Vecchio 26 febbraio 05, 01:10   #1 (permalink)  Top
Data registr.: 01-02-2005
vorrei comprare una radio per usare per ely però non so quale scegliere ho provato a mandare un email ad helihobby e ho avuto una risposta tradotta con da me con un traduttore on line (no speak english) e non ciò capito una mazza, allora chiedo a voi quale è meglio secondo voi fra questi 2 modelli?
1) Hitec 6 Channel Transmitter, Charger, Crystal
All Micro Helis
Laser 6 loaded with features like Elevon and V-tail Mixing & Dual Rates. Excellent choice for a feature-packed TX.
Elevon and V-tail mixing
EPA on Channel 3
6 channel FM transmitter
All channel servo reversing
ATV on ch. 1 and 2
Ch. 1 & 2 Elevon mixing
Ch. 2 & 4 V-tail mixing
5 LED power meter
Trainer Capable
Ergonomic case
2)Hitec Optic 6 Transmitter ( Standalone or with Servos / RX)
All Helis
The Optic 6 FM/Q-PCM six channel computer aircraft and Helicopter radio system is available with power plane, sailplane, Heli programming, and an 8 model memory. This sophisticated computer radio offers great features like assignable switches, throttle lock, dual timer, and two slider switches. With a shift select function and Spectra synthesized capability, the new Optic 6 is one of the most flexible six channel systems available. It is a powerful yet economic radio system which is available as a standalone unit or with complete servos and receiver.
- 6 channel, FM / Q-PCM,
- 8 Model Memory and Spectra compatible available
- Digital trims as well as Model name
- Dual timer, Switch Assignability
- EPA, Dual rates, Exponential, Fail safe
- Throttle lock and Engine Cut
- Three flight modes
- 2 open mixes
- Gyro gain
- Throttle curves and Pitch Curves
- Revo mix
- CCPM mixing and CROW Mixing
- Camber and Reflex
System is available in:
- Standalone Unit: Hitec Optic 6 FM TX with Spectra Module
- Complete: Hitec Optic 6 FM TX with 4 HS-325HB servis and a 8ch RX
volevo sapere
se sono tutti e 2 digitali
se qualcuno sa per noi italiani arriva con le frequenze consetite
e se a quanto ho capito ( hitec) arriva coi servi e l'altro?....
vi metto anche le foto
io lo userei esclusivamente per ely elettrici thank
tonysch non è collegato   Rispondi citando
Vecchio 26 febbraio 05, 01:36   #2 (permalink)  Top
S_Ciambra
Guest
Messaggi: n/a
Non acquistare radio all'estero, non sono omologate per l'uso in Europa e andresti incontro a guai seri.
  Rispondi citando
Vecchio 26 febbraio 05, 01:58   #3 (permalink)  Top
td_2200
Guest
Messaggi: n/a
può interessarti una Eclipse 7 QPCM - FM completa ovviamente di ricevente?...C'è ancora la pellicola protettiva sul display....
Vorrei passare alla mx22
  Rispondi citando
Vecchio 26 febbraio 05, 12:34   #4 (permalink)  Top
a S_Ciambra
grazie per il consiglio lo sospettavo ma non avevo la certezza
a td_2200
mi dici a quanto
Vecchio 26 febbraio 05, 14:28   #5 (permalink)  Top
td_2200
Guest
Messaggi: n/a
190€ trattabili...radio nuova....
ha solo un piccolo segno su un lato vicino ad uno stick...
come venditore puoi vedere i commenti di fabio1963 nel thread "vendo cumulus 2000"
Fammi sapere ok?
  Rispondi citando
Vecchio 26 febbraio 05, 19:06   #6 (permalink)  Top
td
ti ho mandato un email
Vecchio 26 febbraio 05, 19:36   #7 (permalink)  Top
L'avatar di MIRICOLO
Data registr.: 27-11-2004
Se vuoi acqustare una radio devi prederla una sola volta e buona io volevo prendere la eclipse 7 me lo hanno sconsigliato, perche ha pochi programmi per ely e pochi punti sul revo mix importante per i mini ely.Io ho preso la futaba 9cp ff9 e vero che costa un po pero é una radio professionale
MIRICOLO non è collegato   Rispondi citando
Vecchio 26 febbraio 05, 21:46   #8 (permalink)  Top
ciao miracolo
mi dici dove l'hai presa così so + o - la spesa da fare ?
Vecchio 27 febbraio 05, 00:42   #9 (permalink)  Top
lo comprata nella mia citta perche' comprarla on-line è un rischio.
io lo pagata € 600 completa la nuova versione con 12 programmi 4 servi la ricevente + 2 batterie una per la rx e la tx + caricatore.
Vecchio 27 febbraio 05, 01:38   #10 (permalink)  Top
S_Ciambra
Guest
Messaggi: n/a
Utilizzando un giroscopio con blocco della coda il Revo Mix si disabilita e quindi diventa una funzione della quale si può fare a meno.
  Rispondi citando
COMPRARE UNA VERA RADIO....(a cosa dare priorità???) taurusbond74 Radiocomandi 54 30 agosto 08 10:02
comprare un O.S. hangar_1 Aeromodellismo 18 17 novembre 07 22:54
Comprare EPP !!! Eaglista Aeromodellismo 14 26 settembre 07 00:31
Comprare la radio all'estero? Silvagni Radiocomandi 3 03 maggio 07 19:39
Non so che comprare!!!!!! xxxnt Aeromodellismo Volo Elettrico 20 30 novembre 06 22:33
Tutti gli orari sono GMT +2. Adesso sono le 13:17.
