![]() | #6371 (permalink) Top | |
User Data registr.: 01-08-2008 Residenza: TORINO
| ![]() Citazione:
- Per il gyro col blocco di coda ok ( ma perchè non lo montano già in fabbrica ? Costa tanto...???) - Per la radio, scusate l'ignoranza ma una radio superiore .. cosa mi permette di più e come ?? Con la radio di scatola sudo di più a fare hovering o proprio ..... è quasi impossibile ? Ciao baracca1 | |
![]() | #6372 (permalink) Top | |
| ![]() Citazione:
E vivi ( e voli ) bene ??? | |
![]() | #6374 (permalink) Top | |
User | Citazione:
__________________ Saludos stefano Trex 700 LE-- Trex 500 esp--Trex 450 pro--Trex 250--tarot 450 carbon--gaui 425--PROTOS CARBON-- Tricopter kk fpv--Quadrocopter kk-- + futaba 10 CG | |
![]() | #6375 (permalink) Top | |
| ![]() Citazione:
ecco caratteristiche ...mi butto ? Vi sembra ok per circa 180 euro ? The latest ESky Belt-CP V2 is an upgrade version of the world famous ESky Belt-CP RC helicopter. With totally fresh apperance and new designs for the main rotor and tail rotor systems, the Belt-CP V2 increases the stability, powerful and accuracy of the helicopter as well as to give more direct control by the pilot. Include EVERYTHING TO FLY! Products Description: Completely assembled and tested at the factory, ready to fly out box! 120 degree ECCPM Control System High performance Heading Lock gyro is Capable of sport flying and 3D aerobatics Stainless steel flybar, main shaft and tail shaft 450 brushless motor, 25A brushless ESC and 3S 11.1V 1800mAh 20C Li-Po battery deliver incredible power and performance. Hold Rotation System Tail Belt Drive System High Inertial Main Blade High Efficiency Tail Blade Rear Tail Servo Stand High Rigidity Iron Main Shaft High Rigidity Aluminum Tail Boom Super Iron Landing Skids High Strength Carbon Fiber Tail Boom Support Set Specification: Main blade diameter: 680mm Tail blade diameter: 130mm Length: 640mm Height: 230mm Weight: about 670g (including EK1-0186 Li-Po) Motor gear: 10 teeth Main driven gear: 140 teeth Tail driven gear: 110 teeth Driven gear ratio: 14:1:5 Package included : 1 x ESky Belt-CP V2 Helicopter Body, All Electronics Installed, Ready-to-Fly 1 x 3800KV brushless motor (EK5-0006) 1 x 25A brushless speed controller (EK1-0350) 1 x ESky professional headlock gyro (EK2-0704 ![]() 4 x 7.5g Digital Servo (EK2-0508) NEW! 1 x ESky 6-channels PPM / CCPM Transmitter (EK2-0406F) NEW! 1 x ESky 6-channels CCPM Receiver (EK2-0420A) 1 x ESky 1800mAh 20C Li-Po Battery (EK1-0186) 1 x 7.4V & 11.2V Li-Polymer Battery Charger (EK2-0851) 1 x 100-240V AC Switching Adapter (EU, US/JP, UK, AU) We will choose the correct one for your country! 1 x Colourful English & Chinese Manual (incl. spare parts list) for RC Helicopter Ricordo a tutti quelli che mi vorranno consigliare in questa scelta finale che ricerco precisione di volo,hoverig senza slogarsi i pollici...,non mi interessano i tagliaerba... e sopratutto una felice progettazione e una buona ed economica riparabilità.. Vado ?????? Aiutatemi e poi non rompo più !! Grazie a tutti. | |
![]() | #6376 (permalink) Top | |
| ![]() Citazione:
