![]() | #1 (permalink) Top |
User Data registr.: 26-12-2003 Residenza: near Nijmegen, the Netherlands
Ralph Okon (a.k.a. http://www.powerditto.de ) is putting together a group order for 40mm. diameter, 18pole statorlaminations. A minimum order of 5000 laminations is needed to start a production run. Minimum order per person is 50. One 0.20mm lamination (NO20 iron quality) will cost 0.5. Flux ring and frontplates will probably also be available by then. Keep in mind, this is not a business for Ralph, he's in the business of curing people :-) More info on ordering; http://www.rcgroups.com/forums/showthread.php?t=392627 I'm posting this in several lists/forums, think it's best if we all discussed/asked in the thread above. |
![]() | #2 (permalink) Top |
User Data registr.: 09-05-2004 Residenza: Varese (Olgiate Olona)
Probabilmente può interessarti Ron.... It is my test stand, at the monente the work is in progress. http://www.baronerosso.it/forum/inde...howtopic=12773 Ciao |
![]() | #3 (permalink) Top | |
![]() | #4 (permalink) Top |
| Turned parts, magnets, shafts, ball bearings will be available too. See: English http://www.rcgroups.com/forums/showthread.php?t=392627 http://www.powerditto.de/crocodile-projectengl.html Deutsch http://www.rclineforum.de/forum/thread.php...ghtuser=&page=4 http://www.powerditto.de/crocodile-project.html Remember, this is not a commercial thing, it's a group design project from the diy motor builders at http://www.rclineforum.de/forum/board.php?boardid=29 ![]() |
![]() | #5 (permalink) Top |
Pre-ordering shafts, fluxring, mounting plate, drive plate, statorcarrier etc (English & German): http://www.croco-power.de/ |
Ogiva x tripala da 36~40mm | Valerioraptor | Aeromodellismo Progettazione e Costruzione | 0 | 22 dicembre 07 14:39 |
powercroco motor turned parts (40mm, 18slot stator) | ron_van_sommeren | Aeromodellismo Volo Elett. - Realizzazione Motori | 2 | 06 settembre 06 03:46 |
16.5mm outrunner stator group order (&parts) | ron_van_sommeren | Aeromodellismo Volo Elett. - Realizzazione Motori | 0 | 27 maggio 06 16:07 |
[roma] Canuti's Group - Indirizzi per Messanger | Bowen | Incontri Modellistici | 2 | 05 febbraio 06 03:32 |
