Vecchio 02 aprile 14, 19:11   #1 (permalink)  Top
L'avatar di zheus
Data registr.: 28-08-2005
Residenza: cuneo
Invia un messaggio via MSN a zheus
STRATO SNAPPEPPER V2 comando per videocamere
VENDO comando remoto per video camere STRATO SNAPPER V2.
il dispositivo è nuovo, vendo per cambio di programma.
€ 50 Euro + SS
Con questo dispositivo potete comandare dal radiocomando lo star/stop e lo zoom
StratoSnapper 2 The StratoSnapper 2 gives you control over your camera, even when it’s attached to your favorite flyer high above.
Through a wide choice of remote options the StratoSnapper2 will let you control how and when to get the perfect shot. Turn that unused poti into a zoom or flip a switch to start video recording. The choice is yours, and it’s all configurable from an easy mac/pc utility.
The StratoSnapper2 uses wire-trigger, LANC or infrared remote. If you use IR it even learns new commands from most traditional remotes – all by it self.
from Esben Nielsen on Vimeo.
Specifications:
  • Will remote control your cam through: infrared, wire or LANC.
  • Accepts four standard servo inputs, with op to eight different commands.
  • Learns new IR commands just by shooting your remote at it
  • Takes 4-17 volts input (1s-4s)
  • Wide range of wire-trigger cable accessories
  • Easy configuration through USB interface
  • Works with hundreds of camera models
  • Timelapse / stand-alone option
  • Reverse voltage and short circuit protection
  • Standard 2.56mm plugs, easily hackable
  • Completely open source
  • Expandable through I2C bus
  • Highly durable, light weight, small form factor and RoHS compliant.
We have a wide choice of connectors for you favorite cam. Take your pick. All connector cables must be ordered separately. We stock Nikon, Canon and Sony. Plus 2.5mm and 3.5mm jack connectors.
What’s in the box
  • StratoSnapper2 main board
  • Two servo cables (30cm)
  • One IR transmitter
  • Dual lock re-closeable fasteners
Fully configurable remote solution for your on board camera. Supports a wide range of cameras, and will let you customize when to trigger the shutter, video, interval shooting and more. Support infrared, LANC and traditional wire trigger
Canon:
Supports all Canon cameras with the standard canon connector plug
Supports infrared remote controls: RC-3, RC-4, RC-5, RC-6. For example:
Vixia and Legria video cams (Video start/stop, tele, wide and photo)
1D series
(shutter and video. In live view mode)
5D series (shutter and video. In live view mode)
6D series (shutter and video. In live view mode)
7D series (shutter and video. In live view mode)
300D, 350D / XT (shutter)
400D, 450D / XTI, XSI (shutter)
500D, 550D / T1i, T2i (shutter and video. In live view mode)
600D / T3i (shutter and video. In live view mode)
G1, G2, G3, G4, G5, G6 (shutter, zoom and video)
ELPH series (shutter)
Sony still cameras (remotes: RMT-311, RMT-335, RMT-845, RMT-855)
FS-700 and other video cams using the remotes: RMT-311, RMT-335, RMT-845
NEX-5 series(shutter and video)
NEX-7 series(shutter and video)
A230, A330 (shutter)
A450, A500, A550 (shutter)
A700, A900 (shutter)
Sony video cams:
Supports LANC remote with ALL sony cameras capable of accepting LANC wire cammands. We are currently developing cables for the new (mid 2013) multiconnector plug. The old “half moon” plug is available in the shop.
Video start/stop and zoom (infrared) on:
DCR-DVD103, DCRDVD201, DCRDVD203, DCRDVD301, DCRDVD306E, DCRDVD308, DCRDVD403, DCRDVD408, DCRDVD505, DCRDVD508, DCRDVD708E, DCRDVD710, DCRDVD710E, DCRDVD755E, DCRDVD808E, DCRDVD810, DCRDVD905, DCRDVD908E, DCRDVD910, DCRSR100, DCRSR100E, DCRSR200, DCRSR200E, DCRSR220, DCRSR220D, DCRSR300, DCRSR300C, DCRSR33E, DCRSR42, DCRSR42A, DCRSR42E, DCRSR60, DCRSR62E, DCRSR65, DCRSR80, DCRSR82E, DCRSR85, DSCH7, DSCH7B, DSCH9, DSCH9B, HDRCX300, HDRCX350V, HDRCX550, HDRCX550E, HDRCX550V, HDRCX550VE, HDRCX7EK, HDRCX7K, HDRSR1, HDRSR10, HDRSR10D, HDRSR11, HDRSR12, HDRSR5, HDRSR5C, HDRSR7, HDRSR7E, HDRSR8, HDRSR8E, HDRUX1, HDRUX10, HDRUX5, HDRUX5E, HDRUX7, HDRUX7E, HDRXR200V, HDRXR350V, HDRXR500V, HDRXR520V, HDRXR55, HDRXR550E, HDRXR550V, HDRXR550VE, HDRCX700, DCR-PC100, DCR-PC110, DCR-PC120BT, DCR-PC5, DCR-TRV10, DCR-TRV20, DCR-TRV30, DCR-TRV40, DCR-TRV900, DCR-VX2000, DCR-VX2100, DSR250, DSRPD100, CX730, CX740, CX760
Or any other model supporting the RMT-811 or RMT-835 remote.
Nikon
Supports all Nikon cameras with the round multi connector plug
COOLPIX Series (shutter)
D40, D50, D60, D70 (shutter)
D80, D90 (shutter)
D3000, D5000, D5100 (shutter)
D7000 (shutter)
D3 series (shutter)
1 V1 (shutter)
Pentax
Supports all Pentax cameras with a mini-jack wire remote plug
*istD (shutter)
A series (shutter, zoom)
EI200, K-x (shutter)
Optio series (shutter, zoom)
Q (shutter, zoom)
K series (shutter)
S series (shutter, zoom)
W60, W80 (shutter, zoom)
Olympus
E series (shutter)
Minolta
Dimage A200 (shutter)
S series (shutter)
F100, F200, F300 (shutter)
Nome: umberto
Cognome: garelli
Città: Montaldo di M.vi (CN)
[COLOR=blue][B][COLOR=blue]- PROTOS 500 - Logo 500 Vstabi - Autogiro
zheus non è collegato   Rispondi citando
strato limite ricerca info carmichael Aeromodellismo Alianti 18 05 novembre 07 14:54
Tutti gli orari sono GMT +2. Adesso sono le 12:04.
