03 marzo 06, 18:09 | #11 (permalink) Top |
User | 12.8v New safe technology Lithium Phosphate 4s1p This product is much safer than Lithium Polymer & Lithium Ion, it is only dangerous when short circuited or put in a fire, as with other cells such as Nicad or Nimh. Uses a standard Lithium charger Features: 15C discharge rate 25C bursts Lightweight at 42g per cell Can be discharged to 2v per cell Saphion cells must be from the same production batch, parallelling of cells/packs by simple harness is recommended. Specification: Size 133 x 36 x 18mm Unit Weight : 175gm Use: Boats, cars, planes & helicopter Configuration: 9 Charge: 2C 2.5Amps Discharge: 18A constant, 30A bursts (e' una 1200 mah) Charge on Lithium Ion/Poly setting at 3.6/7V per cell. 2S 7.2V/4V, 3S 10.8/11.1V, 4S 14.4/14.8V, 5S 18V/18.5V First charge at 400 mah for 3 hours Fast charge up to 2C 2.5A Can be discharged to 5V per pack. Warning: Only use lithium charge settings. Nicad & Nimh settings will cause irrepairable damage to cells. Safety Warning. These warnings relate to ALL Lithium Polymer, Lithium Ion (Li-Po, Li-Ion) cells currently available. The fact that a supplier of Lithium Polymer, Lithium Ion
__________________ Ciao Pepitos ________________________________________________ Un ulteriore controllo prima del decollo...non guasta mai !!! |
e le nuove batterie?? | Pepitos | Automodellismo Mot. Elettrico On-Road | 2 | 06 marzo 06 12:29 |
nuove batterie! | merengue | Aeromodellismo Volo Elettrico | 11 | 22 febbraio 06 09:48 |
Batterie nuove | Giacomino | Batterie e Caricabatterie | 3 | 18 settembre 05 16:02 |
nuove batterie | lapo92 | Aeromodellismo Volo Elettrico | 2 | 05 agosto 05 14:23 |
