![]() | #1 (permalink) Top |
Sospeso | Questo coax NON vola in salotto....!
e non costa neppure una fucilata! http://www.cad-modelltechnik-jung.de...ll_trainer.htm (trad automatica :-( ) Technical data Ka-52 (Ka-50), model yardstick 1: 6 Dimensions: Length over all 2,667 mm Height over all 825 mm Fuselage length 2,255 mm Span 1,217 mm Main rotor diameter 2 x 2.0 m (and/or 2.4 m) Rotor speed 1,100 1/min, (and/or 950 1/min) Engine speed 6,500 1/min Take-off mass approx. 18 kg Stand for drive, 2 different propulsion variants to the selection: Petrol engine ZG 62SL (62ccm), max. 3.5 KW (approx. 4.6 HP), magneto ignition, regular grade fuel 1: 50 and 2-Wellenturbine JetCat SPT5-H, 6.5 KW (approx. 9 HP), kerosene starting system Equipment: Electrical nose and main retractable landing gear. In front dual tire Linked height and rudders Onboard Elektrostarter Semi Scale swash plates and rotor linking in aluminum Lighting system Rocket launcher Servo control, receiving: 1 x gas 4 x swash plates (4 point linking) 1 x craving 2 x elevators, combines with TS-control 1 x rudder, combines with TS-control 1 x PCM double superreceiver 1 x Gyro system for greed servo, Futaba GY 401 2 x Akkus 5-zellig, electronic switch inclusive. Akkuweiche Governor, Throttle Jockey pro with enterprise with petrol engine ZG62 SL (Model Avionics) High current switch for E-starters Rotor control: Cyclic control: Both rotors possess in each case a swash plate for control that in each case three. Rotor blades. The control of the lower rotor blades is made directly by the TS-outer ring of the lower TS. The control of the upper rotor blades is made indirectly by the upper swash plate and the mixture controls arranged above the upper rotor head. In the case of cyclic control of the lower TS the upper TS is linked directly in the same direction with. By skillful selection of the swash plate diameters and mixture control parameters same cyclic excursions have the upper and lower rotor system. Collective pitch: The pitch control takes place at both swash plates in the same direction. Through/lowers the lower TS the upper TS lifts directly with is addressed. Via the aforementioned mixture controls however a larger excursion takes place to the rotor head sheet holding at the upper rotor head. Thereby a yaw moment develops on the helicopter, which by a transmitter-lateral static tail rotor - admixture in connection with a Gierkreisel becomes balanced. Yaw control: The yaw control of the rotor system takes place via against-intimate pitch control of the two rotor heads. At the two rotors develop different buoyancy coefficients and thus torques of which craving helicopters around the vertical axis cause. The resulting lift at both rotors remains the same, so that the model away-rises not at the same time or drops. The yaw control (tail rotor function) is headed for by axial to adjust the mixture control bridge, at which again the mixture controls are installed. The mixture control bridge over a rod inner slider/bellcrank combination is headed for by the hollowbored interior driveshaft by the greed servo. Via the aforementioned control directly only the control of the sheet owners of the upper rotor head takes place. Gegensinnig in addition is reached by means of a transmitter-lateral admixture a sinking/a rise of the lower TS. Thereby, as mentions already above, again differently large excursions at the two rotor heads enstehen, facilitate the whole yaw control not necessarily. An efficient and co-ordinated Gyrosystem in connection with a sufficiently fast and strong digital servo is a condition for a good tail stabilization |
![]() | #5 (permalink) Top | |
Sospeso | Citazione:
Prices * Base price mechanics (inclusive. On board electrical starter): 4.950, - Eur * RC-plates (CFK), for the assembly of complete RC-electronics: 145, - Eur * Coach chassis consisting for above mentioned mechanics of aluminum skid chassis, hood, 1 litre tank, tail with tail units and Abstrebung (complete in aluminum/CFK): 545, - Eur * Kit without ZG-petrol engine, muffler plant, Starterakku, RC-electronics, rotor blades and trunk cell Ka-52 | |
![]() | #6 (permalink) Top | |
User Data registr.: 05-04-2005 Residenza: Salerno - provincia
![]() Trainer version consisting of aluminium carriage, canopy, 2 x 1 litre tank, rear with tailplanes and tail support (complete in carbon fibre) 640,- Eurcerto, 1 capottina, un carrello, 2 serbatoi e la coda ![]() Basic price mechanics 4.650,- Eur ![]() ops... sono arrivato tardi ![]() | |
![]() | #10 (permalink) Top |
User Data registr.: 20-03-2006 Residenza: venere
ciao a tutti il kamov ka 50 hokum è l'unico elicottero coassiale al mondo che in caso di avaria ,sgancia tutto il rotore e il pilota si spara fuori dall'abitaccolo ,un vero sedile iettabile figo no?
Anche questo vola... (ed è semplice) | tacchino | Aeromodellismo Principianti | 22 | 13 aprile 08 13:46 |
Progettino IV° - Arlecchino - questo almeno vola ... | paologiusy | Aeromodellismo Progettazione e Costruzione | 41 | 15 marzo 07 12:10 |
Come vola questo? | Cherottu | Aeromodellismo Volo Elettrico | 3 | 26 febbraio 07 17:53 |
incredibile vola veramente questo frullino df4 | stroncapaperi | Elimodellismo Principianti | 0 | 26 marzo 06 17:30 |
