4H - i miei video
magnetron1 non è collegato   Rispondi citando
Vecchio 31 marzo 12, 08:40   #620 (permalink)  Top
L'avatar di Lamerino
Data registr.: 20-06-2011
Residenza: Macerata
Find my codes here: RC International (valid until April 14, 2012)
NTM Prop Drive 35 Series Accessory Pack Save US$: 0.64
Twisted 22AWG servo wire 1mtr (R/B/W) 22AWG Save US$: 0.67
Self-Tapping Screws M2x4 (10pcs/set) Save US$: 0.51
Self Tapping Screws w/shoulder M2x8 (10pcs/set) Save US$: 1.12
Lamerino non è collegato   Rispondi citando
BuddyPrice su HobbyKing Mayer Modellismo 2 23 maggio 11 13:03
X Garbo e i tuoi 20/23 micheletn Aeromodellismo Volo a Scoppio 69 21 febbraio 08 21:53
Tutti gli orari sono GMT +2. Adesso sono le 18:57.
