![]() | #111 (permalink) Top |
User Data registr.: 14-11-2008 Residenza: augusta
io ho chiesto quando è prevista la spedizione ew loro mi hanno risposto... Hi again No BeastX no stock mi sa che pure si sono innervositi dalla risposta... io l'ho ordinato l'8 maggio
__________________ VISION 50 COMPETITION - T-REX 600 L.E. - MSH PRÔTOS 500 - mini titan e325 SE - nine eagles kestrel 500 sx - blade msr |
![]() | #112 (permalink) Top |
User |
Sono riuscito a contattare Steffen Jungherz, uno degli sviluppatori di BeastX, e l'ho messo la corrente del malumore che circola. Lui mi ha risposto così: Hi Egidio, sorry, at the moment I'm tu busy to translate and read all these posts, perhaps you can make a (short) conclusion what the problem is. Most probably, I think, the actual problem is the delivery date of the MICROBEAST. Due to the fact, that I work for BEASTX and not for freakware, I'm not absolutly sure what the actual state of delivery is, but what I know is the following: Freakware in Kerpen (HQ) is STILL shipping MICROBEASTs. The last delivery was quite huge, so it takes some time until all orders are completly shipped. Here in germany holidays just started, so same work has to be done by less people, which is not always possible. If anybody gets angry, because freakware is not delivering in time, feel free to cancel the order at any time. Of course, we (BEASTX) and freakware are not happy with this situatuion, but we don't have more capacities. Developing the hardware, developing MBs software, developing the PC softwares, programming & calibrating the units, testing, support, and so on... takes a lot of time. We are working nearly all day and night, and we are trying really hard to satisfy everybody! But right now, not even all units have been shipped, so I would ask everybody to be a little bit more patient. Best regards, Steffen Jungherz
__________________ "Quanto più ci innalziamo, tanto più piccoli sembriamo a quelli che non possono volare" (F. N.) |
![]() | #113 (permalink) Top |
User Data registr.: 03-06-2006 Residenza: roma tor vergata
| scadenza
ma si io aspetto fino ad i primi di giugno....in finale è quella la data che mi hanno detto ![]() certo però non capisco, allora i primi venduti avranno bisogno dell'aggiornamento. e poi il link per collegarlo al pc dove si prende? non lo trovo,ho letto che potrebbe essere un semplice cavetto usb.....possibile??
__________________ ![]() ![]() ![]() ![]() ![]() |
![]() | #115 (permalink) Top | |
User | Citazione:
Personalmente, avendone già uno e trovandolo davvero ottimo, non ho problemi ad aspettare un mese: ne ho ordinato un altro venerdì scorso ![]() P.S. sono a pag. 36 del manuale. Tolte le immagini e altre cosetta varie che non necessitano di traduzione, ho ancora una 12ina di pagine.
__________________ "Quanto più ci innalziamo, tanto più piccoli sembriamo a quelli che non possono volare" (F. N.) | |
![]() | #116 (permalink) Top |
User Data registr.: 01-02-2007 Residenza: Tirano (SO)
Aiaaaa..la vedo lunga!!.. Dear Sir, all parts in stock only micro beast no stock an no deliver date we can ship all other parts today If you want. And you can cancell microbeast or we send it the microbeast when we have back in stock. Viele Grüße / Best regards Jens Friedrich World-of-Heli - "Wir lieben Helis"
__________________ RAVE ENV |
![]() | #117 (permalink) Top | |
User Data registr.: 28-11-2008 Residenza: Nei sogni
![]() | #118 (permalink) Top |
User | Cosa fare se ...
