Vecchio 02 gennaio 10, 14:08   #11 (permalink)  Top
L'avatar di criasso
Data registr.: 06-12-2008
Residenza: novafeltria (rn)
Voltage for this calculation (avg):3,6075/cell with a total of 21,645
Nominal voltage: Spoolup RPM 100% throttle no governor (22,2v): 2412
Avg RPM you will see with 100% throttle and no governor: 2263
Max normal bogging applied you will see RPM at: 1999
(this number should be the minimum if your motor & battery is up for the challenge)
Spoolup with Governor @ 65%: 2033
Spoolup with Governor @ 75%: 2153
Spoolup with Governor @ 85%: 2272
il pignone da fastlad..ciao
criasso non è collegato   Rispondi citando
Tutti gli orari sono GMT +2. Adesso sono le 03:02.
