Vecchio 03 ottobre 11, 19:06   #321 (permalink)  Top
Data registr.: 02-07-2011
Help Scorpion 4035 12N8P 6 Turn Delta 800Kv
Hello
I´m Portuguese, and can´t speak italian....Sorry!
I have a Scorpion 4035 wich is a 12N8P 6 turn Delta Winding, wich has 800Kv.
I would like to keep the Rpm, or increase it to 900Kv more or less in a YY winding with 3+3 1.8mm turns per tooth...The problem is that all the winding schematic i see in the net is for 12N10P and not 12N8P....Is the winding chematic the same, or it´s different?
Is it possible for a good working motor a YY winding in a 12N8P motor?
Very Best Regards and thanks for your help, everyone!
gracing non è collegato   Rispondi citando
Vecchio 03 ottobre 11, 20:20   #322 (permalink)  Top
L'avatar di 7.62x51
Data registr.: 09-07-2011
Residenza: Mongardino d'Asti
ce l'ho anch'io....
Fabio
Henseleit TDR; Synergy E7; Hirobo EMBLA.
7.62x51 non è collegato   Rispondi citando
Vecchio 03 ottobre 11, 20:39   #323 (permalink)  Top
Gmauro
Rewound Scorpion HK5025 6+6 1.4mm YY 515KV, with some help from GMAURO
....New Motor New Heli..
Modifica - Riavvolgimento Dei Motori Brushless-scorpion-5025-6-6-1.4yy-12s-5100mah-65c.jpg
Vecchio 03 ottobre 11, 21:46   #324 (permalink)  Top
Rivenditore - GMauroBrushless
L'avatar di GMAURO
Data registr.: 22-07-2005
Residenza: Piacenza
Originalmente inviato da gracing Visualizza messaggio
Hello
Gerardo.... are you? A new motor ready for rewind?
For find this schema please see the following link
12N8P YY winding schema
The YY winding is possible for all N-P combination (but not with all the same schema), this 12N8P have only a little more difficult to jump with wire from 1° to 4° toot, from 2° to 5° etc..... but with a patience is possible.
But why you whant use this motor for high Kv? for very big wire diameter or only because 8P motor done high Kv?
ROCK 'N ROLL!
www.gmaurobrushless.it
GMAURO non è collegato   Rispondi citando
Vecchio 03 ottobre 11, 23:24   #325 (permalink)  Top
Scorpion motor
Hello GMAURO
I hope everything is good with you.....
i have this motor, the scorpion 4035 in a boat, but i want less heat, and more power....i have 1.8mm wire that i want to rewire...
Check this video :
10S Rigger Portugal - YouTube
But i want to change the Delta winding to YY......
From the link that you sent me the stator dont work in pairs has in normal 12N10P, is this normal?
Mine Motor has 6 turn Delta with 800Kv...If i put 3+3 turn i will have 800*1.15= +/- 920Kv..am i right?
Best Regards GMAURO
Vecchio 03 ottobre 11, 23:47   #326 (permalink)  Top
L'avatar di GMAURO
Residenza: Piacenza
Hello GMAURO
Check this video :
Best Regards GMAURO
Yes this schema is correct. This is only possible for 12N8P YY. If you rewind with tooth in pair motor don't work because the esc don't found the correct sincronously on "free" fase.
The calculation of Kv is ok..... Good work and post your result if you whant!
Pics of your boat?
Bye Mauro
ROCK 'N ROLL!
Vecchio 04 ottobre 11, 00:05   #327 (permalink)  Top
boat pics
Hello GMAURO..
Here follows...(i know this is a Heli Forum)...hope you don´t mind...
[IMG][/IMG]
Best top speed in oval 123km/h
By the way, can i put 3 turns in one tooth, and 4 turns on the other ttoh?
If yes, should they be desphased 90º , am i right..that should give about 3.5 turn?
Vecchio 04 ottobre 11, 03:17   #328 (permalink)  Top
L'avatar di RRRappy50
Data registr.: 30-05-2006
Residenza: Marte
Immagini: 4
GMAURO...the international works coming soon?
Futaba T18SZ
Shit-nergy N7
In fase di montaggio...l'incubo ha una sua identità...
RRRappy50 non è collegato   Rispondi citando
Vecchio 04 ottobre 11, 08:37   #329 (permalink)  Top
L'avatar di GMAURO
Residenza: Piacenza
Hello GMAURO..
[IMG][/IMG]
My test on 12n8p confirm the calculation with this schema (kv Of turn delta x 1.15 done yy kv...) please test and post your results. Good work.
ROCK 'N ROLL!
Vecchio 04 ottobre 11, 08:39   #330 (permalink)  Top
L'avatar di GMAURO
Residenza: Piacenza
Originalmente inviato da RRRappy50 Visualizza messaggio
No no rappo, é solo un momento comicità dovuto al mio pessimo inglese...
ROCK 'N ROLL!
Modifica motori Easy copter Snail Elimodellismo Principianti 7 06 giugno 07 00:20
Modifica regolatore motori a spazzole. luca24372 Circuiti Elettronici 5 05 febbraio 07 09:39
Modifica MM2001 per Motori Bipolari saviothecnic CNC e Stampanti 3D 6 26 maggio 04 17:15
Tutti gli orari sono GMT +2. Adesso sono le 03:00.
