Vecchio 25 febbraio 07, 19:34   #1 (permalink)  Top
L'avatar di Alpino
Data registr.: 04-09-2006
Motocalc , interpretare i risultati
Ho fatto un pò di prove con motocalc per avere dei paramentri sperimentali
per il sukhoi 29S del silvestri , non mi trovo con i risultati , li metto a seguito e ditemi cosa ne pensate
In-flight Analysis - Untitled
1148ft above Sea Level, 29.92inHg, 55°F
Motor: Hacker A30 10XL; 900rpm/V; 2.3A no-load; 0.024 Ohms.
Battery: FlightPower 2500 (20C); 3 cells; 2500mAh @ 3.7V; 0.0065 Ohms/cell.
Speed Control: SPIN55; 0.94 Ohms; High rate.
Drive System: 14x8 (Pconst=1.08; Tconst=1) direct drive.
Airframe: Sukhoi 29S; 57sq.in; 127.8oz RTF; 321oz/sq.ft; Cd=0.039; Cl=0.53; Clopt=0.82; Clmax=1.07.
Stats: 3 W/lb in; 2 W/lb out; 90mph stall; 103mph opt; 127mph level; -535ft/min @ -3.4°; -535ft/min @ -3.4°.
AirSpd Drag Lift Batt Motor Motor Input Loss MGbOut MotGb Shaft Prop Thrust PSpd Prop Total Time
(mph) (oz) (oz) Amps Amps Volts (W) (W) (W) Ef(%) Ef(%) RPM (oz) (mph) Ef(%) Ef(%) (m:s)
0.0 0.0 0.0 8.6 8.6 2.8 24.5 7.8 16.6 67.9 17.4 2370 10.1 18.0 0.0 0.0 17.26
1.0 0.0 0.0 8.6 8.6 2.8 24.5 7.8 16.6 67.9 17.4 2370 9.8 17.0 7.3 1.3 17.26
2.0 0.0 0.0 8.6 8.6 2.8 24.4 7.8 16.6 67.9 17.4 2368 9.6 15.9 14.3 2.5 17.25
3.0 0.0 0.1 8.6 8.6 2.8 24.4 7.8 16.6 67.9 17.3 2365 9.3 14.9 20.8 3.6 17.25
4.0 0.0 0.1 8.6 8.6 2.8 24.4 7.8 16.6 67.9 17.3 2362 9.0 13.9 26.9 4.7 17.24
5.0 0.0 0.2 8.6 8.6 2.8 24.4 7.8 16.6 67.9 17.3 2361 8.7 12.9 32.6 5.7 17.24
6.0 0.0 0.3 8.6 8.6 2.8 24.4 7.8 16.6 67.9 17.4 2367 8.4 11.9 37.8 6.6 17.25
7.0 0.0 0.4 8.6 8.6 2.9 24.5 7.9 16.7 67.9 17.5 2385 8.1 11.1 42.4 7.4 17.28
8.0 0.0 0.5 8.6 8.6 2.9 24.7 7.9 16.8 67.9 17.7 2418 7.8 10.3 46.3 8.2 17.32
9.0 0.0 0.6 8.5 8.5 2.9 25.0 8.0 17.0 67.9 18.0 2462 7.6 9.7 49.7 8.9 17.38
10.0 0.1 0.8 8.4 8.4 3.0 25.3 8.2 17.2 67.8 18.3 2516 7.3 9.1 52.5 9.6 17.46
11.0 0.1 1.0 8.4 8.4 3.1 25.7 8.3 17.4 67.7 18.7 2583 7.0 8.6 54.8 10.3 17.56
12.0 0.1 1.1 8.3 8.3 3.2 26.1 8.5 17.7 67.6 19.2 2663 6.7 8.2 56.7 10.9 18.08
13.0 0.1 1.3 8.2 8.2 3.3 26.6 8.7 18.0 67.5 19.8 2754 6.5 7.9 58.2 11.5 18.21
14.0 0.1 1.5 8.1 8.1 3.4 27.1 8.9 18.3 67.3 20.4 2853 6.3 7.6 59.4 12.1 18.36
15.0 0.1 1.8 7.9 7.9 3.5 27.6 9.1 18.5 67.1 21.0 2959 6.0 7.4 60.4 12.7 18.53
16.0 0.1 2.0 7.8 7.8 3.6 28.1 9.3 18.8 66.9 21.7 3070 5.8 7.3 61.2 13.3 19.12
17.0 0.2 2.3 7.7 7.7 3.7 28.6 9.6 19.1 66.6 22.4 3187 5.6 7.1 61.9 13.8 19.31
18.0 0.2 2.5 7.5 7.5 3.9 29.1 9.8 19.3 66.2 23.0 3309 5.4 7.1 62.5 14.4 19.53
