![]() | #41 (permalink) Top | |
User Data registr.: 04-05-2008 Residenza: Barlassina-milano nord
Pollici, pollici.......però che sound il motore! ![]()
__________________ " Andrea" GAUI X5 FES, Trex 500/AS350, AngelFighter F-35,F6f Hellcat ,Piper 2350 ,ExtremeFlightMXS64", Fly Baby , RedArrows EDF JET...YAK 1050EPP., F109, Bmw 1/10, Buggy 1/16 | |
![]() | #42 (permalink) Top |
User Data registr.: 05-01-2009 Residenza: sassari
io continuo ad avere gli occhi a mandorla...... ![]() allora vi dico la mia: faccio 3d volo tutti i giorni e spacco anche parecchio..... qusto è il mio ragioamento e cosa ne penso premesso che il mio primo modello era un trex 450 se gf originale. ieri ho fatto un'ordine: SKU Description Qty STATUS GT500-051204 HK-500GT Ball Bearing 12 x 5 x 4mm 1 Reserved HK-500-124 HK-500GT Carbon Fiber/Alloy tail s 2 Reserved GT500-243 HK-500GT Carbon Tail Support Rod 2 Reserved GT500-137 HK-500GT Feathering Shaft 3 Reserved GT500-139 HK-500GT Landing Skid 2 Reserved GT500-128 HK-500GT Main Gear Assembly 3 Reserved GT500-104 HK-500GT Metal Flybar Control Arm 2 Reserved GT500-101 HK-500GT Metal Main Rotor Head Set 2 Reserved GT500-103 HK-500GT Metal Flybar Seesaw Hub 1 Reserved GT500-126 HK-500GT Metal Tail Linkage Rod Fi 1 Reserved GT500-133 HK-500GT Canopy Spinner 2 Backorder GT500-211 HK-500GT Carbon Fiber Main Blade ( 2 Backorder GT500-138 HK-500GT Main Shaft 3 Backorder GT500-141 HK-500GT Skid Nut 1 Backorder GT500-142 HK-500GT Tail Boom 3 Backorder GT500-107 HK-500GT Metal Wash-out Control Ar 1 Reserved GT500-135 HK-500GT Tail Blade 2 Reserved GT500-136 HK-500GT Tail Drive Gear Shaft 5 Reserved GT500-109 HK-500GT Stabilizer Bar 2 Reserved HK5027 HK-T500 Tail Rotor Holder 2 Reserved HK5035 HK-T500 Linkage Rod 2 Reserved GT500-210 HK-500GT Stabilizer Blade 2 Reserved GT500-105 HK-500GT Metal Stabilizer Control 1 Reserved GT500-061204 HK-500GT Ball Bearing 12 x 6 x 4mm 1 Reserved GT500-081605 HK-500GT Ball Bearing 16 x 8 x 5mm 1 Reserved GT500-040904 HK-500GT Ball Bearing 9 x 4 x 4mm 1 Reserved GT500-122 HK-500GT Metal Tail Rotor Control 1 Reserved Shipment Air Parcel (Italy) up to 2.0kg $33.73 Taxes $0.00 Total $256.92 Credit Total circa 180 euro......tutto di piu 3 corone 5 alberini 2 paia di pale in carbonio etc etc.....comprate in italia gli stessi pezzi e fatemii il conto. ![]() ora fate quello che volete.....io volo tanto mi diverto monto smonto ,...frena filetti a 1000 e giu a volare......per pochi euro se poi qualcuno crede che sia meglio comprare batterie di marca perche la telemetria non so cosa o i pezzi originali...io sono con voi...non venite a dirmi pero che batterie turnigy o rinho non vanno bene perchè sono stronzate.... poi chi vola veramente purtroppo cade di frequente...quindi capita anche che le batterie nell'impatto si spacchino totalmente.....quindi cosa facciamo: tu ne compri una con 150 euro e dopo un volo si rompe cosa fai? io ne compro 6.... i ricambi sono identici.....e il rapporto è ottimo sapete quanto sono 29$ circa 20 euro.... HobbyKing Online R/C Hobby Store : HK-450 CCPM 3D Electric Helicopter Kit $29.99 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() | #43 (permalink) Top | |
User Data registr.: 15-01-2009 Residenza: napoli
Guarda qui:CY Model RC Shop Online 53 Dollari, circa 35 euro ![]() Spedizione compresa e parti in metallo ![]()
