Vecchio 20 aprile 15, 09:05   #11 (permalink)  Top
Data registr.: 07-02-2015
Residenza: Verona
E dunque riesco anche a caricarci le nimh dite con questo?
Albo95 non è collegato   Rispondi citando
Vecchio 20 aprile 15, 09:06   #12 (permalink)  Top
Residenza: Verona
E dunque riesco a caricare anche le nimh con questo dici?
Vecchio 20 aprile 15, 09:13   #13 (permalink)  Top
Residenza: Verona
Sennò molto economici ho trovato questi...che mi dite?
The HobbyKing B6 Charger is a simple and compact Lipoly balance charger for 1~6S batteries, and 1-15S NiMh batteries. Featuring built in JST-XH balance plug ports and 2 LED's to indicate charge status and type, the HobbyKing B6 makes an ideal pocket sized charger to keep in your field box .
Specs:
DC Input: 11-15v
Cell Count: 1-6S Lipoly/ 1-15S NiMh
Battery type: Lithium Polymer/Nickel Metal Hydride
Charge current: 100ma-5000ma
Charge Powe: 50watt
Cut off: Auto
Dimensions: 119x92x35mm
OPPURE:
Features:
• In-built 100~240V AC to DC power supply
• Microprocessor controlled• Delta-peak sensitivity (NiMH/NiCd)
• Individual cell balancing
• Li-ion, LiPo and LiFe capable
• Ni-Cd and NiMH capable
• Large range of charge currents
• Store function, allows safe storage current
• Time limit function
• Temperature threshold cutoff (with optional temperature sensor - not included)
• Input voltage monitoring. (Protects car batteries at the field)
• Data storage (Store up to 5 packs in memory)
• Battery break in and cycling.
Specs:
Input Voltage: 11~18v (in-built 100~240V AC to DC power supply)
Circuit power: Max Charge: 80W / Max Discharge: 10W
Charge Current Range: 0.1~6.0A
Ni-MH/NiCd cells: 1~15
Li-ion/LiPo/LiFe cells: 1~6
Pb battery voltage: 2~20v
Weight: 490g
Dimensions: 135x61x112mm
Vecchio 20 aprile 15, 09:29   #14 (permalink)  Top
L'avatar di raynolds2011
Data registr.: 18-01-2011
Residenza: pisa
Originalmente inviato da Albo95 Visualizza messaggio
Specs:
DC Input: 11-15v
Charge Powe: 50watt
Cut off: Auto
OPPURE:
Features:
Specs:
Weight: 490g
diciamo che potrebbe andare bene anche questo ma con quello che ti ha indicato Culatello, visto che carica fino a 10A hai più potenza di carica e soprattutto, se prendi batterie più capienti, i tempi di ricarica sono comunque contenuti!
per circa 10 euro in più ti conviene prendere il Reaktor!
Sworkz S35 4E Kit - Brushless / S35 3E Kit - Brushless / Sworkz S35 2E Kit - Brushless / Sworkz S350 BE1 - Kit Brushless / Sworkz S14-2 - Kit Brushless
raynolds2011 non è collegato   Rispondi citando
Vecchio 20 aprile 15, 13:02   #15 (permalink)  Top
L'avatar di culatello
Data registr.: 05-12-2008
Residenza: valpolicella
fa conto che ha 5 volte la potenza di quella stupidata rovina lipo (50w contro i 250),ed una precisione imparagonabile.
il tutto per 10 euro in più .
tutto ciò che si chiama imax ,equilibrium o hitec (visto che dentro ha un semplice imax b6 o b8 a seconda dei modelli) hanno una tolleranza schifosa in carica .
basta testarle le celle con un multimetro professionale per fare la prova del 9.
con icharger ,hyperion e graupner si ha la perfezzione.
culatello non è collegato   Rispondi citando
Vecchio 20 aprile 15, 13:16   #16 (permalink)  Top
L'avatar di maxks
Data registr.: 07-05-2013
Residenza: Venezia
Originalmente inviato da culatello Visualizza messaggio
Il problema è che c'è solo nello store internazionale (Hong Kong)... quindi a meno di spedizione rapida (da 30 euro), lo dovrà aspettare dai 25 ai 45 giorni... oltre al fatto che dovrà acquistare anche l'alimentatore e non vale la pena prenderlo con lo stesso ordine, altrimenti rischia di pagare anche la dogana.
X-Ray XB4 2wd - LRP Flow WT - REDS VX 7.5 e LRP X20 7.5 - Orion Vortex 1205 - nVision 5500 saddle 90C - Team Losi 22 - HK X-Car 120A (HW Fw 3 mod) - Trackstar 6.5T/7.5T/8.5T
maxks non è collegato   Rispondi citando
Vecchio 20 aprile 15, 13:32   #17 (permalink)  Top
Residenza: Verona
Il primo CB che avevo proposto cioè lo scorpio il tizio me lo venderebbe a 30 spedito con tutti gli accessori...perciò mi sa che prendo quello, almeno in 3 giorni mi arriva...
Culatello ti avevo scritto un messaggio qualche giorno fa...ti è arrivato?
Vecchio 20 aprile 15, 16:44   #18 (permalink)  Top
Data registr.: 21-01-2014
Residenza: Montesilvano
Sono 10€ più i soldi dell'alimentatore. Altrimenti poi le persone alle prime armi comprano il caricatore e non possono usarlo perché non lo sapevano.
ILM4rcio non è collegato   Rispondi citando
Vecchio 20 aprile 15, 17:04   #19 (permalink)  Top
Residenza: Verona
Ma questo che metto in foto mi pare che abbia l'alimentatore...
Vecchio 20 aprile 15, 19:27   #20 (permalink)  Top
ciao ,si scusami non avevo voglia di aprirli ,poi ti rispondo.
Palio Scorpio e Java Scorpio gnepro Aeromodellismo Principianti 13 14 aprile 14 18:00
Radio scorpio 2&13 su scorpio 1v30 zorgric Elimodellismo Micromodelli 14 02 febbraio 13 20:19
scorpio 1&10, caricabatterie??? luca7 Elimodellismo Principianti 6 20 giugno 10 23:30
Tutti gli orari sono GMT +2. Adesso sono le 20:31.
