Vecchio 02 settembre 17, 18:03   #1 (permalink)  Top
L'avatar di kamikazeta
Data registr.: 17-12-2008
Residenza: Piazzola sul Brenta
RCX 20A (eXtreme Series) BLHeli Multirotor ESC
vendo 4 esc praticamente nuovi usati per una diecina di voli, perfettamente funzionanti.
queste le caratteristiche:
Features
  • XM series esc is the upgraded version from SN series with advanced processor, the basic frequency up to 50MHz and processing capacity is faster to support high KV motor.
  • Specially for Multi-copter, throttle respond fast;
  • Suit for throttle, which can compatible well with motor;
  • Throttle signal is twisted pair cable, reduce the signal crosstalk effectively while transmission in the copper wire to flight more stable;
  • New miniaturization and ultra-low resistance MOSFET, powerful flow resistance, and professional MOS Drive chips to improve efficiency. PCB board processed with special thickness treatment, low resistance and calorific value, higher impact resistance.
  • Subminiaturization design, 10/20A with high performance filtering capacitor on the board to reduce the weight. Long bar XML20A is designed for the frame with arm tube, suit for the Φ10mm tube to make it more neat.
  • Support refresh rate of throttle signal maximum up to 500Hz, compatible with all flight controls; Support ultra-high speed Oneshot125 and 3000Hz high refresh rate, fast response, better throttle liner and smooth shooting to be the first choice for multicopter and racing frame.
  • Throttle lever travel and other settings are available to be set by USB linker; Support two-way mode and 3D mode for racing frame.
Specification
  • Item name: RCX eXtreme -20A BLBeli ESC
  • Signal frequency: 20-500Hz/ Oneshot125 Ultra High Speed
  • Firmware: BLHeli
  • BootLoader: BLHeli
  • Continuous current: 20A
  • Battery: 2-4S
  • BEC: None
  • Weight: Approx 5.6g (included cable)
  • Dimension (L*W*H): 24*14*4.5mm
compresa di chiavetta per programmazione.
totale 20 euro + spedizione
Nome: marco
Cognome: Campaniello
Città: piazzola sul brenta
Nome: marco
RCX 20A (eXtreme Series) BLHeli Multirotor ESC-rcx03-857-usb-linker-v2-programmer-xm-series-esc-01.jpg   RCX 20A (eXtreme Series) BLHeli Multirotor ESC-rcx07-416-dys-20a-xm-blheli-multirotor-esc-high-kv-motor-oneshot125-02.jpg
kamikazeta non è collegato   Rispondi citando
[BA+SPED] ESC DYS BL20A (blheli bootloader), EMAX 12A BLHELI matrixFLYER Merc. Motori ed Elettronica 0 02 marzo 16 00:29
FULLYMAX UAV eXtreme Light S series: chi le ha provate? mapi69 Batterie e Caricabatterie 2 16 dicembre 15 14:14
Hobbyking SS Series 18-20A ESC Lillo Aeromodellismo Volo Elettrico 0 11 settembre 12 20:41
Tutti gli orari sono GMT +2. Adesso sono le 09:33.
