18 gennaio 13, 18:27 | #5612 (permalink) Top |
User Data registr.: 08-02-2009
Domandina.... Mi sono ftto 2 minutini per rodare le batterie appena arrivate... Alla prima dando idle up al salire dei giri ho avuto uno sballamento di coda esagerato... Poi nulla... Poi facebdo un po di su e giu in accellerazione trema tantissimo... Ingranaggini C e D nuovi, il resto tutto bene... Ho prpvato anche una mollettina di edubu molto preciso! Ora vorrei abbassare il gain ciclico ma non ricordo e non l'ho mai fatto... Non trovo manco piu il post... Chi gentilmente mi ricorda cone fare? Graziie |
18 gennaio 13, 18:53 | #5613 (permalink) Top |
User Data registr.: 20-05-2011
ciao diablosr89 l secreto del gain su gli 3 assi....arrivato 130 X Gyro Gain Menu Hi Guys, Now that the 130 X is shipping now, we want to share our little secret about the gyro adjust ability. This was not in the manual because it not required to fly the helicopter, we feel out the box the helicopter flies great for the consumer. However some of the consumers want this ability to tinker and play with it. Below is the instructions on how to access and use the Gyro menu program in the 130 X. Hope everyone enjoys their 130 X's!! 3-Axis Gyro Menu To Enter Programming Mode 1. TX on throttle set to high (100%) 2. Plug the flight battery into the helicopter. 3. The Status LED will go solid blue, then there will be a sequence of Red, Green, and Blue Flashing LEDs 4. The RED LED will now be solid and the status LED will be flashing. To change between axis use the Elevator stick. Red LED = Elevator Green LED = Aileron Blue LED = Rudder To change the gain value use the Aileron stick There are ten steps available in either direction, total of 20 gain values for each axis. The highest and lowest values are not high enough or low enough to cause not to be flyable. It adjusts the gain in a window we determined was useful to the consumer. Right Aileron increases the gain, the LED lights will start flashing faster. Left Aileron decreases the gain, the LED lights will start flashing slower. When the Axis LED is solid that is default value (neutral gain). To reset the settings to default Hold right rudder for 5 seconds while in programming mode, there will be a sequence of Red, Green and Blue flashing LEDs to signify the default settings have been applied. Rudder value must be at 100% travel for this to occur. To exit the menu. Simply just unplug the battery. Set the throttle to low throttle or throttle hold and re-plug in the battery. |
18 gennaio 13, 20:11 | #5614 (permalink) Top |
User Data registr.: 17-03-2011 Residenza: Torino
| Esc esterno
Domandina (molto probabilmente già trattato come argomento ma non riesco a venirne fuori): Visto che l'esc esterno in mio possesso ha un Bec di 5V e 1A come faccio ad aumentare il voltaggio per la 3in1? Devo fare uno step-up? Come? ho chiesto consiglio a un mio amico interessato in elettronica ma lui non è sicurissimo della soluzione da applicare e io non me la sento di giocarmi una 3in1 senza prima chiedere consiglio a voi! Ho provato a collegarla ma la 3in1 flasha lentamente x informarmi che la corrente è troppo bassa. Grazie in anticipo |
18 gennaio 13, 20:23 | #5615 (permalink) Top | |
User Data registr.: 14-02-2012 Residenza: Bergamo
18 gennaio 13, 20:55 | #5617 (permalink) Top | |
User Data registr.: 02-10-2011 Residenza: milano sud
__________________ bladebuster Gaui X7, Oxy 5, Oxy 4 max, Oxy 4, Oxy3, Oxy 2 Ultima modifica di bladebuster : 22 luglio 14 alle ore 09:03 | |
18 gennaio 13, 20:57 | #5618 (permalink) Top | |
altrimenti, puoi alimentare la 3in1 dalla lipo, e dalla medesima alimentare l'esc esterno. di fatto ignori il bec dell'esc. io lo uso cosi (addirittura collego la 3in1 al bilanciatore della lipo, ed il motore ai flight leads, cosi evito del tutto i bottleneck elettrici).
__________________ bladebuster Gaui X7, Oxy 5, Oxy 4 max, Oxy 4, Oxy3, Oxy 2 | |
18 gennaio 13, 21:00 | #5619 (permalink) Top |
Ok allora Accendo la radio gas al 100% collego la lipo.... Si accendono i 3 tipi di led, tramite l'aletone abbasso facendo per es 3 tac a sx, poi per confermare? Tolgo la lipo, spengo la radio, faccio tutto da capo radio,lipo, e pii volo? Ho capito? |
18 gennaio 13, 21:04 | #5620 (permalink) Top | |
Grazie Blade! | |
Club e-flite Blade mSR | maRRRco | Elimodellismo Club Modelli | 7664 | 10 ottobre 15 13:32 |
Club E-Flite Blade MCX ........................ settaggi, upgrade e consigli ........ | fulvico | Elimodellismo Micromodelli | 1025 | 27 marzo 13 13:27 |
