11 ottobre 09, 23:40 | #91 (permalink) Top | |
User Data registr.: 10-08-2008
Here's a table for one of my throttle/pitch settings that gives me a hover at half stick, I use this for in the house. Your head may not be set up the same so really you have to expereiment no one can really tell you specific settings because they are all built by different people at different times of the day hard to find consistancy here. Throttle; L - 0% 1 - 40% 2 - 85% 3 - 85% H - 100% So you see here your flying at a constant head speed between half an 3/4 stick @ 85% throttle ( headspeed does change with load, but this keeps it from popping into the cieling, you can also go into revo mix and set that to compensate your acceleration settings for the tail pitch, this is detailed in the 2801 tx handbook) Pitch; L - 61.5% 1 - 64% 2 - 66% 3 - 80% H - 100% This gives you a very docile heli that can fly in your living room along with expo and dual rates jacked up to desensitize the stick at middle, it wont slam down/up, lifts off smooth, and flys full range between 1/2 and 3/4 stick. the norm, st1, st2 just gives you 3 types of tables - say norm for in the house st1 for outside not windy, st2 for outside windy etc....
__________________ - Spektrum DX7 Bearnig + Voltage MOD - Walkera 4G6 HP08-2 (2801Pro Switch MOD) - T-REX 450 PRO V3 - T-REX 600N LE | |
12 ottobre 09, 00:31 | #92 (permalink) Top |
User |
si avevo già letto e a confronto con le mie siamo lì. Io ho uno stile di volo un po piu vivace. comunque è una buona partenza per poi adattarle alle proprie esigenze. per il revo mix è da verificare. per ora il mio pollice è piu affidabile.
__________________ T-REX 450 METAL - HDX450 FULL METAL - WALKERA 4#3B BL MAIN - WALKERA 4G6 MOD - SU-31 DEPRON - MULTIWII QUADX |
guardate il mio gioiellino!! | the best | Automodellismo Mot. Scoppio On-Road | 8 | 14 settembre 08 20:22 |
Gioiellino da rcgroups | gmo78 | Categoria F3K | 7 | 10 settembre 08 23:46 |
E di questo gioiellino?? | matt81 | Aeromodellismo Volo 3D | 11 | 04 ottobre 06 01:09 |
Un altro gioiellino.... | redaniel | Aeromodellismo Alianti | 8 | 22 luglio 05 13:19 |
