27 febbraio 14, 22:15 | #4121 (permalink) Top |
User Data registr.: 05-09-2004 Residenza: Perugia
Ma la turnigy 9x originale non dovrebbe essere frequency hopper spread spectrum cioè FHSS ?? NEW Turnigy 2.4Ghz FHSS and DSSS - 9 channel radio under $80.00 - RC Groups RC Model Reviews • View topic - Review: Turnigy 9X version 2 (FHSS). |
28 febbraio 14, 00:10 | #4122 (permalink) Top | |
User Data registr.: 29-12-2012
http://www.mavbot.com/2012/12/build-...y-th9x-to.html http://www.rcgroups.com/forums/showt...6162&page=1063 Ultima modifica di pincopaolino : 28 febbraio 14 alle ore 00:15 | |
28 febbraio 14, 00:22 | #4123 (permalink) Top |
AFHDS is different than DSSS and FHSS. It is not dual-channel DSSS either. Everybody can define his/her AFHDS scheme, as long as it makes sense to be related to AFHDS. I guess the designer of the 'B' version uses something like the following: * It uses frame-based bursting transmissions. As for how wide a RF channel is in spectrum, only the designer knows. Or you can measure it if you have a good Spectrum Analyzer. * The RF module and the receivers can use a few different RF channels. At the start, they both work on the same default channel. During the time slot the RF module is not transmitting, it can sense the signal levels on different channels. If it senses a channel which is much less utilized than the current channel, it will inform the receiver in data frame sent to it to switch to that channel. This process can be repeated; and this qualifies to be called AFHDS. . http://www.rcgroups.com/forums/showt...35575&page=153 |
28 febbraio 14, 01:04 | #4124 (permalink) Top |
User Data registr.: 22-11-2013
Vorrei colorare i canopy con i colori a smalto della Humbrol, mi sapete consigliare un qualche "fissante" o comunque un qualcosa di trasparente da applicare sopra per farli tenere? Purtroppo non ho piu' un negozio di modellismo nelle vicinanze quindi non disdegnerei un prodotto "alternativo" ai preferibili tamya, magari qualcosa che possa trovare in un OBI o in ferramenta o ditemi voi su Amazon. Mi piacerebbe anche trovare una fonte per i colori online (ed eventuali fissanti, accessori, tubi in carbonio) che non abbia una folli di sovraccarico di spese di spedizione per comprare qualche nuovo colore
__________________ v911 - LadyBird - nQX - SuperCP - HFP80 - HCP80 - HCP100 - Devo 7e MoD - Taranis - Heli-X Wing Wing Z-84 - Bonsai - M. Sonic - Sonic 64 EDF - S.Kinetic - Rare Bear M. - Walrus - Phoenix 2K - M. DLG - Sbach EPP - Extra 330 - Edge 540T - MX2 EPP 955 - Yak - Reaktor - SCT 1/16 |
28 febbraio 14, 02:10 | #4126 (permalink) Top |
| ...ne parleranno nel thead del v912, questo e' il v911 amico
28 febbraio 14, 20:06 | #4127 (permalink) Top |
Mi ha risposto massive rc suggerendomi l'hely compatibile per turnigy 9x hisky-hfp80-micro-heli-bnf-flysky-compatible ho ragione di credere che sia identico a questo HiSKY HFP80 FBL70 2.4G 4 Channel Flybarless 3 Axis Mini 3D RC Helicopter Compatible with FS Transmitter Yellow ARF - Tmart.com |
28 febbraio 14, 20:29 | #4128 (permalink) Top |
User Data registr.: 19-01-2014 Residenza: benevento
se mi arriva questo dannato v911 con la sua maledetta radio compro questo e vi faccio sapere se è compatibile. se banggood non mi ha fatto un 'pacc' mi dovrebbe arrivare tra lunedì e venerdì prossimo perchè a mia sorella sono arrivati gli ordini effettuati il 6 febbraio.
__________________ 1004G-B Micro falcon 9927 v911 in giro chissà dove |
28 febbraio 14, 20:59 | #4129 (permalink) Top | |
BTW: oggi pomeriggio ho volato un tot con un discreto vento: - il v911 ovviamente di tanto in tanto arrancava e veniva spedito via, a volte la coda andava per i suoi o on riusciva a girare dove lo volevo mandare io - l'HFP80 andava come una cavalletta sparata con una fionda sulle montagne russe: molto divertente. Molta piu' forza anche diretto contro il vento e curve strettissime senza scomporsi, si mette a 90' ma non si ribalta mai quindi e' facile da gestire. - HCP100: molto piu' potente e pesante ma molto piu' difficile, impegnativo da gestire, da' molta meno confidenza e risulta meno efficacie se non si e' sempre precisissimi sugli stick. - quad tipo ladybird: il piu' facile da gestire, buona capacita' di tagliare il vento ma meno agile degli altri. Comunque decisamente noioso. A fine giornata HFP80 ha fatto 12 lipo e ZERO danni, l'HCP100 7 lipo con 2 tail boom e un telaio spaccato a meta (e visto che c'era vento mi stavo pure tenendo ), V911 e quad hanno fatto 2 lipo l'uno.
__________________ v911 - LadyBird - nQX - SuperCP - HFP80 - HCP80 - HCP100 - Devo 7e MoD - Taranis - Heli-X Wing Wing Z-84 - Bonsai - M. Sonic - Sonic 64 EDF - S.Kinetic - Rare Bear M. - Walrus - Phoenix 2K - M. DLG - Sbach EPP - Extra 330 - Edge 540T - MX2 EPP 955 - Yak - Reaktor - SCT 1/16 | |
28 febbraio 14, 21:29 | #4130 (permalink) Top | |
User Data registr.: 01-12-2013 Residenza: Napoli
