12 aprile 15, 20:55 | #122 (permalink) Top | |
User Data registr.: 12-02-2012 Residenza: Como
lo xerun 80a spinge benissimo mezzi di scala 1:8 / buggy & short 1:5
__________________ | |
12 aprile 15, 21:49 | #124 (permalink) Top |
| The Turnigy Trailblazer XB is a high powered 1/5 4WD racing buggy thats ready to dominate the track! With its powerful 14.8V 80A brushless system pre-installed, this buggy has plenty of power to take home the win. Large oil filled shocks, aluminum alloy drive shafts, 3mm 6061 T6 aluminum chassis, front/rear anti-sway bars, 3 differential transmission system, and sealed ball bearings all the way around shows that this buggy means business! It comes fully pre-assembled, and almost ready to run. Just add your own 2CH radio system and 14.8V batteries (2 x 7.4V) and this buggy is ready to race! Features: - 4 Wheel Drive System - 3 Diff Transmission - Alloy Steering Knuckles - Almost Ready to Run (just add your own 2CH radio system and batteries) - High Performance 1500KV Brushless Motor - 80A Hobbywing Brushless ESC - 3mm 6061 T6 Aluminum Chassis - Waterproof and Dustproof Sealed Gearbox - Quality Differential with Four Bevel Gears - Sealed Precision Ball Bearings for Entire Model - Aluminum Alloy Drive Shafts - High Torque Metal Gear Servo Pre-installed Specs: Length: 688mm Width: 430mm Height: 250mm Wheelbase: 480mm Tire Size: 150x70mm Motor: 1500KV Brushless Inrunner ESC: Hobbywing 80A Battery Tray Size: 140Lx47.5Wx29H (mm) Required: 2CH Radio System 14.8V (2 x 7.4V in series) 3000~3300mAh Lipo che poi tenga una tramissione da 1:8 viene comunque spacciata per 1:5
12 aprile 15, 22:08 | #125 (permalink) Top | |
Sospeso Data registr.: 28-09-2006 Residenza: In garage tra i modelli.....
Prendo atto di questa ennesima pagliacciata di HK, ma va benone così finchè c'è gente che le compra. Io con un 80A mi limiterei ai modelli 1/8, ma già li siamo al limite PS Le 1/5 serie vanno (decentemente) dalle 6S in su, ma si tratta di ben altri modelli. | |
13 aprile 15, 20:02 | #126 (permalink) Top |
User Data registr.: 05-01-2015 Residenza: Milano
| nuova sperimentazione :-)
ma errore mio ... presa la macchinetta e fatta andare in retro e poi tutto di colpo in avanti. Risultato "clack!" ... Girava male e subito ho temuto "differenziale rotto" ... allora smontata e notato che era saltato un dente della corona (stock 69 denti). Cambiata con ricambi e tutto ok. Solo una considerazione ... se vado in avanti e metto retro parte il freno e la ESCA rallenta il motore come da impostazione. Ma se vado in retro sparato e metto in avanti il freno agisce tutto in un colpo con il risultato che si è visto. La domanda è ... è un limite della ESC (economica Leopard V2) oppure tutte le ESCA funzionano nello stesso modo? Grazie p.s. alla prossima sperimentazione ... pensavo di provare un motore 4 poli ... boh, vedremo :-) |
13 aprile 15, 21:36 | #127 (permalink) Top |
User Data registr.: 07-05-2013 Residenza: Venezia
Pensa che molti ESC da competizione non hanno nemmeno il programma per la retromarcia. Non è un difetto del regolatore, quelli che hanno la possibilità della retro funzionano tutti allo stesso modo: Avanti/Freno/Retro/Avanti Però, se imposti la retro, puoi indicare la percentuale di velocità che vuoi abbia. Di default dovrebbe essere al 50%, ma se proprio la vuoi mettila al 25% così non fai danni.
__________________ X-Ray XB4 2wd - LRP Flow WT - REDS VX 7.5 e LRP X20 7.5 - Orion Vortex 1205 - nVision 5500 saddle 90C - Team Losi 22 - HK X-Car 120A (HW Fw 3 mod) - Trackstar 6.5T/7.5T/8.5T |
14 aprile 15, 06:42 | #130 (permalink) Top |
| Domanda ...
... Sarebbe conveniente montare una corona in metallo Al posto di quella stock in plastica? Oppure si rischia solo di spostare il punto di rottura? In caso risultasse conveniente non trovo in giro corone 69T in metallo ... Idee? Gracias |
Seben topic | REfuso | Automodellismo Mot. Elettrico Off-Road | 3117 | 10 settembre 16 00:51 |
Nasce il nuovo Seben Italia Forum dedicato solo alle Seben | guidatore_pericoloso | Automodellismo | 8 | 18 marzo 10 08:38 |
seben...parere | dark_flower | Automodellismo Mot. Scoppio On-Road | 88 | 28 luglio 09 23:54 |
Seben Buggy | urakan | Automodellismo Mot. Elettrico Off-Road | 2 | 19 dicembre 07 17:17 |
Himoto Hispeed Smartech Seben | modeldinamic | Automodellismo Mot. Scoppio On-Road | 4 | 29 agosto 06 09:57 |
