![]() | #682 (permalink) Top | |
User Data registr.: 04-05-2008 Residenza: Barlassina-milano nord
__________________ " Andrea" GAUI X5 FES, Trex 500/AS350, AngelFighter F-35,F6f Hellcat ,Piper 2350 ,ExtremeFlightMXS64", Fly Baby , RedArrows EDF JET...YAK 1050EPP., F109, Bmw 1/10, Buggy 1/16 | |
![]() | #683 (permalink) Top | |
User Data registr.: 01-08-2008 Residenza: TORINO
| ![]() Citazione:
mancherebbe solo il connettore tra il banana e le tue batterie.. Carica le Lipo da 1 a 6 cells..Carica tutto. Secondo me, se ti fà comodo l'attacco a 12v e anche il 220 è ottimo. ciao
__________________ baracca1 - MCX2 - PROTOS 700 MAX V2 - Logo550 VBar Carbon - DEVIL 380 - ESACOTTERO CRIUS AIO V2 - EACHINE E010 + H8 - SPEKTRUM DX8 - Ferrovia MARKLIN H0 | |
![]() | #684 (permalink) Top | |
![]() | #685 (permalink) Top |
The Pro-Peak Sigma EQ is a high performance unit for charging, discharging and cycling batteries at home or the field. Its integral Lithium Cell balancing System makes it as versatile as it is practical. Suitable for 240v AC or 12v DC input, it comes complete with adaptor boards for cycling all major brands of Li-Po batteries. Its large backlit LCD makes monitoring of the Sigma EQ's charge or discharge progress clear and simple and during balancing, each cell's voltage is displayed. 11-15v DC or 100-240v AC Input Battery Type: Li-lon/Po - 1-6 cells (3,7-7,4-11.1-14,8-18,5-22,2 volt) LiFePO4 - 1-6 cells NiCd/MH - 1-14 cells Lead-Acid - 1-6 cells Max charge: 6A (2C Li-Po) Max Discharge 1A Max 50W output Please note that due to the 50 Watt output (as found on many of the mid range chargers) as the voltage of the battery requiring charging increases the current ability (Amps) of the charger decreases. As an example a 6s 22.2v LiPo could be charged at a maximum rate of 2.25 Amps. Please consider this factor when selecting a charger to ensure that it is fully capable of charging your batteries at the expected charge rate. Se vuoi sapere altro chiedi pure ciao
![]() | #686 (permalink) Top | |
| ![]() Citazione:
Lo stò usando io,non parlo per sentito dire. ciao
![]() | #687 (permalink) Top |
Eilà, oggi sciopero? Siete già in vacanza? Ieri sera mi sono dedicato a montare un imnpiantino luci sul kds....avevo il kit della extreme preso tempo fà e mai usato: ho attaccato la centralina sotto la lipo (su una fiancata), posizionato due led ai fianchi, uno sul tubo di coda prima dello stabilizzatore,un led rosso su coda (questo indipendente, alimentato da sua batteria), e faro bianco sotto fusoliera. Ah, dimenticavo, led bianco messo sopra il gyro che illumina il rotore...una figata. Quest'ultimo è a luce fissa ma appena la lipo scende sotto il voltaggio, prima che l'esc tagli il power, inizia alampeggiare. ![]() Lo so, lo so: il video.Stasera inizio a farvi vedere l'albero di natale... ![]()
![]() | #688 (permalink) Top |
Una banalità....1000 mah= 1A; se io carico una lipo da 2800 a 2800mah, a cosa la stò caricando, 2.8A? ![]() No, perchè si dice di non caricare le lipo a più di 1A, o forse ho le idee confuse...
![]() | #690 (permalink) Top | |
| ![]() Citazione:
Và riferito alla capacità della batteria se ad esemprio fosse da 1500mah a 1C di carica = 1500mah = 1,5A corrente di carica. Un buon carichino fà tutto da solo, non puoi sbagliare, devi solo selezionare il tipo e la capacità della batteria. ciao
KDS 800 Gyro chi lo conosce? | Capitan Harlock | Elimodellismo Motore Elettrico | 4 | 31 agosto 08 23:57 |
T-rex 450S CF o T-rex 450S ARF o 3DX450 B | ste_23_66 | Elimodellismo Motore Elettrico | 6 | 18 dicembre 06 01:12 |
