21 gennaio 12, 12:51 | #32 (permalink) Top |
User |
preso da FB: "Very important Message for T-rex 700 DFC rotor head. Regarding Align's recently released 700DFC rotor upgrade assembly, there has been an instance reported customer where a loosely tightened bolt on the pitch link assembly caused high frequency vibration, resulting in material fatigue and bolt breakage from where the thread start. Due to the concern that this breakage can lead to unforeseen safety issue, Align has modified the grip linkage arm design of both 700DFC and 600DFC rotor upgrade assembly. In addition, the bolt has been replaced with one made from CNC'ed high carbon steel material for improved rigidity and strength, effectively avoids bolt breakage issue. Caution: Please do not fly before the 700 DFC new parts have replaced. We deeply apologized for all the inconvenience caused. For customers who have already purchased the first version of Align 700DFC head upgrade set, please bring the main blade grip arm and the screw to where you purchased or the local distributors to exchange the newly designed screws and grips. This replacement process will be start on 2012/01/21. If you have any question, please contact with your distributors or mail to align@ms.align.com.tw"
__________________ Goblin 700 Competition |
21 gennaio 12, 23:03 | #35 (permalink) Top |
User Data registr.: 03-01-2009 Residenza: Udine
| DFC Ok
Ciao a tutti. Oggi ho volato con il mio T-Rex 700N, con la nuova testa DFC. 4 voli in tutto di 3D: 2 voli con giri rotore a 1700 e 2 voli a 1950. Nessun problema.....
__________________ T12FG Logo 600 --- Goblin 700 --- Multirore (FPV-NAZA-GPS-GoProHero2) Ultima modifica di Lupen ec135 : 19 marzo 12 alle ore 01:39 |
22 gennaio 12, 01:20 | #37 (permalink) Top | |
Comunque oggi niente problemi, ma provvederò subito x l'aggiornamento appena possibile.
__________________ T12FG Logo 600 --- Goblin 700 --- Multirore (FPV-NAZA-GPS-GoProHero2) | |
24 gennaio 12, 17:56 | #40 (permalink) Top | |
User Data registr.: 14-07-2008 Residenza: mestre (VE)
sono riuscito ad atterrare di carrello limitando i danni.(carrello ed una pala rotti + il menzionato linkage e relativo uniball).. 13° di passo e 2050 giri, pale da 690. leggendo qs post riguardo le vibrazioni ad alta frequenza prodotte, mi viene qualche dubbio... ciao
__________________ http://snipurl.com/27ih6f Ultima modifica di pirango : 24 gennaio 12 alle ore 18:03 | |
