![]() | #11 (permalink) Top | |
User | Citazione:
![]() | #12 (permalink) Top | |
Guest
Messaggi: n/a
Forse dovresti leggere meglio i miei posts.... Poi in ToFlyRc nel medesimo thread ti avevo fatto una domanda precisa sul bilanciamento din. del ruotino, per capire se lo avevi fatto, in quanto a me fa una cosa simile sul TRex 450 dopo averlo bilanciato. Ma non mi hai risposto. Come faro' io di seguito con i tuoi posts | |
![]() | #13 (permalink) Top | |
User | Citazione:
Mamma mia...... ![]() | |
![]() | #15 (permalink) Top |
Guest
Messaggi: n/a
| Hai controllato i cuscinetti reggispinta delle pinze di coda ??? Per quanto riguarda il 611 ti consiglio vivamente di utilizzarlo alla percentuale di gain consigliata cioè 35÷37% se non vuoi rischiare di "arrostire" il 9256 !! ( ti allego qua la spiegazione del settaggio di Jason Krause ) I have played with the 601 setup for some time now and basically found that the simple setup works the best for me. 1. Leave almost all of the menus at the stock setting (the default settings are in the book) except what is mentioned below. 2. Adjust your tail linkage so that your tail servo limit setting (last menu) is over 100% NOT under. Set the travel equally for both A & B at around 110% to 120%. Setting the limits under 100% can reduce the life of the servo. 3. Setup your radio however you like but make sure the gain on the first screen that shows up after the gyro initializes reads 35-37% MAX this is very important. The 601 will not wag until the gain is very high but if the gain is too high and you stop the tail very abruptly you may damage your heli. High Gain can also reduce the life of the tail servo. 4. 3D or FAI Mode? Try both modes see what you like. FAI mode tends to stop and start yaw/tail movements very precisely and crisp. 3D mode seems to add a little "softening" when the yaw/tail motion is stopped rapidly. 3D mode also can help make the pirouette rate more consistent while moving through fast flight. I have flown every available gyro made today and the 601 by far has the best performance yet....enjoy it! 601 e 611 a livello software sono IDENTICI !! Giacomo |
![]() | #16 (permalink) Top | |
Guest
Messaggi: n/a
Accertati di non aver attivato (per sbaglio) sulal radio qualche mix che agisca con la coda. Poi la prima cosa che ti consiglio di fare è di leggere direttamente sul display del giroscopio il valore di gain effettivamente impostato, Se non è stata fatta una corretta programmazione della TX i valori che leggi sulla radio potrebbero non corrispondere a quelli sul giroscopio. Considera che, se la meccanica dell'eli è in ordine, i valori che devi avere non devono essere inferiori o maggiori rispettivamente del 28% 35%. Purtroppo con il GY611 non si nota facilmente se la sensibilità impostata è troppo elevata per cui a volte si eccede nella percentuale. Poi apri il manuale del GY611 e vai all'ultima pagina per controllare se tutti i settaggi sul giro corrispondono ai parametri indicati in quella pagina, praticamente ti accerti che tutti i valori siano quelli di default. Se il problema persiste ulteriormente vai nel menù D1D (control delay D) e prova ad aumentare la percentuale del 10% per volta sia per il lato Dx che Sx. Nel caso in cui non risolvi il problema in questo modo, molto probabilmente potresti avere i cuscinetti sul rotore di coda rovinati. | |
![]() | #17 (permalink) Top |
User |
Come ha detto già Giacomo, controllo che i cuscinetti reggispinta nelle pinze del rotore di coda abbiamo un leggerissimo gioco nelle rispettive sedi.......lo stesso identico problema è capitato/capita con alcune pinze del rotore di coda del Synergy N9.......... Ciao
__________________ |
![]() | #19 (permalink) Top | |
User Data registr.: 19-01-2005 Residenza: 33170 e dintorni
esatto! servo? come sei con l'alimentazione della tx? ricordo che il 9256 non digerische i 6 volt. ciao dex1 | |
set up gy611 | mod_bucarelli | Elimodellismo in Generale | 6 | 21 settembre 07 20:30 |
problema gy611 | granmaster | Elimodellismo Acrobazia | 1 | 14 marzo 07 22:55 |
problema gyro GY611 | marcofly82 | Elimodellismo Principianti | 0 | 28 dicembre 06 18:32 |
help settaggio gy611 | granmaster | Elimodellismo in Generale | 12 | 12 dicembre 06 19:23 |
