16 gennaio 09, 08:13 | #13 (permalink) Top |
User Data registr.: 20-05-2008 Residenza: dintorni di torino
| ahhhh per i prezzi indubbiamente, io personalmente, tranne un chrger urgente, non ho mai comprato nulla in Italia. Le 3 spektrum che ho sono USA e sono molto molto piu' potenti delle nostre AUTO LIMITATE, x me che al campo vado poco, non interessa la certificazione e nemmeno fare le gare, quelle le facciamo tra di noi |
17 gennaio 09, 01:23 | #14 (permalink) Top |
User Data registr.: 28-11-2008 Residenza: Nei sogni
| consigli
Sempre girovagando per il web ho trovato dei settings aggiuntivi per dx6i e blade400 : beginers level d/r - expo pos 0 100% expo as req" (with expo + values numb the controls - values sharpen them)+20% is a good start point for beginers pos 1 80% expo as req" travel adjust 100% on all exept rudder=90% all sub trims 0 (perfect mechanical setup! ) gyro sw=gyro pos 0 73% pos 1 64% normal throttle curve .................. or alternate curve pos L 0%......................... pos l 0% pos 2 23% .................. pos 2 60% pos 3 43%.................. pos 3 85% pos 4 67%.................. pos 4 85% pos h 100% .................. pos 5 85% stunt pos L 85% pos 2 85% pos 3 85% pos 4 85% pos H 85% you can up these all if you want higher head speed but 85% gives a nice speed for ff figure 8s etc ( will need higher for stall turns loops etc) hold 0.5% pitch curve norm pos L 35% pos 2 43% pos 3 50% pos 4 75% pos H 100% this will give lift off about mid way between half/3 quarter stick) stunt posL 0% pos2 25% pos3 50% pos4 75% posH100% hold 0%25%50%75%100% swash mix airl -75% elv -75% pitch +85% channel reverse ...(swash mix and channel reverse will need tweeks for those that have replaced servo's) thro N airl R elv N rudd R gyro N pitch N swash set to ccpm 120 degree's ( if your going to use these settings for phoenix flight sim also.. start a new model memory copy the settings over and set the swash type to normal 90 degree's 1 servo) throttle cut inh dr/combi inh timer set as req .. switch=throttle cut power A-EU 328 for more advanced pilots the stunt throttle curve can be altered to 100% or made into a "v" curve to your own preference Questi dovrebbero esser settaggi per principianti, siccome non ho ancora potuto metter in volo il mio, cosa ne pensate? |
17 gennaio 09, 09:29 | #15 (permalink) Top | |
che come tutti i settaggi della CASA MADRE sono solo di riferimento, sei tu in base a cio' che vuoi a come lo usi dove lo usi CHE DEVI PERSONALIZZARE QUESTE IMPOSTAZIONI comunque su diversi siti trovi impostazioni DA CATTIVO e da VOLATO occhio al manico........se esageri non lo tieni piu' | |
18 gennaio 09, 18:28 | #16 (permalink) Top | |
se sai hai dei link postali pure qui sopra penso potrebbero esser utili non solo a me ! | |
26 gennaio 09, 08:29 | #20 (permalink) Top | |
Sospeso | Citazione:
Eflite Blade 400 | |
Club EFLITE BLADE CX 2 - info;settaggi;modifiche;consigli;suggerimenti | OlandeseVolante | Elimodellismo Micromodelli | 1000 | 07 settembre 15 15:35 |
Club E-Flite Blade MCX ........................ settaggi, upgrade e consigli ........ | fulvico | Elimodellismo Micromodelli | 1025 | 27 marzo 13 13:27 |
blade 400 3D | miomap1 | Elimodellismo Principianti | 36 | 17 settembre 10 14:37 |
Club Blade CP PRO.......... | Mongolfino | Elimodellismo Principianti | 125 | 01 febbraio 10 16:05 |
Non è il Club Zoom 400! (ma se mi aiutate... | Mongolfino | Elimodellismo Motore Elettrico | 30 | 08 luglio 08 08:29 |
