![]() | #5381 (permalink) Top |
User Data registr.: 05-05-2012 Residenza: Mantova
Nuovo aggiornamento brain Available new Software/firmware Release Notes - 1.0.017 (Firmware 1.3.083) - Solved governor over speed with some Nitro engine - Now Swashplate Rotation in Advanced menu works correctly - In Tail drag if you move the cursor to zero, now swashplate instantly removes the correction - Reduced the Governor engage level from 62,5% of the target speed to 56% of the target speed. - Added Chinese Simplified in the Language menu - Added Chinese Traditional in the Language menu - If Standard Receiver is selected unusable parameters in Governor setup are greyed out - For all the units now the Servo setup is in panel 2 of the Wizard - Tail setup wizard simplified with only one plus and only one minus button for either endpoint direction. - Tail Precompensation now correct either for aileron and elevator - Rotor clockwise and rotor counterclockwise buttons added in Swashplate Selection panel and removed the Precompensations panel from Tail Setup panel. - Now in Advanced -> Gov & Level, moving the Aileron Angle for over cursor, the swashplate move in the same direction. - Connections schemes are now correct when reload data from a MTR file with a different receiver type. - Opening a .MTR configuration file already opened in a text editor, the application doesnt crash anymore - Added infos of SW, FW, Voltage and SN at the end of the new generated MTR file. - The Unit Type selection (Brain/microBrain) is now readed from the connected unit automatically. - Selecting Ok on the messages that inform to close the program (language change, Spektrum binding), now directly closes the program. - The check at the left of Full Screen is now correct if program was open in Full Screen mode. - Corrections and fixes to some instructions - Small bug fixes and optimization of code Qui il link diretto New Software 1.0.017 / Firmware 1.3.083 Available - HeliFreak
__________________ Prôtos Max V2 BrainHD2 - Prôtos 380 Evoluzione Mini Brain2- Prôtos 500 Brain - Oxy3 Qube Brain2 - Oxy2 FE µBrain2 |
![]() | #5382 (permalink) Top | |
User Data registr.: 13-02-2010 Residenza: belluno
| chiarimenti riguardo autolevel Citazione:
Ho provato la funzione con il mio goblin 380 che monta la scheda brain ed anche a me sembra che dal momento che tiro la leva per auto level il modello risponda con ritado e lentezza , non so se nel tool sia possibile andare a modificare la velocita' di reazione e concordo anche io che per salvarlo bisogna avere il modello abbastanza alto altrimenti si rischia di fare un bel botto . Un amico ha cambiato il brain con la sheda spirit per questo motivo e devo dire che l' autolevel oltre ad essere piu' performante ha delle funzioni in piu' se ci fosse pilota che mi sa dare dei chiarimenti o consigli per migliorare l' efficenza di questa funzione ne sarei ben lieto. grazie a tutti ![]()
__________________ FUTABA 9 CH-SUPER-BLADE CX2-T REX 500-HK 500 t rex 450 sport - Goblin 380 mit brain | |
![]() | #5383 (permalink) Top | |
User Data registr.: 02-10-2011 Residenza: milano sud
entra nel setup in cui vuoi avere l'Autolevel (es setup 3), sezione GOV&LEVEL, quadro Autolevel li hai 4 sliders da impostare per ottenere la reazione voluta (se ci passi sopra con il mouse, c'è la spiegazione dettagliata)
__________________ bladebuster Gaui X7, Oxy 5, Oxy 4 max, Oxy 4, Oxy3, Oxy 2 | |
![]() | #5384 (permalink) Top |
User Data registr.: 29-09-2008
magari è una cavolata ma proverei ... che tipo di velocità hai nei servi? beginner o sport? anche io ho notato una certa lentezza ma avevo beginner... infatti mi sono riproposto di provare sabato con l'impostazione sport ![]() |
![]() | #5386 (permalink) Top |
User Data registr.: 28-10-2015 Residenza: Cermenate
| Governor esc MsH
Ciao, Ho aquistato e montato un Protos carbon stretch. Sono ora all programmazione del Brain e specificatamente sto cercando di capire come approcciare la finestra del governor. Osservo che: - lo ESC MSH ha la funzione governor attivata, come si legge nelle istruzioni - sul Brain c'e' una connessione per il governor - lo ESC non ha nessun cavetto supplementare per tale connessione Quindi: programmo il Brain o lo ESC? Trasmittente Spectrum DXi6, se dovesse centrare qualcosa. Grazie in anticipo per suggerimenti. ![]() ![]() ![]() |
![]() | #5387 (permalink) Top |
Inoltre nella schermata 4 setup trasmittente si chiede di modificare la corsa dei servi sulla radio in modo da ottenere + e - 100 sul pannello del Brain. Io ho esteso le corse dei servi al 125% ma ancora non riesco a raggiungere il 100. Credo quindi di non avere capito bene. Mi illuminate? Grazie ancora. |
![]() | #5388 (permalink) Top |
Per il governar sul protos se hai il regolatore stock yge MSH puoi usare sia il governar del regolatore in governar sotore, oppure lo disattivi e usi quello del brain. Per usare quello del brain ti serve un sensore di giri che si collega a 2 fasi del motore poi il cavetto che va dal sensore giri al brain nella porta GOV. Importante per usare il governar del brain avendo spektrum devi usare i satelliti e non la RX standard nella schermata dei servi controlla di non essere andato ad aumentare i dual rate, quelli che devi utilizzare sono gli end point / travel / EPA a seconda della radio per vedere le corse al 100% la velocità di risposta cambia in base al tipo di volo che scegli beginner sport 3d hard3d che la puoi comunque regolare nel menù avanzato indipendentemente alettoni ed elevatore. Aggiorna sempre software e firmare all'ultima versione
![]() | #5389 (permalink) Top | |
| non si finisce mai di imparare Citazione:
![]() | #5390 (permalink) Top | |
Strumenti discussione | |
Visualizzazione | |
