27 aprile 09, 21:25 | #1 (permalink) Top |
User Data registr.: 07-12-2008 Residenza: Roma
| Hs-82mg Vs Hs-65mg
su un piatto tipo CCPM non so di un T-Rex 450 ad esempio cosa mettereste tra i due? io sceglierei il primo come coppia e velocità, costa anche il 30% di meno dell'altro. che dite?? ******* Servo Specifications: HS-82MG Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 3-5 Volt Peak to Peak Square Wave Operating Voltage: 4.8-6.0 Volts Operating Temperature Range: -20 to +60 Degree C Operating Speed (4.8V): 0.12sec/60° at no load Operating Speed (6.0V): 0.10sec/60° at no load Stall Torque (4.8V): 38.8 oz/in. (2.8kg.cm) Stall Torque (6.0V): 47.2 oz/in. (3.4kg.cm) Operating Angle: 40 Deg. one side pulse traveling 400usec 360 Modifiable: No Direction: Clockwise/Pulse Traveling 1500 to 1900usec Current Drain (4.8V): 8.8mA/idle and 220mA no load operating Current Drain (6.0V): 9.1mA/idle and 280mA no load operating Dead Band Width: 8usec Motor Type: 3 Pole Ferrite Potentiometer Drive: Direct Drive Bearing Type: None, outer case serves as bearing Gear Type: 4 Metal and 1 Nylon Connector Wire Length: 6.29" (160mm) Dimensions: 1.17" x 0.47"x 1.16" (29.8 x 12 x 29.6mm) Weight: 0.66oz (19g) *********** Servo Specifications: HS-65MG Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 3-5 Volt Peak to Peak Square Wave Operating Voltage: 4.8-6.0 Volts Operating Temperature Range: -20 to +60 Degree C Operating Speed (4.8V): 0.14sec/60° at no load Operating Speed (6.0V): 0.11sec/60° at no load Stall Torque (4.8V): 25 oz/in. (1.8kg.cm) Stall Torque (6.0V): 31 oz/in. (2.2kg.cm) Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: No Direction: Clockwise/Pulse Traveling 1500 to 1900usec Current Drain (4.8V): 5.3mA/idle and 400mA no load operating Current Drain (6.0V): 6.6mA/idle and 500mA no load operating Dead Band Width: 4usec Motor Type: 3-Pole Neodynium Magnet Potentiometer Drive: Indirect Drive Bearing Type: Top Ball Bearing Gear Type: Karbonite Gears Connector Wire Length: 6" (150mm) Dimensions: 0.92" x 0.45"x 0.94" (23.6 x 11.6 x 24mm) Weight: .39oz. (11.2g)
__________________ Sbagliare è umano, perseverare è diabolico!! |
HS 81MG o HS 65MG? | antosamp | Radiocomandi | 4 | 11 gennaio 09 00:00 |
hs 65hb - hs 65mg | pterigio | Elimodellismo Principianti | 3 | 09 novembre 06 13:05 |