Per chi ha già il MicroBeast, ho tradotto un simpatico post. Cosa fare se ... 1... Il MicroBeast non funziona correttamente in volo? - Controllare tutto di nuovo e cercare il giusto settaggio del rotore e del piatto ciclico (punto J regolazione dei 6 °); se non è corretto, MB non funziona perfettamente. 2. ... Lelicottero risulta troppo morbido? - Aumentare il controllo del comportamento (punto B del menù parametri), o settarlo da radio (LED di stato blu). - Aumentare Pot. 1 fino a quando lelicottero oscilla 3. ... Impossibile aumentare a sufficienza il guadagno di coda? - Spostare la ball-link di un foro, verso lesterno del braccio del servo di coda 4. ... La velocità della coda non è costante (durante il volo)? - Aumento dei parametri del punto D del menù parametri. 5. ... La coda si muove su e giù durante i voli in velocità? - Diminuire il Pot. 1! Cè il rischio, però, di ritrovarsi al punto 2 La soluzione migliore è quella di usare un pad un po meno morbido. 6. ... Lelicottero sembra un delfino durante i voli in velocità, senza dare comandi? - Aumentare il parametro del punto C del menù di setup. 7. ... Lelicottero tende a rovesciarsi/rollare su un lato? - Prima di tutto verificare le regolazioni del piatto ciclico. - Ottimizzare il trimming del piatto ciclico attraverso il punto A del menù parametri - Eliminare vibrazioni! 8. ... Il MicroBeast non finisce la inizializzazione? - Può succedere con sistemi Spektrum; nel caso, rifare il binding. 9. ... L'elicottero sembra goffo e poco lineare durante il volo? - Verificare la regolazione dei 6°. - Nel caso in cui per il punto B del menù parametri si utilizza il settaggio da radio, non aumentare il Dual/Rate e gli endpoint oltre il 100%! 10. ... La reazione dellelicottero ai comandi di elevatore e alettoni non è sufficiente? - Leggete attentamente il punto L del menù di setup di nuovo e ottimizzate il movimento del piatto ciclico. 11. ... Dopo aver alimentato lelicottero, il LED di stato lampeggia rosso senza interruzione, e nulla più funziona? - E lindicazione che durante linizializzazione è stato riscontrato un sensore difettoso. Per circa 30 secondi dopo laccensione, il MB effettua i controlli sullo stato dei sensori e lelicottero deve essere immobile. Se linizializzazione non va a buon fine, le cause possono essere dovute al movimento dellelicottero, causato da voi stessi, o dal vento. - Se è certo che è possibile escludere quanto sopra, allora potrebbe trattarsi di un errore hardware! Contattare Freakware o BeastX, riportando lo stato del LED di stato. 12. Nonostante sia tutto ben settato, con variazioni importanti di passo la coda non resta ben ferma e/o lelicotterso si squote? - Controllare il passo collettivo! Se le variazioni sono massive, si avrebbe los tesso problema anche con la flybar (il sistema è più sensibile che con la flybar). 13. ... L'elicottero durante le piroette dondola e si scompone? - Controllare la direzione dall'ottimizzazione piroette (punto N del menù di setup)? - Cercare di stabilizzare con l'uso di Pot. 1. - Problemi di baricentro: verificare il baricentro dellelicottero! 14. ... il nuovissimo MicroBeast, non ancora montato sullelicottero, lampeggia solo rosso invece di inizializzasi? - Verificare esattamente il cablaggio tra Microbeast e ricevente. Sulla radio, deve essere impostato il mix meccanico del piatto ciclico (H1 Mode o 1 servo Mode)! 15 ... Cambiando il guadagno del giroscopio di coda dalla radio, il MB non reagisce coerentemente? - Controllare se il filo marrone del Guadagno del Gyrosopio è collegato correttamente sul pin del segnale e non su quello del negativo dellalimentazione (connettore capovolto!). Spero venga utile.
![]() | #119 (permalink) Top | |
![]() ![]() lo imparo a memoria in attesa della BestiaX. Certo,che se hai tradotto così bene anche il manuale,facciamo tutti festa. ![]()
__________________ RAVE ENV | |
![]() | #120 (permalink) Top | |
| ok Citazione:
__________________ ![]() ![]() ![]() ![]() ![]() | |
[Thread Ufficiale] BRAIN, Virtual Flybar System from MSH!! | RRRappy50 | Elimodellismo Sistemi Flybarless e Telemetria | 7275 | 14 giugno 24 21:08 |
