![]() | #861 (permalink) Top | ||
Ciao Tommy Data registr.: 15-10-2005 Residenza: Adro
Enjoy TOMMY | ||
![]() | #862 (permalink) Top | |
User Data registr.: 03-04-2010 Residenza: Novi Ligure
Grazie | |
![]() | #863 (permalink) Top | |
Moderatore Data registr.: 16-04-2007
Enabling Bank Switching on DX7 DX7 using the flight mode switch 1. Go to the system menu, scroll to the [INPUT SELECT] submenu and set GEAR to GEAR and AUX2 to INH. 2. Go to the normal menu, scroll to the [REVERSING SW] submenu and set 'ch 5' to NORM. 3. Scroll to the [SUB TRIM] submenu and set 'GEAR' value -75. 4. Scroll to the [TRAVEL ADJUST] submenu and set 'GEAR' upper and lower values to +100% and -100%. 5. Scroll to the [PROG. MIX1] submenu and set the following: GEAR -> GEAR RATE +75% 0% SW:F-S12 OFFSET: 0 6. Scroll to the [PROG. MIX3] submenu and set the following: GEAR -> GEAR RATE +100% 0% SW:F-S2 OFFSET: 0 7. Go to the system menu, scroll to the [INPUT SELECT] submenu and set GEAR to INH and AUX2 to F.MOD. You will now be set up with the following: Throttle Hold = Bank 1 Normal flight mode = Bank 1 Flight Mode 1 = Bank 2 Flight Mode 2 = Bank 3 Before flying, disconnect your motor and test your heli on the bench with your vbar connected to your laptop and verify that you can see the banks switching. Also, ensure that you have the vbar settings copied across all banks 0 to 3. If this is not done, you could loose control of the heli when switching to a bank that is not programmed. It's really useful when trying out different vbar settings during a single flight. Try it for yourself.
__________________ "C'è una forza motrice più forte del vapore, dell'elettricità e dell'energia atomica: la volontà." Albert Einstein | |
![]() | #869 (permalink) Top |
User Data registr.: 15-05-2008 Residenza: Vicenza
Appena montato il sensore Hyperion, perfetto!! Eccolo: eBay Italia - Aste online e shopping a prezzo fisso |
![]() | #870 (permalink) Top | |
Inviato dal mio GT-I9100 con Tapatalk 2
Cerco Mikado V-Stabi | sberla76 | Compro | 0 | 08 febbraio 13 15:37 |
mikado v-stabi | revo 3.3 | Elimodellismo Acrobazia | 15 | 23 gennaio 10 14:50 |
mta4 dubbi..problemi..soluzioni.!! | linus | Automodellismo Mot. Scoppio On-Road | 22 | 10 dicembre 07 07:49 |
