![]() | #902 (permalink) Top | |
User | Citazione:
io credo che il frenafiletti almeno si debba mettere, non credo decada la garanzia secondo voi è ancora troppo presto per inoltrare richieste alla horyzon? | |
![]() | #903 (permalink) Top | |
User Data registr.: 29-07-2009 Residenza: roma
__________________ DX7 - Easy glider brushless-Easy star(videoriprese) - RC Alpha 1500 - Hype Cessna 182 78 cm- Parkzone Archer W l'elettrico! silenzioso, ecologico e pulito | |
![]() | #906 (permalink) Top |
User |
ecco alla mia domanda la risposta seguente, vediamo di capirci qualcosa "" Hi everyone i have read about bearings question, but i now don't understand well which is the problem ... you speak about load or axial force, bearing open face out or in, spacers etc but where is the problem ? there is a bit of general confusion defective bearings, incorrect assembly, faulty design or something else ?? then, the t-rex 250 bearings solve the presunted problem? http://www.helipal.com/h25060-bearin...qk1mdi1t86akp2 i have o couple of this definitely, what i have to check when my hely arrive ?? please, can someone do a summary about this topic ? "" Like every other CP heli out there, you'll need to have the screwdrivers, the bottle of blue (or purple) Loctite, and possibly some CA ready. Looking over at Helifreak, the main issues are: A) Check all the metal-on-metal fasteners. The feathering shaft has a habit of disassembling itself unless you apply a little Loctite to the screws. On that note, you should be periodically checking all the screws on this heli . . . just like every other CP heli out there. ![]() C) The main gear is press-fitted onto the shaft and is retained by friction alone. Some people have reported that it tends to migrate downward, inducing vibrations. D) You have to be on top of the collective on takeoff, since the mCP X (like every other FBL heli) will tend to try to tip over on takeoff. E) It's (and this should be no surprise to anyone) surprisingly twitchy, and doing 3D requires much better collective management than bigger, more powerful, helis. It's not a suitable next step from an mSR. F) When you pull off the blade grip, look at the bearing face on the blade side of the grip. You should be able to see the copper/brass retaining ring visible in the gap between the inner and outer race on this side of the bearing, (if you see all silver, pry it out and flip it around, as it has been installed backward at the factory). And G) While that blade grip is still in your hands, look at the hub side of it. The bearing face on this side should show all silver, and you shouldn't be seeing the copper/brass retaining ring on this side. If your blade grip shows the copper ring on the hub side and the all silver face on the grip side, it is probably a failure just waiting to happen. |
![]() | #907 (permalink) Top | |
![]() | #908 (permalink) Top | |
UserPlus | Citazione:
![]() Forse mi arriva domani. Darò un'occhiata su bocabearings e atomicmods, magari hanno cuscinetti di miglior qualità... | |
![]() | #909 (permalink) Top |
User |
Se ho ragione (e spero di no) basterebbe 1 rondella a spessore differenziato, oppure una piccola e una più grande insieme... più o meno come nelle manine dell'ESKY CP2... Nell'esploso (dal manuale on line) sembra che ci sia un cuscinetto reggispinta, e non mi pare di vedere rondella di "sicurezza". Se quel cuscinetto e tutto ciò che "tiene" la manina, se salta quello salta la manina... Ma così è troppo campato in aria...
__________________ Ad un certo punto, inspiegabilmente voli... DX6i - T-Rex 250 - HBKing V2 - mSR - E-Sky CP2 - PZ Sukhoy 26XP BL 2s - HK PittsSpecial - PZ µT-28 - mCP-X BL - Sbach BL - mQX - Mig15 - 130X - Nano BL-Wild Ultima modifica di Blekmacigno : 10 marzo 11 alle ore 15:46 |
![]() | #910 (permalink) Top |
User Data registr.: 22-01-2010 Residenza: Torino
| ![]() ![]() Che bello.. è arrivato.. Adesso cominciano le preocupazioni per il cuscinetto.. ![]() Speriamo che Eflite faccia chiarezza in fretta. Alex, ci dai una parola di conforto? ![]()
__________________ Scorpio 2&10 - mCX - mSR - mCP X Dx6i |
E-flite Blade 400 3D RTF | Pentium | Elimodellismo Principianti | 27 | 06 febbraio 18 22:02 |
Fatto passaggio da E-Flite Blade120SR a E-Flite Blade 400 3D consigli e pareri da v | jegor | Elimodellismo Principianti | 12 | 03 febbraio 11 08:46 |
e-flite blade cp: help!! | lama_con_la_bava | Elimodellismo Motore Elettrico | 13 | 28 marzo 09 21:28 |
Differenza e-flite Blade Cp e Blade cx2... | gabri81 | Elimodellismo Principianti | 1 | 10 ottobre 07 15:42 |