__________________ Dragon fly 4 Mini titan 325 Max-z Kinetic 50 nitro fuso augusta A109 Mini Titan Se Nine eagles solo pro ![]() Bixler 1400 1.1 hubsan x4 led | |
![]() | #44 (permalink) Top |
Sospeso |
sempre tornando ai CLONOZZI io consiglierei di prendere solo la meccanica, l'elettronica fa ESTREMAMENTE SCHIFO!!! ....... con la meccanica basta cambiare le viterie più importanti con altre più resistenti, controllare le sedi dei cuscinetti nelle leve del rotore e caso mai mettere alcune gocce di frena filetti per tenerli bloccati. tenere controllato il piatto, al 5° volo prenderà un lasco pericoloso, conviene colare alcune gocce di attak con 1po di polvere di bicarbonato per frenare lo stacco delle due parti. se usate le pale in dotazione nel kit, occhio a non esagerare con i giri, si strappano facilmente! per il resto è ok ....... almeno per i primi periodi di utilizzo, dopo sarà necessario sostituire un buon 90% dei cuscinetti che prenderanno laschi da paura!! ...... d'altra parte se contate i cuscinetti presenti nel modello e provate a comprarli di marca seria, otterrete un prezzo più alto di tutto il modello. Secondo la mia idea questi modelli vanno bene se vengono inseriti su riproduzioni in scala e che al 90% rimangono posati in vetrina come modelli statici. ciao ciao ElyTeo |
![]() | #46 (permalink) Top | |
User Data registr.: 10-06-2007 Residenza: Sansepolcro (Ar)
Sentiamo cosa dice chi ha già il 500... PS: Non ho una vetrina dove tenerlo, quindi sono costretto a volarci ![]()
__________________ Modifica Optic 8Ch ---- Luci Programmabili ---- RcSwitch ---- Il Mio Sito HK500GT & Flymentor - HK450 & SMPilot- SMTech450 & SMPilot --- SM-PILOT [ The Stabilizer ] | |
![]() | #47 (permalink) Top |
Sospeso |
le forze in gioco tra i due modelli sono molto differenti, il 450 vola anche con notevoli laschi, il 500 genera meno laschi ma più rotture! io ne ho testati 3 e tutti e tre hanno avuto lo stesso problema, naturalmente non mi sono limitato all'hovering ma li ho spremuti un pochetto, non esageratamente ma un po di 3D soft ....... ho utilizzato versioni tutto in metallo, in due ho avuto problemi a svitare le vitine che tengono le manine di coda al corpo centrale, hanno utilizzato un frena filetti forte su vitine di burro e si sono strappate, ho dovuto, "da nuovi", cambiare immediatamente le parti centrali dei porta palini. ElyTeo |
![]() | #49 (permalink) Top | |
ho comprato un coda in metallo a soli 18 euro su ebay.....risultato: mi è successa la stessa identica cosa. svitavo le viti per mettere del buon frena filetti e si sono rotte come ho dato mezzo giro....lacoda è fatta anche bene ma le viti fanno cagare...... ![]() | |
![]() | #50 (permalink) Top |
Beh questo è possibile, ma le vitine da 2 se ci viene messo troppo fenafiletti è facile romperle, anche quelle di qualità. Io di solito quando le viti non vengono le scaldo con il saldatore, il frenafiletti si allenta. Se stringono un pezzo in plastica ovviamente è più complicato non è salutare scaldarle troppo.
cloni picoz | bienne | Elimodellismo in Generale | 0 | 13 marzo 07 14:43 |
dremel VS cloni | ravenlinux2000 | Utensili e materiali per costruzione | 14 | 01 febbraio 07 14:36 |
PicooZ e cloni | Dinamico | Elimodellismo Motore Elettrico | 13 | 26 novembre 06 14:24 |
Zoom 400 e Cloni | Shark981 | Elimodellismo Motore Elettrico | 0 | 12 agosto 06 18:31 |
Dragonfly 3d e relativi cloni | erupter | Elimodellismo Motore Elettrico | 15 | 31 gennaio 05 22:49 |