ESky Honey Bee King 3 6-channels CCPM 3D Helicopter Ready-To-Fly Pack Coming Soon! (for Intermediate to Advanced Level Pilots) The latest ESky Honey Bee King 3 is an third upgrade version of the world famous ESky Honey Bee King RC helicopter series. With totally fresh appearance and new & simple designs for the main rotor and tail rotor systems, the Honey Bee King 3 increases the stability, powerful and accuracy of the helicopter as well as to give more direct control by the pilot. Include EVERYTHING TO FLY! Products Description: 120 degree ECCPM control system Completely assembled and tested at the factory, ready to fly out box! New High-tech 6-channel RC system High performance Heading Lock gyro is Capable of sport flying and 3D aerobatics Digital Sub-Micro servos and Micro Heading Lock gyro offer precise and powerful control Stainless steel flybar, main shaft and tail shaft 400 brushless motor, 25A brushless ESC and 3S 11.1V 1500mAh 20C Li-Po battery deliver incredible power and performance. Hold Rotation System and Auto Rotation System Tail Belt Drive System High Inertial Main Blade High Efficiency Tail Blade Rear Tail Servo Stan Specification: Main blade diameter: 600mm Tail blade diameter: 130mm Length: 550mm Height: 200mm Weight: About 390g Motor gear: 10 teeth Main driven gear: 110 teeth Driven gear ratio: 14:1:4.44 Package included : 1 x ESky Honey Bee King 3 Helicopter Body, All Electronics Installed, Ready-to-Fly 1 x 3800KV Brushless Motor (EK5-0005) 1 x 25A brushless speed controller (EK1-0350) 1 x ESky professional headlock gyro (EK2-0704 ![]() 4 x 7.5g Digital Servo (EK2-0508) NEW! 1 x ESky 6-channels PPM / CCPM Transmitter (EK2-0406F) NEW! 1 x ESky 6-channels CCPM Receiver (EK2-0420A) 1 x ESky 1500mAh 20C Li-Po Battery (EK1-0183) 1 x 7.4V & 11.2V Li-Polymer Battery Charger (EK2-0851) 1 x 100-240V AC Switching Adapter (EU, US/JP, UK, AU) We will choose the correct one for your country! 1 x Colourful English & Chinese Manual (incl. spare parts list) for RC Helicopter Seguito post precedente sfrutto ancora la Vs esperienza per raffrontare questo al BELT CP2.. oltre alla dimensioni potrebbe essere ok anxhe questo considerando che costa 160 euro e che preferirei restare in una "misura" più piccola possibile...fermo restanto anche il volato con poco vento... Ancora grazie tutti ! Ciao | |
![]() | #6377 (permalink) Top |
User Data registr.: 02-09-2008
Ciao io sono nuovo nuovissimo del forum quindi magari aspetta anche i consigli dei piu esperti cmq io ho provato entrambi belt cp e king 2, e da quel poco che ho provato il belt cp risulta molto piu stabile ciauuuuuuuuu |
![]() | #6378 (permalink) Top |
User Data registr.: 24-08-2008 Residenza: Prov. Milano
la versione v2 del belt-cp non sarà disponibile fino alla fine di novembre, almeno così si vede dallo shop esky, quindi...
__________________ T-rex 100X - T-Rex 450S Full Upgrade - T-Rex450SE V2 - T-Rex 600N - Lama v4 - Blade CX2 - Belt-CP - Drift King JXD 340 - Futaba7C |
![]() | #6379 (permalink) Top | |
User | Citazione:
![]() | #6380 (permalink) Top |
Ma quindi il belt-cp v2 è già acquistabile da qualche parte ? Se si mi date link ? Perchè io trovo solo per i preordini. Grazie ![]()
Belt CP aiuto | Chris | Elimodellismo Principianti | 10 | 26 giugno 10 11:13 |
Belt cp potenza | Chris | Elimodellismo Principianti | 27 | 22 aprile 10 02:19 |
E-sky Belt Cp | gquatro | Elimodellismo Motore Elettrico | 7 | 22 ottobre 07 14:42 |
INTERFERENZE e BELT-CP | bertozzi_marco | Elimodellismo Motore Elettrico | 10 | 06 ottobre 07 13:05 |
E-Sky Belt CP | gquatro | Elimodellismo Principianti | 1 | 06 dicembre 06 14:20 |
