| | #21 (permalink) Top |
| User Data registr.: 14-10-2012 Residenza: San Bonifacio
Questa è la risposta di Castle Creation thanks for your email. The data log shows 564.7F for the max temperature This is an anomaly that usually occurs when the data logger becomes full Did you plug in the ESC again after having this issue? If so please send the data log with that so I can see if the error code was recorded the next time the ESC booted up. If you cleared the log and you do not have this was the ESC beeping a code when it shut down? From what I can tell the last flight on the log was 70 seconds long and it almost looks like 51 seconds the auto hub or something in the drive slipped the temp at the end of the log is an error that gets logged when the logging is stopped in mid stream If the drive was slipping you would have felt like the motor quit from the log you can see the motor ran unloaded for about 20 seconds until it looks like the battery was unplugged . Was the ESC beeping an error code when you got to it? I would update the firmware and clear the data log after you update the firmware you should always clear the data log after updating the firmware. If you are having a problem with the auto bearing it will come back so be careful while testing. Stamattina ho cancellato il log dalla memoria del regolatore, ho staccato il pc e connesso l'ESC alla ricevente per provare a vuoto il motore. Risultato, il regolatore è defunto!!!! Oltre a non emettere più alcun suono al collegamento della batteria, non lo si riesce più a connettere al pc.. Oltre a mandare una mail a Castle, che dovrei fare?? il regolatore ha un'ora e mezza di voli.. |
| | #22 (permalink) Top |
| User Data registr.: 21-05-2006 Residenza: Near Monza
Ma non è in garanzia? Dici 1h 1/2 di volo , ma inteso sul quel modello o da quando l'hai acqusitato? Non è che vale poco come regolatore.
__________________ - WIGENS F3A 2mt - HYDEOUT F3A 2mt - SATURN F3A 2mt - YAK 55 73" - SU-29 2mt OS33GT http://www.youtube.com/watch?v=1BT9OLdXy58 |
| | #23 (permalink) Top |
La garanzia che da castle sui suoi prodotti è di un anno, Questo regolatore è al limite della garanzia.. Castle mi ha invitato di mandare tutto in assistenza!! Spero che il regolatore venga passato in garanzia..
| | #24 (permalink) Top | |
__________________ - WIGENS F3A 2mt - HYDEOUT F3A 2mt - SATURN F3A 2mt - YAK 55 73" - SU-29 2mt OS33GT http://www.youtube.com/watch?v=1BT9OLdXy58 | |
| Bookmarks |