19.0 0.2 2.8 7.4 7.4 4.0 29.6 10.1 19.5 65.8 23.7 3433 5.2 7.0 62.9 14.9 20.15
20.0 0.2 3.1 7.3 7.3 4.1 30.0 10.4 19.6 65.4 24.4 3561 5.0 7.0 63.3 15.4 20.40
21.0 0.3 3.5 7.1 7.1 4.3 30.4 10.7 19.7 64.9 25.0 3692 4.8 7.0 63.6 15.9 21.05
22.0 0.3 3.8 7.0 7.0 4.4 30.8 11.0 19.8 64.4 25.6 3824 4.6 7.0 63.9 16.4 21.33
23.0 0.3 4.2 6.8 6.8 4.6 31.1 11.3 19.8 63.8 26.2 3959 4.5 7.0 64.2 16.8 22.02
24.0 0.3 4.5 6.7 6.7 4.7 31.4 11.6 19.8 63.2 26.8 4096 4.3 7.0 64.4 17.3 22.32
25.0 0.4 4.9 6.5 6.5 4.9 31.6 11.9 19.8 62.5 27.4 4235 4.1 7.1 64.5 17.7 23.05
26.0 0.4 5.3 6.3 6.3 5.0 31.8 12.2 19.6 61.7 27.9 4375 3.9 7.1 64.7 18.1 23.40
27.0 0.4 5.7 6.2 6.2 5.2 32.0 12.5 19.5 60.9 28.4 4517 3.8 7.2 64.8 18.4 24.16
28.0 0.5 6.2 6.0 6.0 5.3 32.0 12.8 19.3 60.1 28.8 4659 3.6 7.3 64.9 18.7 24.55
29.0 0.5 6.6 5.9 5.9 5.5 32.1 13.1 19.0 59.1 29.2 4803 3.4 7.4 65.0 19.0 25.37
30.0 0.5 7.1 5.7 5.7 5.6 32.1 13.4 18.7 58.1 29.5 4947 3.3 7.5 65.1 19.2 26.21
31.0 0.6 7.6 5.5 5.5 5.8 32.0 13.8 18.3 57.0 29.8 5093 3.1 7.6 65.2 19.4 27.08
32.0 0.6 8.1 5.4 5.4 6.0 31.9 14.1 17.8 55.8 30.0 5240 2.9 7.7 65.3 19.6 27.58
33.0 0.6 8.6 5.2 5.2 6.1 31.8 14.4 17.3 54.6 30.1 5387 2.8 7.8 65.4 19.6 28.52
34.0 0.7 9.1 5.0 5.0 6.3 31.6 14.8 16.8 53.2 30.1 5535 2.6 7.9 65.4 19.7 29.50
35.0 0.7 9.6 4.9 4.9 6.4 31.3 15.1 16.2 51.7 30.0 5682 2.4 8.0 65.5 19.6 30.51
36.0 0.7 10.2 4.7 4.7 6.6 31.0 15.5 15.5 50.1 29.8 5832 2.3 8.2 65.5 19.5 31.58
37.0 0.8 10.8 4.5 4.5 6.8 30.6 15.8 14.8 48.4 29.4 5980 2.1 8.3 65.6 19.3 33.09
38.0 0.8 11.4 4.4 4.4 6.9 30.1 16.1 14.0 46.4 29.0 6132 1.9 8.5 65.6 19.0 34.27
39.0 0.9 12.0 4.2 4.2 7.1 29.6 16.5 13.2 44.4 28.3 6283 1.8 8.6 65.6 18.6 35.51
40.0 0.9 12.6 4.0 4.0 7.2 29.1 16.8 12.2 42.1 27.5 6434 1.6 8.7 65.7 18.1 37.23
41.0 1.0 13.2 3.8 3.8 7.4 28.5 17.2 11.3 39.6 26.5 6585 1.5 8.9 65.7 17.4 39.02
42.0 1.0 13.9 3.7 3.7 7.6 27.8 17.6 10.3 36.9 25.2 6737 1.3 9.0 65.7 16.6 40.52
43.0 1.1 14.5 3.5 3.5 7.7 27.1 17.9 9.2 33.9 23.6 6888 1.1 9.2 65.7 15.5 42.51
Non si capisce un gran che
NEC VIDEAR DUM SIM
Alpino non è collegato   Rispondi citando
Italiano da interpretare Ehstìkatzi Modellismo società e istituzioni 58 10 luglio 07 08:50
interpretare disegno stefano007 Aeromodellismo Progettazione e Costruzione 4 05 giugno 07 20:32
Interpretare una polare... fra79 Aeromodellismo Progettazione e Costruzione 19 23 ottobre 06 21:32
Interpretare Le Polari MaVe Aeromodellismo Progettazione e Costruzione 3 30 marzo 06 19:57
Tutti gli orari sono GMT +2. Adesso sono le 02:04.
