| | #1 (permalink) Top |
| User Data registr.: 19-09-2008 Residenza: FVG - (UD)
| Motori Regolatore Centralina alimentazione Alewings
Ciao vendo un paio di cosette che non uso: REGOLATORE TURNIGY TRUST 45 AMPERE: Turnigy® TRUST SBEC ESCs have a very flexible and broadly capable MCU, able to run all types of brushless motors.The large heatsink and simple PCB layout make heat dissapation consistant, enabling the ESC to be run at its limit, without failure. The ESC is program-card and transmitter programmable with clear and easy to understand instructions included. Default factory settings: Brake: off Battery: LiPo Auto Detect Low Voltage: 3.2v (power down motor) Spec. Max Motor Current: 45A Max BEC Current: 3A BEC Voltage: 5.5v LiPo: 2~6S NiMH:5~12cells Weight: 31grams Programming Options. Battery Type Forward/Reverse Soft Start LV Setting (Ignore, Reduce Power, Stop Motor) Timing (Auto, Med, High) Switching (8,16kHz) Factory Restore NUOVO 20 euro MOTORE TURNIGY AERODRIVE: Spec. Kv: 1050rpm/v Operating Current: 6A ~ 20A Peak Current: 23A Weight: 73g Dimensions: 27.6 x 36mm Shaft Size: 3.175mm Kit includes full accessories, including gold bullet connectors, prop saver, mount, spare rubber rings, shrink tube and screws. Performance Data Voltage Current Prop Thrust 11.1V 15.5A 9050 900g 11.1V 18.6A 1047 1090g 11.1V 19.5A 1060 1020g NUOVO 18 euro MOTORE HACKER A20-20l Hovering.it USATO 10 euro CENTRALINA ALIMENTAZIONE ALEWINGS Centralina ESC per alimentazione RX! un ingresso per batterie LIPO 2s e due uscite stabilizzate!Maggiori informazioni sul sito alewings! 50 euro ![]() --------------------------- Nome: Cristiano Cognome: Decorte Città: UD |
| Bookmarks |
| Alimentazione centralina motori a Benzina | garbo | Aeromodellismo Volo a Scoppio | 6 | 24 settembre 09 20:01 |
