01 gennaio 14, 19:13 | #1021 (permalink) Top |
User Data registr.: 17-02-2012 Residenza: Taranto
ti riporto i segnali che da l'esc già postati da altri membri del forum Segnali di errore dellesc YGE Trouble shooting: 1 Beeps/flashes: Incorrect throttle curve for Gov.-Store Mode 2 Beeps/flashes: Under-voltage identification 3 Beeps/flashes: Temperature rise warning 5 Beeps/flashes: Receiver signals failed 6 Beeps/flashes: start up failed |
01 gennaio 14, 19:49 | #1022 (permalink) Top | |
User Data registr.: 07-09-2013 Residenza: Cerreto D' Esi
Inviato dal mio GT-I9100P utilizzando Tapatalk | |
01 gennaio 14, 20:28 | #1023 (permalink) Top | |
User Data registr.: 12-04-2011 Residenza: Pertusio(TO)
__________________ Mikado LOGO 500 V-Bar 5.3 Pro mini | |
01 gennaio 14, 20:34 | #1024 (permalink) Top |
riporto tutto il paragrafo Trouble shooting: 1 Beeps/flashes: Incorrect throttle curve for Gov.-Store Mode 2 Beeps/flashes: Under-voltage identification 3 Beeps/flashes: Temperature rise warning 5 Beeps/flashes: Receiver signals failed 6 Beeps/flashes: start up failed Any error that happens during flight is signaled by the ESC after motor stop (flashing LED and beeps). In case the ESC reduces power completely because of low-voltage, critical temperature, receiver signals lost or the startup failed, the error levels 2,3,5 and 6 will be stored permanently (crash analysis). To reset these errors connect the ESC to the battery with the stick at full power and/or with 100% throttle pre-selection (throttle curve), and disconnect it after the interval beep. Please leave the stick at full power, while disconnecting, otherwise you activate the RC-Setup. Alternativly the errors can be cleared by connecting the ProgCard. With an activated brake, the error is only signaled after a tension reset or in wind milling position. |
01 gennaio 14, 20:50 | #1026 (permalink) Top |
User Data registr.: 11-06-2008 Residenza: otranto
Il mio non fa suonare più il motore, e fa uno strano bzz silenziosissimo, :mad: Inviato dal mio HTC One utilizzando Tapatalk
__________________ protos 500 stretch. trex 600 esp 12s. compass 7hv minitaitan defunto,wuolchera 60 idem |
01 gennaio 14, 21:24 | #1028 (permalink) Top | |
User Data registr.: 12-02-2008
Vai piano? Perchè il 120 yep non basta. Il 120 ha questa lettera dietro: Cioè, sono 120 AmpeLe... I cavi dall'esc alla lipo sono più piccoli che sul 150 e scaldano di brutto. Cali vertiginosi di giri. A meno di andare piano, in passeggiata. | |
02 gennaio 14, 07:59 | #1029 (permalink) Top | |
Hanno clonato Fast Lad | Speedlite | Elimodellismo in Generale | 15 | 18 marzo 12 11:48 |
Sti cinesi.................................... | maddriver967 | Aeromodellismo Ventole Intubate | 23 | 06 agosto 10 09:26 |
Hanno clonato il Baronerosso! | marcosvizzero | Elimodellismo in Generale | 21 | 13 ottobre 09 19:03 |
Stì Cinesi.... | Albytech | Batterie e Caricabatterie | 8 | 12 dicembre 05 09:32 |
