![]() | #1051 (permalink) Top |
User |
Freschi di MO JST-XH 4S Wire Extension 20cm (10pcs/bag) LED PCB Strobe Red 3.3~5.5V Ho preso anche questi due ma niente codice scornto x voi ![]() Domanda nesuno di voi sta provando queste Batterie ? A123-3.3VB Lithium Ion 2300mAh Single Cell Battery Sto facendo bene a convertire in connettori Deans T con questi ? Nylon XT60 Connectors Male/Female (5 pairs) GENUINE Grazie |
![]() | #1052 (permalink) Top |
User Data registr.: 16-12-2012 Residenza: Frosinone
| Freschi freschi Turnigy 1000mAh 3S 25C Lipo Pack (DE Warehouse) Turnigy 1000mAh 3S 25C Lipo Pack (DE Warehouse) Prop adapter w/ Alu Cone 2mm shaft (Grub Screw Type) (DE Warehouse) Short Prop adapter w/ Alu Cone 3mm shaft (Grub Screw Type) (DE Warehouse) HobbyKing 4-6min Epoxy Glue (DE Warehouse)
__________________ Fai di tutto affinché il numero dei tuoi atterraggi sia uguale al numero dei tuoi decolli. |
![]() | #1053 (permalink) Top |
User Data registr.: 07-07-2010 Residenza: Riva del Garda
le mie gigiate Alloy Anti-Slip TX Control Sticks Short (JR TX Red) Multi-Remote Receiver operated on/off Switch
__________________ ![]() ![]() nel 2024.. in lavorazione ![]() |
![]() | #1054 (permalink) Top |
| Fermatemi PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Nylon T-Connectors 10 Pairs (20pc) Futaba Y Servo Lead 30cm Length (5pcs/bag) APC Style Propeller 8x4 (2 pc) D2822/14 Brushless Outrunner 1450kv Sbach 342 1400mm and MX2 1400mm - Replacement Prop Adapter TGS Sport 8x4E Precision propeller
![]() | #1057 (permalink) Top |
| Freschi freschi HKS-9650 High Speed Servo 2.3kg/ 25g/ 0.08sec SF E-Prop 7x4 / 178x102mm w/ Adapters Black (5pcs/bag) On Board Lipoly Low Voltage Alarm (2s~4s) Pivot & Round Hinges 2x33 (10pcs)
![]() | #1058 (permalink) Top |
User Data registr.: 26-04-2011 Residenza: veneto
| i miei... Durafly Zephyr V-70 EDF V-Tail Glider w/70mm EDF/Motor 1533mm (ARF) (DE Warehouse) Turnigy 3600mAh 3S 30C Lipo Pack (DE Warehouse) Hobbyking SS Series 60-70A ESC (DE Warehouse) Turnigy TGY-9018MG Metal Gear Servo 2.5kg/13g/0.10 (DE Warehouse)
__________________ L'incompetenza si manifesta con l'uso di troppe parole. E.P. |
![]() | #1059 (permalink) Top |
User Data registr.: 12-02-2012 Residenza: Como
| ![]() Quanum E-Guana 1/10 Brushless 2WD Desert Racing Buggy (ARR) (NL Warehouse) SCONTO DEL 13% $130.64 (Risparmio $19.29) ![]() Turnigy nano-tech 5000mah 3S 40~80C Lipo Pack (TRA2872 Slash/Slash 4x4) (NL Warehouse) $43.60 (Risparmio $6.44) Buddy-links from Bi7hazard
__________________ ![]() |
![]() | #1060 (permalink) Top |
User |
super motore ![]() Dr Mad Thrust 3000kv 1300w 70mm EDF Inrunner Motor 4s version (29mm) il blend derm x i triaileron... ![]() ![]() 1/2" wide x 4m -3M Blenderm Tape (Hinging Tape - Twin Pack) super ciabatta ![]() Hobbyking PowerStrip - Fuse Protected Power Distribution Board Si possa in Olanda....in 5 giorni a casaaaaa!!!! ![]() Turnigy nano-tech 2200mah 2S 40~80C Lipo Pack (TRA2820 Traxxas 1/16 models) (NL Warehouse) ![]() ZIPPY Compact 2450mAh 4S 35C Lipo Pack (NL Warehouse) super regolo 10$ di scontooooo!!!!! ![]() Super servi alloy 6$ di sconto ![]() Turnigy TGY-777MG Alloy Case Digital Slim Wing Servo (Metal Gear) 5.5kg / .10sec / 23g (NL Warehouse |
BuddyPrice su HobbyKing | Mayer | Modellismo | 2 | 23 maggio 11 12:03 |
X Garbo e i tuoi 20/23 | micheletn | Aeromodellismo Volo a Scoppio | 69 | 21 febbraio 08 20:53 |
