25 maggio 08, 22:08 | #31 (permalink) Top | |
Sospeso Data registr.: 30-08-2006
ok......allora se li usa Rungi vuole dire che vanno bene...!!! | |
25 maggio 08, 23:44 | #33 (permalink) Top | |
User Data registr.: 20-04-2006 Residenza: Finale Ligure ,SV
HG-D260HB DIGITAL SERVO TECHNICAL DATA CONTROL SYSTEM: PULSE WIDTH CONTROL OPERATING VOLTAGE: 4.8V ~ 6.0V OPERATING TRAVEL: 30°/ ONE SIDE PULSE TRAVELING 370usec DIRECTION: COUNTERCLOCKWISE/ PULSE TRAVELING 1500 TO 1870 TEST VOLTAGE: AT 4.8V AT 6.0V OPERATING SPEED: 0.12s/60° 0.10s/60° STALL TORQUE: 2.4Kg.cm(33.32oz.in) 3.4Kg.cm(47.21oz.in) DYNAMIC TORQUE: 2.0Kg.cm(27.77oz.in) 2.5Kg.cm(34.71oz.in) DEAD BAND WIDTH: 2us FEATURES AMPLIFIER TYPE: DIGITAL PULSE WIDTH CONTROLLER & FET DRIVER LONG LIFE POTENTIOMETER: 500,000 cycles MOTOR TYPE: COLED METAL BRUSH 3POLE MOTOR TOP BALL BEARING: MR106 BALL BEARING GEAR MATERIAL: HEAVY DUTY CARBONITE GEARS HORN GEAR SPLINE: 25 SEGMENTS/ Ø5.96(FUTABA TYPE SPLINED HORNS: 4 CLASS CONNECTOR WIRE LENGTH: 270mm(10.63in) CONNECTOR WIRE STRAND COUNTER: 0.08mmx30EA DIMENTIONS SIZE: 30.0x13.0x31.5mm(1.18x0.51x1.24in)
__________________ Ciao Francesco | |
25 maggio 08, 23:45 | #34 (permalink) Top |
Ecco le caratteristiche degli ino-lab ...penso che 2,5 kg (X3) sul ciclico del 500ino non siano male ....e la velocità non è da meno HG-D260HB DIGITAL SERVO TECHNICAL DATA CONTROL SYSTEM: PULSE WIDTH CONTROL OPERATING VOLTAGE: 4.8V ~ 6.0V OPERATING TRAVEL: 30°/ ONE SIDE PULSE TRAVELING 370usec DIRECTION: COUNTERCLOCKWISE/ PULSE TRAVELING 1500 TO 1870 TEST VOLTAGE: AT 4.8V AT 6.0V OPERATING SPEED: 0.12s/60° 0.10s/60° STALL TORQUE: 2.4Kg.cm(33.32oz.in) 3.4Kg.cm(47.21oz.in) DYNAMIC TORQUE: 2.0Kg.cm(27.77oz.in) 2.5Kg.cm(34.71oz.in) DEAD BAND WIDTH: 2us FEATURES AMPLIFIER TYPE: DIGITAL PULSE WIDTH CONTROLLER & FET DRIVER LONG LIFE POTENTIOMETER: 500,000 cycles MOTOR TYPE: COLED METAL BRUSH 3POLE MOTOR TOP BALL BEARING: MR106 BALL BEARING GEAR MATERIAL: HEAVY DUTY CARBONITE GEARS HORN GEAR SPLINE: 25 SEGMENTS/ Ø5.96(FUTABA TYPE SPLINED HORNS: 4 CLASS CONNECTOR WIRE LENGTH: 270mm(10.63in) CONNECTOR WIRE STRAND COUNTER: 0.08mmx30EA DIMENTIONS SIZE: 30.0x13.0x31.5mm(1.18x0.51x1.24in)
26 maggio 08, 10:38 | #35 (permalink) Top | |
caratteristiche di forza e velocita' in linea con altri servi meno costosi e piu' collaudati per farci poi le stesse code...........inoltre....!!!! ti rammento anche a te che il thread dice......!!! configurazione protos500 senza svenarsi .......!!!!3x HG-D260HB = Euro 105,00+s.s. | |
26 maggio 08, 10:54 | #36 (permalink) Top |
User |
gli inolab a parer mio sono i migliori servi in circolazione... solo che nessuno ancora li conosce, non per niente li ha messi anche rungi se non fossero buoni sicuramente non li avrebbe presi non credete? io li monto su tutti i miei modelli...
__________________ vision 50 & os hyper,vision 50 & novarossi rex 57, T-rex 600N Pro,T-rex 500,Protos 500,Beam E4 e tanta voglia di far bene... |
26 maggio 08, 10:59 | #37 (permalink) Top |
User | Diciamo che se uno vuole delle belle accoppiate sia su rex che su protos io andrei con servi inolab e motorizzazione scorpion, i regolatori costano meno di kotronic e il governor funziona alla pari, meglio di così...
26 maggio 08, 11:31 | #38 (permalink) Top | |
E questi sono prezzi di listino...quindi è facile che il negoziante tiri giu ancora qualche euro E se poi si vuole spendere ancora meno ...allora è meglio darsi al "Ping Pong" ...perche quest'hobby è bellissimo stupendo etc etc etc ma non poco costoso!!!
__________________ Ciao Francesco Ultima modifica di firpofra : 26 maggio 08 alle ore 11:35 | |
26 maggio 08, 12:05 | #39 (permalink) Top | |
io non dico che bisogna spendere meno...dico solo che bisogna testare personalmente e poi....adesso sti ino-lab sono i servi migliori in assoluto..?? daiiiiiiiiiiiiii......!!!!!ho sbagliato di poco......adesso vogliamo dire che Futaba, Hitec e JR sono delle cippe lippe ok allora diciamolo chiaro, se si vuole stare al passo dei vari Lukas,Szabo,Rungi,ecc...ecc..... le loro configurazioni sono a quello che dicono loro di scatola, il resto e' solo pubblicita'.......se vuoi ti posto un video dove si fa 3d con comuni servi Futaba s3003 su trex600n quindi con questo hobby ci si puo' divertire spendendo come se si giocasse a ping pong ben venga....e' chiaro che se fai le gare allora il discorso cambia.!!! | |
26 maggio 08, 12:36 | #40 (permalink) Top | |
User | Citazione:
Stavo pensando di prendere gli ino lab, è il giusto compromesso costo\prestazioni e poi non mi paiono tanto peggiori dei 9257....Quelli sull'heli di luigi andavano veramente alla grande! | |
T-rex 450SE V2 in sovrappeso....quanto pesano in ordine di volo i Vostri 450? | RRRappy50 | Elimodellismo Motore Elettrico | 18 | 11 novembre 07 08:00 |
volo rovescio senza simulatore | agomago | Elimodellismo Acrobazia | 31 | 15 novembre 06 15:40 |
primissimo volo senza istruttore :) | monster | Aeromodellismo Principianti | 9 | 28 marzo 06 21:26 |
Volo all'esterno senza collettivo | texano | Elimodellismo Motore Elettrico | 7 | 15 maggio 05 21:23 |
