![]() | #1003 (permalink) Top |
User Data registr.: 20-07-2009 Residenza: Svizzera
SBD4 4-Channel S.BUS Decoder 1 IN STOCK SBD4 4-Channel S.BUS Decoder HobbyKing Helicopter Pitch Gauge Kit 1 IN STOCK HobbyKing Helicopter Pitch Gauge Kit Turnigy 0# 3mm Philips Head Screwdriver 1 IN STOCK Turnigy 0# 3mm Philips Head Screwdriver Turnigy 1.5mm Hex Screwdriver 1 IN STOCK Turnigy 1.5mm Hex Screwdriver Turnigy 2.5mm Hex Screwdriver 1 IN STOCK Turnigy 2.5mm Hex Screwdriver Ball and roller link 4.8x3x17mm (10pcs/bag) 1 IN STOCK Turnigy Pure-Silicone Wire 20AWG (1mtr) Black 1 IN STOCK Turnigy Pure-Silicone Wire 20AWG (1mtr) Black Turnigy Pure-Silicone Wire 20AWG (1mtr) RED 1 IN STOCK Turnigy Pure-Silicone Wire 20AWG (1mtr) RED Turnigy Pure-Silicone Wire 16AWG (1mtr) Red 1 IN STOCK Turnigy Pure-Silicone Wire 16AWG (1mtr) Red Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK 1 IN STOCK Turnigy Pure-Silicone Wire 16AWG (1mtr) BLACK Servo Terminals (Futaba) Gold Plated (10pairs/set) 1 IN STOCK Fiberglass Canopy for Trex-700E 1 IN STOCK Turnigy 1# 3mm Philips Head Screwdriver 1 IN STOCK http://www.hobbyking.com/buddy.asp?c...C-9856D657A2F0 Turnigy 2mm Hex Screwdriver 1 IN STOCK Turnigy Pro 2.0mm long shaft Hex Screwdriver 1 IN STOCK Plastic Multi-purpose Organizer - 24 Compartment 1 IN STOCK Plastic Multi-purpose Organizer - 24 Compartment Turnigy Heat Shrink Tube 100mm BLACK (1mtr) 1 IN STOCK Turnigy Heat Shrink Tube 100mm BLACK (1mtr) Turnigy Heat Shrink Tube 50mm BLACK (1mtr) 1 IN STOCK Turnigy Heat Shrink Tube 50mm BLACK (1mtr) Turnigy Heat Shrink Tube 20mm Transparent (1mtr) 1 IN STOCK Turnigy Heat Shrink Tube 16mm Transparent (1mtr) 1 IN STOCK Turnigy Heat Shrink Tube 10mm RED (1mtr) 1 IN STOCK Turnigy Heat Shrink Tube 10mm BLACK (1mtr) 1 IN STOCK Turnigy 3mm Heat Shrink Tube - RED (1mtr) 1 IN STOCK Turnigy 3mm Heat Shrink Tube - BLACK (1mtr) 1 IN STOCK Turnigy 2mm Heat Shrink Tube - RED (1mtr) 1 IN STOCK Turnigy 2mm Heat Shrink Tube - BLACK (1mtr) 1 IN STOCK Turnigy 6mm Heat Shrink Tube - RED (1mtr) 1 IN STOCK Turnigy 6mm Heat Shrink Tube - BLACK (1mtr) 1 IN STOCK Turnigy 5mm Heat Shrink Tube - RED (1mtr) 1 IN STOCK Turnigy 5mm Heat Shrink Tube - BLACK (1mtr) 1 IN STOCK Turnigy 4mm Heat Shrink Tube - BLACK (1mtr) 1 IN STOCK Turnigy 4mm Heat Shrink Tube - RED (1mtr) 1 IN STOCK HXT 6mm Sprung Gold Connectors (10pair/20pc) 1 IN STOCK 8MM gold connectors (12 pack) 1 IN STOCK JST-XH 4S Wire Extension 20cm (10pcs/bag) 1 IN STOCK JST-XH 4S Wire Extension 20cm (10pcs/bag) JST-XH 5S Wire Extension 20cm (10pcs/bag) 1 IN STOCK HXT 2mm Gold Connector w/ Protector (10pcs/set) 1 IN STOCK Polymax 4mm Gold Connectors (10pairs/set) 1 IN STOCK Standard Bearing Joints 2.8x22x5.5mm (10pcs) 1 IN STOCK Ball and roller link 3.9x2x16mm (10pcs) 1 IN STOCK Ball and roller link 3.9x2x16mm (10pcs) Hex Screw M3x20 (20pcs) 1 IN STOCK Hex Screw M3x10 (20pcs) 1 IN STOCK Wire Mesh Guard Blue 3mm (1mtr) 2 IN STOCK Wire Mesh Guard Blue 3mm (1mtr) Wire Mesh Guard Black 6mm (1mtr) 1 IN STOCK Wire Mesh Guard Black 8mm (1mtr) 1 IN STOCK Wire Mesh Guard Black 10mm (1mtr) 1 IN STOCK Wire Mesh Guard Blue 6mm (1mtr) 1 IN STOCK Wire Mesh Guard Blue 8mm (1mtr) 1 IN STOCK Wire Mesh Guard Blue 10mm (1mtr) Ragazzi questi sono validi fino al 25. alcuni non li ho postati, se servono posto i link, grazie a chiunque ne usufruisca |
![]() | #1007 (permalink) Top |
ok ragazzi, nuovo ordine, dunque validità codici fino a 13-14feb 2013 Adjustable Alu Tie Rod Set - M3 x L70 mm (5pc) Adjustable Alu Tie Rod Set - M3 x L110 mm (5pc) FPV Fiberglass Pan-Tilt Camera Mount L-Size Turnigy Pure-Silicone Wire 24AWG (1mtr) Blue Turnigy Pure-Silicone Wire 24AWG (1mtr) Yellow Buoni acquisti! |
![]() | #1008 (permalink) Top |
User Data registr.: 18-06-2008
Servi hk digitali mini. HobbyKing HK-922MG Digital Metal Gear Servo 1.8kg/ 12g/ 0.07sec (NL Warehouse) Ultima modifica di myzyo : 25 gennaio 13 alle ore 11:52 |
![]() | #1009 (permalink) Top |
User Data registr.: 22-10-2012 Residenza: macerata
__________________ LOSI micro DT; micro SCT;serpents240; Strike; Raminator; turnigy 1\16 buggy; "la Giallina";desert buggy; TT TS4 E; AXIAL Exo; Dingo;Vaterra TH;hpi savage xs; hobao Hyper ST Pro; amewi Pitbull-x; quanumQRF400; anderson M5 |
![]() | #1010 (permalink) Top |
User Data registr.: 27-01-2007 Residenza: Rossano
| lipo olandesi....
avevo dimenticato di questa possibilità..... ma oggi rimedio... può servire? Turnigy nano-tech 5000mah 3S 40~80C Lipo Pack (TRA2872 Slash/Slash 4x4) (NL Warehouse)
__________________ Il mancato sfruttamento dei nostri beni culturali é incomprensibile, eppure siamo in un paese che da solo concentra il 50% dei beni culturali mondiali.Il petrolio che rende ricchi gli arabi finirà, il nostro oro nero no, anzi più invecchia e più é prezioso. |
BuddyPrice su HobbyKing | Mayer | Modellismo | 2 | 23 maggio 11 12:03 |
X Garbo e i tuoi 20/23 | micheletn | Aeromodellismo Volo a Scoppio | 69 | 21 febbraio 08 20:53 |
