![]() | #1571 (permalink) Top |
User Data registr.: 14-01-2004 Residenza: Parma
| I miei BUDDY CODE
BATTERIE!!! Delle fantastiche 5S 4500 45C https://www.hobbyking.com/hobbyking/...4500.5S.45.jpg https://www.hobbyking.com/hobbyking/...dProduct=32717 Ottime per i combat!!! 3S 1300 25C https://www.hobbyking.com/hobbyking/...0-3S-25(1).jpg https://www.hobbyking.com/hobbyking/...dProduct=32553 |
![]() | #1572 (permalink) Top |
User Data registr.: 07-02-2012 Residenza: milano
| freschi di giornata
Aerobatic Pattern/3D EP Airplane Balsa/Ply 1650mm (ARF) (EU http://www.hobbyking.com/buddy.asp?c...0-CD609C3D0BEE HobbyKing 120A ESC 4A UBEC (EU Warehouse) http://www.hobbyking.com/buddy.asp?c...4-C37DEE16C32F Team Turnigy Prop Protectors (Large - 1pr) (EU warehouse) http://www.hobbyking.com/buddy.asp?c...F-0801E59A1D70 Twisted 100cm Servo Lead Extension (JR) 22AWG (5pcs/set) (EU http://www.hobbyking.com/buddy.asp?c...6-5E8AB195C181 Twisted 80cm Servo Extension Lead(JR) 22AWG (5pcs/set) (EU http://www.hobbyking.com/buddy.asp?c...A-43AEF7E7BC31 |
![]() | #1574 (permalink) Top |
User Data registr.: 25-05-2010 Residenza: cosenza
| buddy - 30.03.2014 Clip On Soft Ferrite Rings (5pc) (EU warehouse) AV / Power Cables for FPV (EU Warehouse) Turnigy Multistar 45 Amp Multi-rotor Brushless ESC 2-6S (OPTO) (EU warehouse) saluti
__________________ Alea iacta est --![]() ![]() |
![]() | #1575 (permalink) Top |
User Data registr.: 04-10-2013 Residenza: Empoli
Cicalino batteria: On Board Lipoly Low Voltage Alarm (2s~4s) Elica pieghevole 9x5: Folding Propeller w/ Alloy hub - 9x5 Connettori batteria: PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) LED Rosso: Super Bright 3Watt Red LED Lamp with Aluminium Heatsink LED blu: Super Bright 3Watt Blue LED Lamp with Aluminium Heatsink Power supply x caricabatteria: Hobbyking 105W 15V/7A Switching DC Power Supply Squadrette servi: Pin Horns L20xW15xH11.52 (4 holes) 10pcs/set |
![]() | #1576 (permalink) Top |
User Data registr.: 20-09-2010 Residenza: Campo del G.A.R. "Luciano Baldi" - Rovigo
| ![]() 5030 Propellers (Red) - 3xCW and 3xCCW - 6pcs per bag (EU Warehouse) ![]() $2.80 5030 Propellers (Black) - 3xCW and 3xCCW - 6pcs per bag (EU Warehouse) ![]() $2.80 Universal Nylon Landing Skid Set for Multi-Rotor Frames (Extended 202mm) ( EU Warehouse) ![]() $5.01
__________________ AEREI: Hangar9 Cirrus SR22T - Topmodel Bidule 116 - Jonathan SHK 1/4 - Cuccolo ASG29 1/4.5 - Tangent ASH26 1/4.5 - RCRCM Typhoon - Glider_it Vettore - Uranio F3K - Maxa 4m F5J / RADIO:Spektrum DX20 - Futaba T14SG |
![]() | #1578 (permalink) Top | |
| ![]() Citazione:
Mi spiego meglio: vai su Hobbyking.com, fai il login, poi nella schermata del profilo vai sui tuoi ordini (XX Check), e ti si aprirá la lista dei tuoi ordini sinora effettuati. Bene, alla sinistra dell'ultimo ordine effettuato, clicca "VIEW" e noterai come accanto al prezzo di alcuni oggetti vi siano dei simboletti blu. Una volta cliccato sul simbolo, ti si aprirà un avviso sulla stessa pagina, riportando delle semplici istruzioni circa cosa farne del link presente sul riquadro appena apertosi. Esempio: ![]()
__________________ AEREI: Hangar9 Cirrus SR22T - Topmodel Bidule 116 - Jonathan SHK 1/4 - Cuccolo ASG29 1/4.5 - Tangent ASH26 1/4.5 - RCRCM Typhoon - Glider_it Vettore - Uranio F3K - Maxa 4m F5J / RADIO:Spektrum DX20 - Futaba T14SG | |
![]() | #1579 (permalink) Top |
Guest
Messaggi: n/a
| From HK International All my buddy-codes on RCSearch.info OrangeRx R400 Spektrum/JR DSM2 Compatible 4Ch 2.4Ghz Receiver ![]() $5.38 Turnigy Heat Sealing Iron Sock ![]() $1.46 (buddy price -36%, -$0.82) Hobbyking YEP 18A (2~4S) SBEC Brushless Speed Controller ![]() $8.99 (buddy price -22%, -$2.49) Turnigy Covering Film Iron. ![]() $18.17 (buddy price -9%, -$1.82) |
BuddyPrice su HobbyKing | Mayer | Modellismo | 2 | 23 maggio 11 12:03 |
X Garbo e i tuoi 20/23 | micheletn | Aeromodellismo Volo a Scoppio | 69 | 21 febbraio 08 20:53 |
