27 aprile 06, 20:31 | #1 (permalink) Top |
User Data registr.: 27-04-2006
| consiglio configurazione
ciao a tutti, sono nuovo di qui volevo chiarimenti su alcuni motori brushless e regolatori trovati in rete TowerPro 30A Brushless ESC 34 euri per i due pezzi * Weight: 20.7g with wire * Size: 50x25x10mm * Constant Current: 30A * Max Current: 40A (less than 10s) * Input: 2/3 lithium battery or 4/12 NiMH * Low-voltage Cutoff: Auto detect 3800 Brushless Motor (3800Kv) * Shaft diameter: 2.3mm * Size: 27.7mm x 44.5mm * Weight: 65g * Kv: 3800rpm/V * Max. Output Power : 250W * Max. Continuous Current: 10-18A (Peak 22A for 20 seconds) * Heat Sink is integrated * Screws & 11 teeth metal gear are included Tower Pro 30A Brushless ESC 54 euri per i 2 pezzi * Weight: 20.7g with wire * Size: 50x25x10mm * Constant Current: 30A * Max Current: 40A (less than 10s) * Input: 2/3 lithium battery or 4/12 NiMH * Low-voltage Cutoff: Auto detect 1300 Outrunner Brushless Motor (1300Kv) * Shaft diameter: 3mm * Shaft Length: 14mm * Dimension : 28mm x 28mm * Recommended Propeller: 11x6,10x6,11x7 * Weight: 53g * Kv: 1300rpm/V * Propeller thrust: 1KG * Max Currect: 18A * Max efficiency: 92% * Max. Continuous Current: 1.5-18A * Screws & Parts are included TowerPro 30A Brushless ESC 45euri per i due pezzi * Weight: 20.7g with wire * Size: 50x25x10mm * Constant Current: 30A * Max Current: 40A (less than 10s) * Input: 2/3 lithium battery or 4/12 NiMH * Low-voltage Cutoff: Auto detect + 4200 Brushless Motor (4200Kv) * Shaft diameter: 2.3mm * Size: 27.7mm x 44.5mm * Weight: 70g * Kv: 4200rpm/V * Max. Output Power : 250W * Max. Continuous Current: 10-18A (Peak 22A for 20 seconds) * Heat Sink is integrated * Screws & 11 teeth metal gear are included RC Smart X-SPEED Brushless Motor 2900 23euri >Rpm(Kv): 2900Rpm/V >Resistance: 0.20 >Max Amps: 7 >Weight: 42g >Length: 29mm >Diameter:20mm >Shaft Diameter: 2.0mm >Recommended Battery: 7.2, 8.4, 11.1 Volt Li-Polymer Battery dove sta la fregatura? nella resistenza interna? nell'affidabilita? sono per elicotteri? e per quanto riguarda batterie lipo tipo queste sotto a 28euri? Li Poly 11.1v 12C 2200mAh 3 Cells Rechargeable Battery X 1 Discharge Rate: 12C Connecter: Balance/Ultra Plug Size: 105 X 33 X 30mm Weight: 175g grazie walter ho intenzione di prendere un hitec optic, servi SG90, e un greatPlanes flatout CAP580 o turmoil, che ne dite? stanno insieme i pezzi? un'altra cosa: differenza tra "cap580" con ala subito sotto il motore, "turmoil" dove questi sono allineati e un biplano tipo "Reflection" tutti e 3 della greatplanes. Gli impennaggi sulle ali del turmoil stabilizzano l'aereo maggiormente? grazie ancora Ultima modifica di pintu65a : 27 aprile 06 alle ore 20:35 Motivo: aggiunta |
27 aprile 06, 20:37 | #2 (permalink) Top |
User |
senza andare ad ammattirti, prendi il campanellino di Jonathan che costa 15e e che per un Flatout va benissimo. Batterie, 3 celle da 910 mAh sempre da joanthan+ elica APC 9x4,7 o 10,4,7. E vai col 3D!!!!! CIAO
__________________ -------------------------------- visita il nostro squadrone: www.squadronecorvi.it |
28 aprile 06, 16:17 | #6 (permalink) Top | |
User Data registr.: 23-04-2005 Residenza: Roma
__________________ Icsunonove, a.k.a. Franchino http://digilander.libero.it/polveredibalsa Imparare senza pensare è fatica perduta. Pensare senza imparare è pericoloso. (Confucio) | |
Consiglio su configurazione MM da novizio | mrsax | Aeromodellismo Principianti | 31 | 28 gennaio 08 21:50 |
help per configurazione | MaxOne | Simulatori | 8 | 24 gennaio 08 02:47 |
Configurazione ok? | giacomos77 | Aeromodellismo Volo Elettrico | 21 | 11 maggio 07 15:42 |
configurazione ok? | guizzo | Aeromodellismo Volo Elettrico | 14 | 17 dicembre 05 03:56 |
